RePhone APIs - Audio
RePhone supports playback audio files on SD card or on built-in flash. Formats supported include WAV, MP3, AAC, etc. With this library, you can Play, Pause, Stop playback process and Adjust volume.
The playback (decoding) job is handled internally by LinkIt. Therefore, all functions are non-blocking, which means after you call playFile(), it will play the audio and immediately return to your program.
Use getStatus() to check the current status and act correspondingly. The audio status can be "playing", "play finished", "play paused", etc. The audio will be outputted through the earphone jack on the Linkit board.
Note
If you try to play another audio file before the previous playback is finished, the previous playback will be stopped automatically, and the new audio will be played.[
Function List
- begin()
- playFile()
- setVolume()
- pause()
- resume()
- stop()
- getStatus()
APIs
LAudio.begin()
Initializes the Audio module.
- Syntax
LAudio.begin()
- Parameters
N/A
- Returns
N/A
- Example
#include <LAudio.h>
LAudio.begin();
LAudio.setVolume(2);
LAudio.playFile(storageFlash,(char*)"sample.mp3");
LAudio.playFile()
Plays an audio file on SD card or flash storage.
- Syntax
LAudio.playFile(StorageEnum drv, char *songName)
LAudio.playFile(StorageEnum drv, wchar_t* songName)
Parameters
- drv - Storage, can be storageSD (SD card) or storageFlash (flash storage)
- songName - Path of audio file in ascii (char*) or unicode (wchar_t*) encoding
Returns
N/A
- Example
#include <LAudio.h>
LAudio.begin();
LAudio.setVolume()
Adjusts the playback volume; range is from 0 (silent) to 6 (max).
- Syntax
LAudio.setVolume(unsigned char volume)
Parameters
- volume: Volume level, can be 0 to 6; 0 as silent and 6 as max volume
Returns
N/A
- Example
#include <LAudio.h>
LAudio.begin();
LAudio.pause()
Pauses the playback. It only works when there is an active playback ongoing (by playFile()).
- Syntax
LAudio.pause()
- Parameters
N/A
- Returns
N/A
- Example
#include <LAudio.h>
LAudio.begin();
delay(5000);
LAudio.pause(); // play for 5secs and pause
delay(5000);
LAudio.resume(); // wait for another 5 secs to resume
delay(5000);
LAudio.stop(); // wait for another 5 secs to stop
LAudio.resume()
Resumes playback. It only works when the playback has been paused.
- Syntax
LAudio.resume()
- Parameters
N/A
- Returns
N/A
- Example
#include <LAudio.h>
LAudio.begin();
delay(5000);
delay(5000);
delay(5000);
LAudio.stop()
Stops playback.
- Syntax
LAudio.stop()
- Parameters
N/A
- Returns
N/A
- Example
#include <LAudio.h>
LAudio.begin();
delay(5000);
delay(5000);
delay(5000);
LAudio.getStatus()
Queries the current playback status.
- Syntax
LAudio.getStatus()
- Parameters
N/A
Returns
- AudioStatus - Playback status, can be:
- AudioStop - Playback is stopped.
- AudioPause - Playback is paused (and can resume).
- AudioResume - Playback resumes
- AudioEndOfFile - Playback is finished.
- AudioCommonFailed - Playback fails (e.g. the audio file is corrupted).
Example
#include <LAudio.h>
LAudio.begin();
AudioStatus status;
status = LAudio.getStatus();
if(AudioEndOfFile == status) // Check if playback finish and restart
Example
- Description
With this example, you can play a mp3 file. Open serial monitor to input a number to control the playing.
Command as below:
- Play
- Setvolume
- Pause
- Resume
- Stop
- Code
You can find the code here: File -> Examples -> LAudio -> AudioPlayer
RePhone audio test Demo
First you need to put a mp3 file to storage
Then open the Serial monitor, input number to change the status
1 - Play
2 - Setvolume
3 - Pause
4 - Resume
5 - Stop
#include <LAudio.h>
// add your music file name here
#define FILE_NAME "music.mp3"
#define PLAY 1
#define SETVOLUME 2
#define PAUSE 3
#define RESUME 4
#define STOP 5
unsigned char Status_Value = STOP;
int volume = 6;
void changeVolume()
volume++;
volume = volume>6 ? 1 : volume;
LAudio.begin();
Serial.println("Play - 1");
Serial.println("Setvolume - 2");
Serial.println("Pause - 3");
Serial.println("Resume - 4");
Serial.println("Stop - 5");
Change_Status(PLAY);
char StatusFlag = 0;
unsigned char KEY_NUM;
AudioStatus status;
KEY_NUM = task_uart_key();
if(KEY_NUM > 0)
Change_Status(KEY_NUM);
KEY_NUM = 0;
if(StatusFlag != status)
StatusFlag = status;
Serial.print("LAudio status is ");
Serial.println(status);
if(status == AudioEndOfFile)
Status_Value = PLAY;
Change_Status(Status_Value);
void Change_Status(unsigned char status)
switch(status)
case 1:
LAudio.playFile(storageFlash,(char*)"music.mp3");
LAudio.setVolume(volume);
Serial.println("playOne");
break;
case 2:
changeVolume();
Serial.print("set volume to ");
Serial.println(volume);
break;
case 3:
LAudio.pause();
Serial.println("pause");
break;
case 4:
LAudio.resume();
Serial.println("resume");
break;
case 5:
LAudio.stop();
Serial.println("stop");
break;
default:
break;
unsigned int task_uart_key()
String inString = "";
unsigned int keyValue = 0;
unsigned char bitCount = 0;
unsigned char dataTemp1[10] = {0};
while(Serial.available() > 0)
unsigned char inChar = Serial.read();
inString += (char)inChar;
dataTemp1[bitCount] = inChar - '0';
bitCount += 1;
delay(10);
if(inString != "")
if(bitCount > 4)
Serial.println("Key input error.");
else
for(char i=0;i<bitCount;i++)
unsigned int dataTemp2 = 1;
for(char j=0;j<(bitCount-i-1);j++)dataTemp2 *= 10;
keyValue += (dataTemp1[i] * dataTemp2);
Serial.print("Key value is: ");
Serial.println(keyValue);
return keyValue;
