PyTorch to ONNX
This chapter will describe how to convert and export PyTorch models to ONNX models.
Preparation
Environment Configuration
As the Training step, we recommend you to do it in a virtual environment during the model exporting phase. In the sscma virtual environment, make sure that the Installation - Prerequisites - Install Extra Dependencies step has been completed.
If you have configured a virtual environment but not activated it, you can activate it with the following command.
conda activate sscma
Models and Weights
You also need to prepare the PyTorch model and its weights before exporting the model. For the model, you can find it in the Config section, we have already preconfigured. For the weights, you can refer to the following steps to get the model weights.
Refer to Training section and choose a model, and train to get the model weights.
Or download the SSCMA official pre-trained weights from our GitHub Releases - Model Zoo.
Export Model
For model convert and export, the relevant commands with some common parameters are listed.
python3 tools/export.py \
"<CONFIG_FILE_PATH>" \
"<CHECKPOINT_FILE_PATH>" \
--target onnx
ONNX Export Examples
Here are some model conversion examples for reference.
- FOMO Model Conversion
- PFLD Model Conversion
- SWIFT Model Conversion
configs/fomo/fomo_mobnetv2_0.35_x8_abl_coco.py \
"$(cat work_dirs/fomo_mobnetv2_0.35_x8_abl_coco/last_checkpoint)" \
--target onnx \
--cfg-options \
data_root='datasets/mask'
configs/pfld/pfld_mbv2n_112.py \
"$(cat work_dirs/pfld_mbv2n_112/last_checkpoint)" \
--target onnx \
--cfg-options \
data_root='datasets/meter'
configs/swift_yolo/swift_yolo_tiny_1xb16_300e_coco.py \
"$(cat work_dirs/swift_yolo_tiny_1xb16_300e_coco/last_checkpoint)" \
--target onnx \
--cfg-options \
data_root='datasets/digital_meter'
Model Validation
Since in the process of exporting the model, SSCMA will do some optimization for the model using some tools, such as model pruning, distillation, etc. Although we have tested and evaluated the model weights during the training process, we recommend you to validate the exported model again.
python3 tools/inference.py \
--show \
--cfg-options "<CFG_OPTIONS>"
For more parameters supported, please refer to the source code tools/inference.py or run python3 tools/inference.py --help.
Model Validation Example
- FOMO Model Validation
- PFLD Model Validation
- SWIFT-YOLO Model Validation
"$(cat work_dirs/fomo_mobnetv2_0.35_x8_abl_coco/last_checkpoint | sed -e 's/.pth/.onnx/g')" \
--show \
--cfg-options \
"$(cat work_dirs/pfld_mbv2n_112/last_checkpoint | sed -e 's/.pth/.onnx/g')" \
--show \
--cfg-options \
"$(cat work_dirs/swift_yolo_tiny_1xb16_300e_coco/last_checkpoint | sed -e 's/.pth/.onnx/g')" \
--show \
--cfg-options \
