Grove Shield for Arduino Nano
Grove Shield for Arduino Nano provides you a simple way to connect with Arduino Nano and also Seeeduino Nano. This shield helps you get rid of breadboard and jumper wires by pulling out the pins of the motherboard and expands to 8 Grove connectors. This shield pulls out the pins of the motherboard and expands to 8 Grove connectors, including 3 Grove digital connectors, 3 Grove analog connectors, 1 Grove I2C connector, and 1 Grove UART connector.
Parameter | Value/Range |
Operation Temperature | -25℃ to +85℃ |
Analog Ports | 3 |
Digital Ports | 3 |
UART Ports | 1 |
I2C Ports | 1 |
Size | 45mm x40mm |
Grove Shield V1.0 to V1.1, supports the Arduino Nano 33 series development board.
V1.1 Change Note: Add VCC 3.3V/5V Switch
So far, Grove Shield has been upgraded to version v1.3.
V1.3 Change Note: Version V1.3 of the Grove Shield cuts the wires connecting the RST and RSE pins on both sides.
Compatible Boards
V1.0 Support List:
- Seeeduino nano
- Arduino nano
V1.1 Support List:
- Arduino Nano
- Seeeduino Nano
- Arduino Nano Every
- Arduino Nano 33 IoT*
- Arduino Nano 33 BLE*
- Arduino Nano 33 BLE Sense*
V1.3 Support List:
- Arduino Nano
- Seeeduino Nano
- Arduino ESP32 Nano
To work with Arduino 33 serial boards, please switch the VCC power to 3.3V. If the VCC power supply is switched to 5V, the development board may be damaged!
Hardware Overview
- 1-Analog Ports: include 3 anlog ports, A0, A2, A6.
- 2-Digital Ports: include 3 digital ports, D2, D4, D6.
- 3-UART Port: 1 UART port.
- 4-I2C Ports: 1 I2C ports.
Getting Started
Hardware
- Step 1. Prepare the below stuffs:
Seeeduino Nano | Grove Shield for Arduino Nano | Grove - Buzzer | Grove - Button |
Get ONE Now | Get ONE Now | Get ONE Now | Get ONE Now |
- Step 2. Connect Grove - Buzzer to port D4 of Grove Shield
- Step 3. Connect Grove - Button to port D2 of Grove Shield
- Step 4. Plug Grove Shield for Arduino Nano into Seeeduino nano
- Step 5. Connect Seeeduino to PC through a USB cable
Software
- Step 1. Copy below code to Arduino IDE and upload to Seeeduino.
const int button = 2; // connect a button
const int buzzer = 4; // connect a buzzer
pinMode(button, INPUT); //set button as an INPUT device
pinMode(buzzer, OUTPUT); //set LED as an OUTPUT device
int btn = digitalRead(button); //read the status of the button
digitalWrite(buzzer, btn);
delay(10);
- Step 2. Press the button and we will hear the buzzer.
Schematic Online Viewer
- [Eagle] [Grove shield for Arduino Nano PCB&SCH](https://files.seeedstudio.com/products/103100124/res/Grove Shield for Arduino Nano v1.0PCB&SCH.zip)
- [PDF] [Grove shield for Arduino Nano PCB&SCH](https://files.seeedstudio.com/products/103100124/res/Grove Shield for Arduino Nano v1.0PCB&SCH.pdf)
- [SCH] [Grove shield for Arduino Nano SCH](https://files.seeedstudio.com/products/103100124/res/Grove Shield for Arduino Nano.sch)
- [BRD] [Grove shield for Arduino Nano BRD](https://files.seeedstudio.com/products/103100124/res/Grove Shield for Arduino Nano.brd)
