Photo interrupter (OS25B10)
The OS25B10 is a high performance standard type photo interrupter, which combines high output GaAlAs infrared light emitting diode and high sensitive phototransistor.
10mm space for interruption
Easy to mount on PCB
High-speed response
Widely applicable
Application Ideas
Tape-end sensors
Timing sensors
Edge sensors
copiers
Maximum Ratings (Ta=25℃)
| Item | Symbol | Rating | Unit | |
| Input | Power Dissipation | PD | 80 | mW |
| Reverse Voltage | VR | 5 | V | |
| Forward Current | IF | 50 | mA | |
| Pulse Forward current * 1 | IFP | 1 | A | |
| Output | Collector Power Dissipation | Pc | 100 | mW |
| Collector Current | Ic | 20 | mA | |
| C-E Voltage | VCEO | 30 | V | |
| E-C Voltage | VECO | 5 | V | |
| Operating Temperature | Topr | -25~+65 | ℃ | |
| Storage Temperature | Tstg | -25~+85 | ℃ | |
| Soldering Temperature *2 | Tsol | 240 | ℃ | |
Electro-optical Characteristics (Ta=25℃)
| Item | Symbol | Conditions | Min | Typ | Max | Unit | |
| Input | Forward Voltage | VF | IF=20mA | 1.2 | 1.6 | V | |
| Reverse Current | IR | VR=5V | 10 | µA | |||
| Capacitance | Ct | f=1MHZ | 25 | pF | |||
| Peak Wavelength | λP | 940 | nm | ||||
| Output | Collector Dark Current | ICEO | VCE=10V | 1 | 100 | nA | |
| Light Current | IL | VCE=5V,IF=20mA | 1 | 2.5 | mA | ||
| C-E Saturation Voltage | VCE(sat) | IF=20mA,Ic=0.5mA | 0.2 | 0.4 | V | ||
| Switching Speeds | Rise Time | tr | Vcc=10V, Ic=5mA, RL=100Ω | 5 | µsec | ||
| Fall Time | tf | 5 | µsec | ||||
Mechanic Dimensions
The resources need to be downloaded, like Eagle file, Demo code, project or other datasheet.
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
