Grove Shield for Pi Pico V1.0
The Raspberry Pi Pico is a new popular low-cost, high-performance microcontroller board, so how to integrate Grove sensor to it? The grove shield perfectly solved this problem.
The Grove Shield for Pi Pico v1.0 is a plug-and-play shield for Raspberry Pi Pico which integrates with various kinds of Grove connectors, including 2*I2C, 3*Analog, 2*UART, 3*Digital ports, SWD debug interface and SPI pin, 3.3v/5v selectable power switch. It enables the build prototype and project in an easy and quick way without jumper wire and breadboard, you could explore infinite possibilities of Pico. The shield board is a stackable add-on board which acts as a bridge for Pi Pico and Seeed's Grove system.
Specification¶
Parameter | Value/Range |
Operating voltage | 3.⅗V |
Operation Temperature | -25℃ to +85℃ |
Analog Ports | 3 |
Digital Ports | 3 |
UART Ports | 2 |
I2C Ports | 2 |
Size | 56mm x56mm |
Compatible Boards¶
The Base Shield is tested and fully compatible with Pi Pico.
Hardware Overview¶
- 1-Analog Ports: include 3 anlog ports, A0, A1, A2.
- 2-Digital Ports: include 3 digital ports, D16, D18, D20.
- 3-UART Port: 2 UART port.
- 4-I2C Ports: 2 I2C ports.
- 5-Power Switch: 5V/3.3V selectable power switch.
6-SPI port: 1 spi0 port.
Dimension: 56mm * 56mm
Getting Started¶
Project of Different Sounds of Buzzer¶
Materials Required¶
- Step 1. Prepare the below stuffs:
Pi Pico | Grove Shield for Pi Pico | Grove - Buzzer | Grove-Rotary-Angle-Sensor |
Get ONE Now | Get ONE Now | Get ONE Now | Get ONE Now |
- Step 2. Connect Grove Buzzer to port A1 of Base Shield.
- Step 3. Connect Grove Rotary Angle Sensor to port A0 of Base Shield.
- Step 4. Plug Grove Shield for Pi Pico into Pi Pico.
- Step 5. Connect Pi Pico to PC through a USB cable.
Software¶
- Step 1. Download Thonny(Windows, Mac)Integrated Development Environment(IDE) according to your computer system.
For linux develop environment:
Binary bundle for PC (Thonny+Python):
bash <(wget -O - https://thonny.org/installer-for-linux)
pip3 install thonny
sudo apt install thonny
sudo dnf install thonny
Hit "ok" if your Raspberry Pi Pico is plugged in and running MicroPython Thonny should automatically connect to the Repl.
- Step 3. Copy below code to the Thonny IDE, and click the green run button.
Rotate Grove-Rotary-Angle-Sensor, you will hear different sounds from the buzzer.
from machine import Pin,PWM,ADC from time import sleep adc = ADC(0) #ADC input (knob potentiometer) connected to A0 pwm = PWM(Pin(27))#DAC output (buzzer) connected to A1 pwm.freq(10000) while True: '''Analog port test''' val = adc.read_u16()#Read A2 port adc value (65535~0) #Drive the buzzer, turn off the buzzer when the adc value is less than 300 if val > 300: pwm.freq(int(val/10)) pwm.duty_u16(10000) else: pwm.duty_u16(0) print(val) sleep(0.05)
Project of Detecting Temperature and Humidity¶
Materials Required¶
Pi Pico | Grove Shield for Pi Pico | Grove-OLED-Display-0.96-SSD1315 | Grove-Temperature-Humidity-Sensor-DHT11 |
Note
In this kit, we have upgraded the Grove Temperature Humidity Sensor(DHT11) to Grove Temperature Humidity Sensor(DHT20). If you want to get started with Grove Temperature Humidity Sensor(DHT20), you can click here.
- Step 2. Connect Grove OLED Display 0.96" to port I2C1 of Base Shield.
- Step 3. Connect Grove Temperature Humidity Sensor DHT11 to port D18 of Base Shield.
Software¶
Please refer to the demo1 software part.
Copy below code to the Thonny IDE at first.
from ssd1306 import SSD1306_I2C
from dht11 import *
from machine import Pin, I2C
i2c = I2C(1, scl=Pin(7), sda=Pin(6), freq=200000)#oled connect to I2C1
oled = SSD1306_I2C(128, 64, i2c)
dht2 = DHT(18) #temperature and humidity sensor connect to D18 port
while True:
temp,humid = dht2.readTempHumid()#temp: humid:
'''I2C port test'''
''' oled display test'''
oled.fill(0)#Clear screen
oled.text("Temp: " + str(temp),0,0)#display tempearture on line 1
oled.text("Humid: " + str(humid),0,8)
oled.show()
sleep(0.5)
Input dht11.py in File name column, click "ok", then the file is saved at File->Open->MicroPython device, the same with the ssd1306.py file.
After you have save both of the files to your MicroPython device, now please click the green button to run the demo code.
Then you can get the temperature and humidity displayed on the OLED as below.
Project of Controling Led and Relay¶
Materials Required¶
Pi Pico | Grove Shield for Pi Pico | Grove-button | Grove-LED | Grove relay |
Get ONE Now | Get ONE Now | Get ONE Now | Get ONE Now | Get ONE Now |
- Step 2. Connect Grove button to digital pin 18 of Base Shield.
- Step 3. Connect Grove led to port D16 of Base Shield.
- Step 4. Connect Grove Relay to port D20 of Base Shield.
- Step 5. Plug Grove Shield for Pi Pico into Pi Pico.
- Step 6. Connect Pi Pico to PC through a USB cable.
Software¶
button = Pin(18, Pin.IN, Pin.PULL_UP)# button connect to D18
button.irq(lambda pin: InterruptsButton(),Pin.IRQ_FALLING)#Set key interrupt
led = Pin(16, Pin.OUT)#led connect to D16
relay = Pin(20, Pin.OUT)
tmp = 0
'''Key interrupt function, change the state of the light when the key is pressed'''
def InterruptsButton(): #button input
global tmp
tmp = ~tmp
led.value(tmp)
relay.value(tmp)
while True:
pass
Then you can press the grove button, you can control the led and relay open and close.
Project of Flashing Colors¶
Materials Required¶
Pi Pico | Grove Shield for Pi Pico | RGB LED WS2813 mini |
- Step 2. Connect RGB LED WS2813 mini to port 18 of Base Shield.
- Step 3. Plug Grove Shield for Pi Pico into Pi Pico.
- Step 4. Connect Pi Pico to PC through a USB cable.
Software¶
from ws2812 import WS2812
import time
BLACK = (0, 0, 0)
RED = (255, 0, 0)
YELLOW = (255, 150, 0)
GREEN = (0, 255, 0)
CYAN = (0, 255, 255)
BLUE = (0, 0, 255)
PURPLE = (180, 0, 255)
WHITE = (255, 255, 255)
COLORS = (BLACK, RED, YELLOW, GREEN, CYAN, BLUE, PURPLE, WHITE)
#WS2812(pin_num,led_count)
led = WS2812(18,30)
print("fills")
for color in COLORS:
led.pixels_fill(color)
led.pixels_show()
time.sleep(0.2)
print("chases")
led.color_chase(color, 0.01)
print("rainbow")
led.rainbow_cycle(0)
Input ws2812.py in File name column, click "ok", then the file is saved at File->Open->MicroPython device.
After you have save the files to your MicroPython device, now please click the green button to run the demo code. Then you can get the RGB LED WS2813 mini flash beautiful color as below.
Project of Detecting Sound and Light¶
Materials Required¶
Pi Pico | Grove Shield for Pi Pico | grove sound sensor | Grove light sensor | Grove-16x2 LCD |
Get ONE Now | Get ONE Now | Get ONE Now | Get One Now | Get ONE Now |
- Step 2. Connect Grove sound sensor to analog pin 0 of Base Shield.
- Step 3. Connect Grove light to port A1 of Base Shield.
- Step 4. Connect Grove 16X2 lcd to port I2C1 of Base Shield.
Software¶
#from lcd1602 import LCD1602_RGB #LCD1602 RGB grove
from machine import I2C,Pin,ADC
i2c = I2C(1,scl=Pin(7), sda=Pin(6), freq=400000)
d = LCD1602(i2c, 2, 16)
#d = LCD1602_RGB.display(i2c, 2, 16)
#d.set_rgb(255, 0, 0)
sleep(1)
light = ADC(0)
sound = ADC(1)
while True:
lightVal = light.read_u16()
soundVal = sound.read_u16()
d.home()
d.print('lightvalue=')
d.print(str(lightVal))
#d.set_rgb(0, 255, 0)
sleep(1)
d.setCursor(0, 1)
d.print('soundvalue=')
d.print(str(soundVal))
#d.set_rgb(0, 0, 255)
sleep(1)
Then please download the LCD1602.py to your local. Use Thonny open LCD1602.py, click file->save as->MicroPython device.
Input LCD1602.py in File name column, click "ok", then the file is saved at File->Open->MicroPython device.
Note
In this example, the version of LCD1602 we are using is a monochrome backlit version, If you need to control the full-color backlit version of LCD1602, check out the functions in this library file to learn how to use it.
After you have save the files to your MicroPython device, now please click the green button to run the demo code. Then you can get the sound sensor and light sensor data as below.
Project of Detecting Motion¶
Materials Required¶
Pi Pico | Grove Shield for Pi Pico | grove servo | Grove Mini Fan | Grove mini pir motion sensor |
- Step 2. Connect Grove servo to analog pin 1 of Base Shield.
- Step 3. Connect Grove Mini fan to port D16 of Base Shield.
- Step 4. Connect Grove Mini pir motion sensor to port D18 of Base Shield.
Software¶
from machine import Pin,ADC,PWM
import utime
miniFun = Pin(16, Pin.OUT)
miniPir = Pin(18, Pin.IN)
pwm_Servo=PWM(Pin(27))
pwm_Servo.freq(500)
Servo_Val =0
while True:
if miniPir.value() == 1 :
miniFun.value(1)
while Servo_Val<65535:
Servo_Val=Servo_Val+50
utime.sleep_ms(1)
pwm_Servo.duty_u16(Servo_Val)
while Servo_Val>0:
Servo_Val=Servo_Val-50
utime.sleep_ms(1)
else :
miniFun.value(0)
pwm_Servo.duty_u16(0)
