Raspberry Pi Platform Devices Guide
Raspberry Pi (aka "RPi") was originally designed and created by a non-profit organization with the intention to promote teaching computer science at an affordable cost. Several generations and models of Raspberry Pis have now been released that have expanded their footprints, power and applications.
At Seeed Studio, we offer the entire Raspberry Pi family of boards as well as complementary accessories and starter kits that can help you create projects centered around the product. Additionally, we have created many tutorials in Seeed’s Raspberry Pi community where you can easily find references to build your own circuits or write your own applications.
Why Choose Raspberry Pi?
Hover over a feature to see explanation
Raspberry Pi Official Boards
| Raspberry Pi 5 | Raspberry Pi 4B | Raspberry Pi CM4 |
| Raspberry Pi 3B+ | Raspberry Pi Zero W | Raspberry Pi Pico W |
Compare Raspberry Pi Models
| 3B+ | Zero | Zero 2 W/WH | 4B | CM4 | Pico | Pico WH | 5 | |
| RAM | 1GB | 512MB | 512MB | 2/4/8 GB | 2/4/8 GB | 264 KB | 264 KB | 4/8 GB |
| Storage | Micro SD | Micro SD | Micro SD | Micro SD | Up to 32GB eMMC | 2 MB | 2 MB | Micro SD |
| Processor Type | ARMv8 x86 | ARMv6 | ARMv6 | ARMv8 x64 | ARMv8 x64 | ARM M0+ | ARM M0+ | ARMv8 x64 |
| Processor Speed | Quad Core @1.4GHz | 1GHz | Quad Core @1GHz | Quad Core @1.5GHz | Quad Core @1.5GHz | Dual Core @133MHz | Dual Core @133MHz | Quad Core @2.4Hz |
| Form Factor | Standard [a] | pHat | pHat | Standard [a] | Ultra-compact [c] | Through-Hole SOM | Through-Hole SOM | Standard [a] |
| Ethernet | ✅ | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ |
| Wifi | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ |
| Bluetooth | ❌ | ❌ | ✅ | ✅ | ❌ | ❌ | ✅ | ✅ |
| USB Ports | x4(A) | x1(Micro) | x1(Micro) | x4(A),x1(C) | ❌ | x1(Micro) | x1(Micro) | x4(A),x1(C) |
| I2C Ports | x1 | x1 | x1 | x1 | x1 | x1 | x2 | x1 |
| SPI Ports | x1 | x1 | x1 | x1 | x1 | x1 | x2 | x1 |
Getting Started
- Getting Started with Raspberry Pi 3 Model B
- Remotely connect to Raspberry Pi
- Update EEPROM for Compute Module 4
Hats (extension boards)
Grove Base Hat for Raspberry Pi
Add-on board that provides an array of Digital/Analog/I2C/PWM/UART ports to meet all your needs
Compatible With
3B+, 4B
🖱️ Buy Now📚 Getting StartedGrove Base Hat for Raspberry Pi Zero
Add-on board that provides an array of Digital/Analog/I2C/PWM/UART ports to meet all your needs in the pHat form factor of the RPi Zero family
Compatible With
Zero, Zero W/WH
🖱️ Buy Now📚 Getting StartedWM1302 Raspberry Pi Hat
Add-on board for connecting the WM1302 LoRaWAN module, based on LoRa Concentrator Semtech SX1302
Compatible With
3B+, 4B, Zero, Zero W/WH
🖱️ Buy Now📚 Getting StartedLTE Cat 1 Pi HAT
Open-source cellular extension modem for Raspberry Pi, based on u-blox LARA-R2xx series
Compatible With
ReSpeaker 2-Mics Pi HAT
Dual-microphone expansion board for Raspberry Pi designed for AI and voice applications.
Compatible With
🖱️ Buy Now📚 Getting StartedReSpeaker 4-Mics Pi HAT
Quad-microphone expansion board for Raspberry Pi designed for more powerful AI and voice applications.
Compatible With
3B+, 4B
🖱️ Buy Now📚 Getting StartedKits + Courses
Grove Base Kit for Raspberry Pi
Seeed Grove starter kit contains one Grove Base Hat(for Raspberry Pi ) and 10 Grove modules
Compatible With
3B+,4B,Zero,Zero W/H
🖱️ Buy Now📚 Getting StartedLoRa/LoRaWAN Gateway Kit
Provides all the basic elements you need to collect and transfer data from all your LoRa nodes. Build your IOT prototype within minutes
Compatible With
🖱️ Buy Now📚 Getting StartedGrove Starter Kit for Microsoft IoT
Seeed and Microsoft have worked together to alleviate some of the challenges in complex setup using Windows 10 IoT Core and Grove modules
Compatible With
🖱️ Buy Now📚 Getting StartedAccessories
Skeleton Box for Raspberry Pi Compute Module Development Kit
Constructed from military grade aluminum and hardwearing acrylic, this box is stackable in all three dimensions, allowing for limitless expansion possibilities
Compatible With
CM4
🖱️ Buy Now📚 Getting StartedSkeleton Box for Raspberry Pi
Compatible With
3B+,4B
🖱️ Buy Now📚 Getting StartedRaspberry PI B+ Clear Case
An easy to assemble clear acryllic case, made using a better-performing 4-piece design over the standard 6-piece
Compatible With
3B+
🖱️ Buy Now📚 Getting Started✨ Contributor Project
- This project is supported by the Seeed Studio Contributor Project.
- Thanks Corey's efforts and your work will be exhibited.
Updates to this page are in in progress. Stay tuned!
