Install Operating System
Introduction
LinkStar-H68K-V2 router equips quad-core Cortex-A55 RK3568 chip, featuring 4 Ethernet interfaces for dual-2.5G and dual-1G, along with Wi-Fi 6 technology, while providing high storage capacity and media player functionality. In this wiki we will show you how to install operating system with TF card or eMMC.
Select the system you need for LinkStar-V2
The powerful LinkStar-V2 supports a wide range of operating systems such as OpenWRT, Armbian and many more. In this section, we will bring you the installation methods for each system. Meanwhile, it is compatible with all firmware of older LinkStar H68K versions.
Notes & Instructions
LinkStar-V2 has two types of storage, one is TF card storage and the other is eMMC storage. Both memories are available for flash memory systems.
In this chapter, we can use the TF card with a card reader to flash the system to the TF card. Due to the read/write speed and stability, this way can only be flashed into the OpenWRT system.
We can also flash the system to the eMMC that comes with the LinkStar-V2. This method currently supports all supported operating systems from LinkStar-V2.
When a TF card is inserted in the LinkStar-V2, the system in the TF card is the one that boots up when the system is turned on, as the TF has priority to boot.
Flash OpenWRT to the TF card
Preparation
- Windows/MacOS PC
- USB - C data cable
- A TF card
- A card reader
- balenaEtcher —— Please download and install balenaEtcher, we will use this software to flash the system to a TF card.
- OpenWRT package
Please prepare the equipment required above, firmware update packages can be downloaded by clicking the download button below.
| Version | Description | Download |
| balenaEtcher | ISO Burner Tool | Download |
| OpenWRT R22.11.18 | Add Docker support. | Download |
When using a TF card with LinkStar-V2, it is important to note that it may be incompatible with some high-speed cards. If you are using a high speed card, you may experience data loading errors, boot-up errors or malfunctions during power-up and loading of the system due to the speed of the card.
The advantage of using a TF card is that different networks can be configured with different TF cards. It is also possible to have multiple systems - different systems can be used by replacing different TF cards.
Procedure
Step 1. Connect the TF to the PC
Please put the TF into your prepared card reader and connect it to your PC.
Step 2. Flash the system onto a TF card
Open the balenaEtcher which has been installed in advance.
Select the OpenWRT firmware you downloaded, it should end in .img.
Select the drive you want to flash the system to.
Click the Flash button and the software will flash the system into your TF.
Some computers may prompt whether the USB device is not recognised after flashing the system and whether to format it, please do not reformat the card or the system inside will be erased.
Step 3. Boot OpenWRT from the TF card
Remove the TF card from the card reader and insert it into the TF card slot of the LinkStar-V2.
Then power up the LinkStar, you can choose to power it via Type-C power.
Step 4. Manage the OpenWRT backend
Use a network cable to connect to the ETH1/ETH2/ETH3 network port of the LinkStar-V2. Then enter the address: 192.168.100.1 into your browser to access the admin backend.
ETH0 is the WAN port and the other network ports are LAN ports. If you want to manage LinkStar-V2's OpenWRT via a network cable, then connect the network cable to a LAN port other than ETH0.
The initial account and password for the system are as follows.
account: root
password: password
Congratulations, you have now successfully installed OpenWRT via TF card.
Flash OpenWRT to eMMC
Preparation
- Windows PC
- OpenWRT package
- Armbian package (Optional)
| Flash to eMMC tool & driver | - | Download |
| Armbian 24.5.0 desktop (Optional) | - | Download |
Procedure
Step 1. Install the driver
The file you downloaded contains the following three files.
Go to the Rockchip_DriverAssitant_v5.1.2 folder and double click to open the DriverInstall.exe file to install the driver.
In the driver installation software that launches, click on "驱动安装" (Driver Installation).
Step 2. Put the device into Maskrom mode
Go to the RKDevTool_Release_v2.84 folder and double click to open the RKDevTool.exe file.
At this point it should say "No Devices Found" at the bottom of the software.
Press the Update keyhole button continuously with the card pick-up pin and do not release it.Then keep your hands on the LinkStar-V2 and connect it to your computer using a USB-C type cable. Afterwards you can release the button.
At this point watch the software again and it will show from "No Devices Found" to "Found One MASKROM Device".
Step 3. Erase firmware
Click on "Upgrade Firmware", then click on "Firmware" and select the H6XK-Boot-Loader.bin file in the file directory.
After importing the file, click on "EraseFlash".
Wait for the operation to complete and click "确定" (OK).
Step 4. Flash OpenWRT
if you follow along the steps from above your LinkStar H68K-V2 should be still in MASKROOM Mode, if not please repeat and follow along the steps from Step 2 again.
Click on "Download Image" in the top left corner of the software, then select the H6XK-Boot-Loader.bin file for the first Boot option line.
Then in the second line of system options, select the system image for OpenWRT. It should be a file ending in .img.
Then click on the "Run" button below.
Wait for the "Download image OK" prompt, then the system has been successfully installed into LInkStar-V2's eMMC.
Once the system flash is complete, the LinkStar H68K-V2 should automatically reboot and once rebooted it will enter the OpenWRT system.
Step 5. Manage the OpenWRT backend
account: root
password: password
Congratulations, you have now successfully installed OpenWRT into eMMC.
LinkStar H68K-V2 is open source hardware.Download links to relevant materials.
| OpenWRT R22.11.18 | Add Docker support | Download |
| H68K-V2-SCH | H68K schemetics | Download |
| RK3568 Datasheet | - | Download |
| M7921E Wi-Fi Module | - | Download |
