Piezo Sensor - MiniSense 100
The MiniSense 100 is a low cost cantilever-type vibration sensor loaded by a mass to offer high sensitivity at low frequencies. Pins are designed for easy installation and are solderable. Horizontal and vertical mounting options are offered. The active sensor area is shielded for improved RFI/EMI rejection. Rugged, flexible PVDF sensing element withstands high shock overload. Sensor has excellent linearity and dynamic range, and may be used for detecting either continuous vibration or impacts. The mass may be modified to obtain alternative frequency response and sensitivity selection (consult factory). The MiniSense 100 acts as a cantilever-beam accelerometer. When the beam is mounted horizontally, acceleration in the vertical plane creates bending in the beam, due to the inertia of the mass at the tip of the beam. Strain in the beam creates a piezoelectric response, which may be detected as a charge or voltage output across the electrodes of the sensor. The sensor may be used to detect either continuous or impulsive vibration or impacts. For excitation frequencies below the resonant frequency of the sensor, the device produces a linear output governed by the "baseline" sensitivity. The sensitivity at resonance is significantly higher. Impacts containing high frequency components will excite the resonance fre-quency, as shown in the plot above (response of MiniSense 100 to a single half-sine impulse at 100 Hz, of amplitude 0.9 g). The ability of the sensor to detect low frequency motion is strongly influenced by the external electrical circuit.
Low cost
Cantilever-type vibration sensor
High sensitivity at low frequencies
Active sensor area is shielded for improved RFI/EMI rejection
Excellent linearity and dynamic range
Application Ideas
- Detect either continuous
- Impulsive vibration or impacts
Typical Properties (at 25°C)
| Parameter | Value | Units |
| Voltage Sensitivity (open-circuit, baseline) | 1.1 | V/g |
| Charge Sensitivity (baseline) | 260 | pC/g |
| Resonance Frequency | 75 | Hz |
| Voltage Sensitivity (open-circuit, at resonance) | 6 | V/g |
| Upper Limiting Frequency (+3 dB) | 42 | Hz |
| Linearity | +/-1 | % |
| Capacitance | 244 | pF |
| Dissipation Factor | 0.018 | (none) |
| Inertial Mass | 0.3 | gram |
Environmental Specifications
| Storage Temperature | -40 to +80 deg C | |
| Operating Temperature | -20 to +60 deg C | |
| Weight | Minisense 100H | 0.5 gram |
| Minisense 100V | 0.6 gram | |
Resource
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
