Grove - Wio-E5 TTN Demo
Getting Started
The Things Network provides a global, open LoRaWAN network with a set of open tools and to build your next IoT application at low cost, featuring maximum security and ready to scale. Through robust end-to-end encryption, a secure and collaborative Internet of Things network is built that spans across many countries around the globe. Now operating thousands of gateways providing coverage to millions of people.
Preparations
Here is a demo showing you how to connect TTN (The Things Network) and Seeeduino XIAO module via Grove - Wio-E5 module. These modules are able to collect temperature and humidity parameters from the environment and send them back to TTN. The flashing LED lights on the Seeeduino Xiao indicate the status of the temperature and humidity sensor as connecting to TTN cloud.
Please ensure the consistent of the frequency band among the end nodes, gateway, and TTN configuration you are using by following this instruction. The frequency plan this demo applied is for EU868.
Hardware Required
| Seeeduino XIAO | Grove - Wio-E5 | Seeeduino XIAO Expansion Board | Grove - Temperature & Humidity Sensor (DHT11) |
If this is your first time using Seeeduino XIAO, please refer to Seeeduino XIAO's wiki. If this is your first time to use Arduino, Arduino’s website is a great resource for you to start your Arduino journey.
Hardware Connection
Step 1. Connect the Wio-E5 module directly to the "UART" slot.
Step 2. Put DH11 into the "A0/D0" socket.
Step 3. Download the code, please refer to the software part.
Software Preparation
If this is the first time you work with Arduino, we strongly recommend you to see Getting Started with Arduino before the start. Click to learn about detail about how to install an Arduino Library
Download Library
Step 1. Install the u8g2 library
Step 2. Install the DHT sensor library
Software Code
Download the example; copy the code stick onto the Aruino IDE and then upload it.
# include <Arduino.h>
# include <U8x8lib.h>
# include "DHT.h"
# define DHTPIN 0 // what pin we're connected to
// Uncomment whatever type you're using!
# define DHTTYPE DHT11 // DHT 11
// #define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/*reset=*/U8X8_PIN_NONE);
// U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(/*clock=*/ SCL, /*data=*/ SDA, /*reset=*/ U8X8_PIN_NONE); // OLEDs without Reset of the Display
static char recv_buf[512];
static bool is_exist = false;
static bool is_join = false;
static int led = 0;
static int at_send_check_response(char *p_ack, int timeout_ms, char*p_cmd, ...)
int ch;
int num = 0;
int index = 0;
int startMillis = 0;
va_list args;
memset(recv_buf, 0, sizeof(recv_buf));
va_start(args, p_cmd);
Serial1.printf(p_cmd, args);
Serial.printf(p_cmd, args);
va_end(args);
delay(200);
startMillis = millis();
if (p_ack == NULL)
return 0;
do
while (Serial1.available() > 0)
ch = Serial1.read();
recv_buf[index++] = ch;
Serial.print((char)ch);
delay(2);
if (strstr(recv_buf, p_ack) != NULL)
return 1;
} while (millis() - startMillis < timeout_ms);
return 0;
static void recv_prase(char *p_msg)
if (p_msg == NULL)
return;
char*p_start = NULL;
int data = 0;
int rssi = 0;
int snr = 0;
p_start = strstr(p_msg, "RX");
if (p_start && (1 == sscanf(p_start, "RX: \"%d\"\r\n", &data)))
Serial.println(data);
u8x8.setCursor(2, 4);
u8x8.print("led :");
led = !!data;
u8x8.print(led);
if (led)
digitalWrite(LED_BUILTIN, LOW);
else
digitalWrite(LED_BUILTIN, HIGH);
p_start = strstr(p_msg, "RSSI");
if (p_start && (1 == sscanf(p_start, "RSSI %d,", &rssi)))
u8x8.setCursor(0, 6);
u8x8.print(" ");
u8x8.setCursor(2, 6);
u8x8.print("rssi:");
u8x8.print(rssi);
p_start = strstr(p_msg, "SNR");
if (p_start && (1 == sscanf(p_start, "SNR %d", &snr)))
u8x8.setCursor(0, 7);
u8x8.print(" ");
u8x8.setCursor(2, 7);
u8x8.print("snr :");
u8x8.print(snr);
void setup(void)
u8x8.begin();
u8x8.setFlipMode(1);
pinMode(LED_BUILTIN, OUTPUT);
Serial1.begin(9600);
Serial.print("E5 LORAWAN TEST\r\n");
u8x8.setCursor(0, 0);
if (at_send_check_response("+AT: OK", 100, "AT\r\n"))
is_exist = true;
at_send_check_response("+ID: AppEui", 1000, "AT+ID\r\n");
at_send_check_response("+MODE: LWOTAA", 1000, "AT+MODE=LWOTAA\r\n");
at_send_check_response("+DR: EU868", 1000, "AT+DR=EU868\r\n");
at_send_check_response("+CH: NUM", 1000, "AT+CH=NUM,0-2\r\n");
at_send_check_response("+KEY: APPKEY", 1000, "AT+KEY=APPKEY,\"2B7E151628AED2A6ABF7158809CF4F3C\"\r\n");
at_send_check_response("+CLASS: C", 1000, "AT+CLASS=A\r\n");
at_send_check_response("+PORT: 8", 1000, "AT+PORT=8\r\n");
delay(200);
u8x8.setCursor(5, 0);
u8x8.print("LoRaWAN");
is_join = true;
else
is_exist = false;
Serial.print("No E5 module found.\r\n");
u8x8.setCursor(0, 1);
u8x8.print("unfound E5 !");
dht.begin();
u8x8.setCursor(0, 2);
u8x8.setCursor(2, 2);
u8x8.print("temp:");
u8x8.setCursor(2, 3);
u8x8.print("humi:");
u8x8.print(led);
void loop(void)
float temp = 0;
float humi = 0;
temp = dht.readTemperature();
humi = dht.readHumidity();
Serial.print("Humidity: ");
Serial.print(humi);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(temp);
Serial.println(" *C");
u8x8.print(" ");
u8x8.print(temp);
u8x8.print(humi);
if (is_exist)
int ret = 0;
if (is_join)
ret = at_send_check_response("+JOIN: Network joined", 12000, "AT+JOIN\r\n");
if (ret)
is_join = false;
else
Serial.print("JOIN failed!\r\n\r\n");
delay(5000);
else
char cmd[128];
sprintf(cmd, "AT+CMSGHEX=\"%04X%04X\"\r\n", (int)temp, (int)humi);
ret = at_send_check_response("Done", 5000, cmd);
if (ret)
recv_prase(recv_buf);
else
Serial.print("Send failed!\r\n\r\n");
delay(5000);
else
TTN Console Configuration Setup
Step 1. Visit The Things Network website and sign up for a new account
Step 2. After logging in, click your profile and select Console
- Step 3. Select a cluster to start adding devices and gateways
- Step 4. Click Go to applications
- Step 5. Click + Add application
- Step 6. Fill Application ID and click Create application
Note: Here Application name and Description are not compulsory fields. If Application name is left blank, it will use the same name as Application ID by default
The following is the newly created application
- Step 7: Navigate to
Payload formatters > Uplink, select Formatter Type as Javascript and fill the Formatter parameter as follows
function Decoder(bytes, port) {
var decoded = {};
if (port === 8) {
decoded.temp = bytes[0] <<8 | bytes[1];
decoded.humi = bytes[2] <<8 | bytes[3];
return decoded;
- Step 8: Upload the Arduino code to Seeeduino XIAO as explained before, and open serial monitor to see the following output
Humidity: 50% Temperature: 25.00 *C
AT+JOIN
+JOIN: Start
+JOIN: NORMAL
+JOIN: Join failed
+JOIN: Done
AT+ID
+ID: DevAddr, 24:40:00:7C
+ID: DevEui, 2C:F7:F1:20:24:90:03:63
+ID: AppEui, 80:00:00:00:00:00:00:07
+JOIN: Join failed
Note down DevEui and AppEUi generated above
- Step 9: Go back to the Overview page of the created application and click + Add end device
- Step 10. Click Manually, to enter the registration credentials manually
- Step 11. Select the Frequency plan according to your region. Also make sure you use the same frequency as the gateway in which you will connect this device to. Select MAC V1.0.2 as the LoRaWAN® version and PHY V1.0.2 REV B as the Regional Parameters version. These settings are according to the LoraWAN® stack of Wio-E5.
- Step 12. Copy and paste the previously obtained information from step 8 into DevEUI and AppEUI fields. End device ID field will be automatically filled when we fill DevEUI. For AppKey field, use: 2B7E151628AED2A6ABF7158809CF4F3C.
Finally click Register end device
- Step 13. Register your LoRaWAN® Gateway with TTN Console. Please refer to the instructions shown here
If you see the following output on serial monitor after everything is setup, that means the Seeeduino XIAO is successfully connected with TTN and sending the temperature and humidity sensor data!
- Step 14. Go back to the application page and navigate to End devices, select the created device and click Live data
Here you will see the temperature and humidity sensor data displayed in real-time!
- Step 15. Navigate to
Messaging > Downlink, type 01 under Payload and click Schedule downlink to turn on the built-in yellow LED on the Seeeduino XIAO.
- Step 16. Send the Payload as 00 to turn off the built-in yellow LED
Datasheet:
Certifications:
Relevant SDK:
