Photo Reflective Sensor
This is a reflective sensor combines a GaA1As infrared light emitting diode with a high sensitive Darlington phototransistor in a mini package.
Compact
High performance
High output
Easy to mount on PCB
Widely applicable
Application Ideas
Timing sensors
Edge sensors
Micro floppy disc drivers
Level sensors of liquid
Maximum Ratings (Ta=25℃)
| Item | Symbol | Rating | Unit | |
| Input | Power Dissipation | PD | 100 | mW |
| Reverse Voltage | VR | 5 | V | |
| Forward Current | IF | 50 | mA | |
| Pulse Forward current *1 | IFP | 1 | A | |
| Output | Collector Power Dissipation | Pc | 100 | mW |
| Collector Current | Ic | 20 | mA | |
| C-E Voltage | VCEO | 30 | V | |
| E-C Voltage | VECO | 5 | V | |
| Operating Temperature | Topr | -10~+65 | ℃ | |
| Storage Temperature | Tstg | -25~+85 | ℃ | |
| Soldering Temperature*2 | Tsol | 260 | ℃ | |
Electro-optical Characteristics (Ta=25℃)
| Item | Symbol | Conditions | Min | Typ | Max | Unit | |
| Input | Forward Voltage | VF | IF=20mA | 1.2 | 1.6 | V | |
| Reverse Current | IR | VR=5V | 10 | µA | |||
| Capacitance | Ct | V=0V, f=1kHZ | 25 | pF | |||
| Peak Wavelength | λP | 940 | nm | ||||
| Output | Collector Dark Current | ICEO | VCE=20V | 0.1 | µA | ||
| Light Current | IL | VCE=5V,IF=20mA | 50 | µA | |||
| Leakage Current | ICEOD | VCE=5V,IF=10mA | 1 | µA | |||
| Switching Speeds | Rise Time | tr | Vcc=5V, Ic=1mA, RL=1kΩ | 15 | µsec | ||
| Fall Time | tf | 15 | µsec | ||||
Mechanic Dimensions
