FAQs for Jetson Usage
This document contains all the frequently asked questions related to Jetson series products. This will be very helpful if you are suffering from any issues when using the Jetson.
Q1: Troubleshooting Installation
For details, please click here
Q2: The remaining space in the eMMC in the received reComputer is only about 2GB, how to solve the problem of insufficient space?
Q3: How to solve the compatibility issue between reComputer and VEYE camera?
Q4: How to solve the compatibility issue between IMX477 Camera and A603 carrier board?
Q5: How to get the system log of reComputer J30/J40?
Q6: Common flashing errors during Jetson flashing.
Q7: I cannot use USB-A port, Ethernet port or no HDMI dispaly after flashing the device.
A: Please check file integrity (for instance, we provided the SHA256 cheksums), for some carrier boards (especially A60X series), make sure that the driver patch was successfully copied/applied to Linux_for_tegra directory. There are files that require sudo permission, and when you copy directories, make sure -r parameter is included in your command.
Q8: My system crashed/unable to boot/black screen/lost peripheral drivers after I execute "sudo apt-get update && sudo apt-get upgrade" commands.
A: These issues can be concluded as "Why can't I upgrade the system with apt upgrade on custom carrier boards?" The short answer is: Do not run the apt upgrade command on custom/third-party carrier boards. Additionally, avoid running any scripts that include apt upgrade commands or using GUI updater tools in Ubuntu. Debian packages from the server do not account for the specific design of our custom boards, and forcing the upgrade can cause incompatibilities that may brick your device. This process is only compatible with the official devkit. To solve these issues, please follow our guide to reflash the JetPack.
Q9: How can I upgrade software packages if you told me that I cannot execute apt upgrade? Will there be security risks if I don't upgrade the software?
Q11: What modifications does Seeed make to NVIDIA's Jetson BSP.
Q12: How to enable the SPI interface on Jetson-nano?
Q13: Why is it that sometimes after completing the flashing process on Jetson, the system fails to boot from the SSD?
This issue currently occurs when flashing JetPack 5, and NVIDIA has officially documented it. For the solution, please click here.
Q14: How to Build the Source Code Project for Seeed's Jetson BSP?
Q15: Why can’t the apt upgrade command be executed on reComputer/reServer?
The kernels and drivers of reComputer/reServer are customized. If the apt upgrade command is executed, some kernel and driver related packages may be replaced with NVIDIA’s official resources, which could cause software compatibility issues. Therefore, please do not run apt upgrade on any third-party Jetson platforms.
You can refer to the following instructions to lock the relevant APT sources. This way, if apt upgrade is accidentally executed, the impact will be minimized:
sudo apt-mark hold <package-name>
### For example:
sudo apt-mark hold nvidia-l4t-core
Q16: If the reComputer/reServer does not have the required .ko driver module, how can I compile a usable driver?
Q17:How can I mount an external hard drive formatted with exFAT on Jetson (JetPack 6)?
First, install the dependencies:
sudo apt install build-essential autoconf automake libtool pkg-config
sudo apt install git libfuse-dev
Then clone and build the exFAT driver from source:
git clone https://github.com/relan/exfat
cd exfat
autoreconf --install
./configure
make
sudo make install
Next, manually mount the disk to a local directory:
lsblk   # Check the device name of your external hard drive
sudo mkdir /media/seeed/tmp-exfat # Create a mount point
sudo mount.exfat /dev/sda3 /media/seeed/tmp-exfat/
This mounts the exFAT-formatted external drive to /media/seeed/tmp-exfat/ so that it can be accessed normally on the Jetson.
Q18:How to encrypt the disk of Jetson before flashing the image?
Q18:How to establish communication between Jetson and EtherCAT devices?
Solution for this issue: please click here
Tech support
