Use Demos from Seeed Studio's Github
It is necessary to use demos from Seeeduino Github frequently and there some slight difficult for a novice to run the demo well. So we want to show you a scheduled procedure to run the demos quickly.
Get started
You can download sample code and library or header files on Seeed's Github sites.
Click a button named "Download Zip" at Github.
Decompress the downloaded ZIP file.
Remove the "-master" twice in decompressed file name.
Copy the folder decompressed file xxx into your library folder (In default, it is same with Sketchbook Location which can be found by clicking File > Preference).
Under Windows, it will likely be called "My Documents\Arduino\libraries". For Mac users, it will likely be called "Documents/Arduino/libraries". On Linux, it will be the "libraries" folder in your sketchbook.
Add ZIP library by the downloaded ZIP file(with "-master" removed first).
- Open .ino file in the sub directory example
- Compile or Upload demos into your main controller board.
Tips: Always add compress a library file(header file in majority circumstances) with zip format if Arduino prompt that it can not find a foo.h file.
