RePhone Lumi Kit
RePhone Lumi Kit is specially designed for LED lovers - embedding the Xadow GSM+BLE module into your awesome lighting device and control the light via SMS or Bluetooth!
Xadow GSM+BLE
| Microcontroller | MT2502 |
| MCU Core | 32-bit ARM7EJ-STM RISC processor |
| RAM | 4 MB |
| Flash Memory | 16 MB |
| Power Supply | 3.3 ~ 4.2V(no SIM)/3.5 ~ 4.2V(with SIM) |
| Power Consumption | 20mW/30mW/52mW @ standby(no radio)/standby(GSM)/standby(BT) |
| Quad-band | 850/900/1800/1900 MHz |
| GPRS | Class 12 modem |
| Clock Speed | 260 MHz |
| Connectors | 35 PIN Connector & 11 PIN Connector for Xadow Modules; JST 1.0 Connector for the battery |
| Interfaces | LCD, Audio, I2C, SPI, UART, and GPIOs etc |
| Dimensions | 25.37mm × 20.30mm / 1" × 0.8" |
Xadow Duino
| Microcontroller | ATmega32u4 |
| Power Supply | 5V via USB, current draw is 1.5A at Max 3.3 ~ 4.2V via battery socket, current draw is 1.5A at Max 3.3 ~ 6V via breakout pins, current draw is 500 mA at Max 3.3 ~ 4.2 V via Xadow GSM+BLE, current draw is 500 mA at Max |
| Charging Current | 500 mA |
| Flash Memory | 32 KB (ATmega32u4) of which 4 KB used by bootloader |
| SRAM | 2.5 KB (ATmega32u4) |
| EEPROM | 1 KB (ATmega32u4) |
| Clock Speed | 16 MHz |
| Connector | 2 × 11 PIN Xadow Connector Bonding pads for RGB LED WS2812b |
| Interfaces | Interface with Xadow GSM+BLE through I2C (7-bit address 0x23) |
| Dimensions | 25.37mm × 20.30mm / 1"× 0.8" |
Xadow GSM Breakout
Module Connection
The Xadow GSM+BLE integrates a Xadow 36 Pin connector and a Xadow 11 Pin connector. As the image shows here, you can connect the Xadow GSM+BLE to Xadow GSM breakout with a Xadow 36 Pin cable, but do bear in mind that the cable has to be inserted firmly and flat, and most importantly, keep the 'TOP' side upwards. The Xadow 11 Pin connector have much more flexible design, you can connect the Xadow Duino and the mainboard with a Xadow 11 Pin ribbon cable in whatever way you want, again just make sure cable is firmly inserted.
Control the Light with SMS!
Here is an example of controlling you RGB LEDs by sending a message to your RePhone.
Then copy the following code to your Arduino IDE for RePhone. Choose the board as "RePhone" and download it with the "MTK USB Debug Port".
#include <LCheckSIM.h>
#include <LGSM.h>
#include <LWs2812.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
//SMS command 0 : "OFF" - off display.
//SMS command 1 : "R100G0B0" - red color is 100, green color is 0, blue coler is 0.
char num[20];
char buf_contex[200];
Serial.print("Ws2812 test.\r\n");
unsigned long rgb_color;
if(LSMS.available())
LSMS.remoteNumber(num, 20);
LSMS.remoteContent(buf_contex, 50);
Serial.println("Get new sms: ");
Serial.print("Number:");
Serial.println(num);
Serial.print("Content:");
Serial.println(buf_contex);
if(strcmp("OFF", buf_contex) == 0)
Serial.print("RGB off.\r\n");
LWs2812.monochrome(5, 0, 1);
else
if(StingFind(buf_contex, "R", 1))
if(StingFind(buf_contex, "G", 1))
if(StingFind(buf_contex, "B", 1))
Serial.print("RGB flag is find.\r\n");
char color_r[4] = {0};
char color_g[4] = {0};
char color_b[4] = {0};
sscanf(buf_contex + 1,"%[^G]", color_r);
sscanf(buf_contex,"%*[^G]G%[^B]", color_g);
sscanf(buf_contex,"%*[^B]B%[^\0]", color_b);
rgb_color = atol(color_r)*256*256 + atol(color_g)*256 + atol(color_b);
Serial.print("rgb color is ");
Serial.println(rgb_color);
delay(100);
LWs2812.monochrome(5, rgb_color, 0);
delay(100);
int StingFind(char* string, char* find, int number)
char* pos = string;
char* p = string;
int count = 0;
while(number > 0)
pos = strstr(p, find);
if(pos == 0)return -1;
while(p <= pos)
if(*p > 0x80 || *p < 0)
p ++;
p ++;
count ++;
number --;
return count;
In this code we set the SMS command as: ··· "OFF" - off display. "R100G0B0" - red color is 100, green color is 0, blue coler is 0. ···
So if we send "R100G0B0" to the RePhone, the LEDs will become red as showing below:
More Example Code
Playing with some example code would a good start if you are heading into some even more interesting project.
- Simply setup your sketchbook location in the preference as where you install the Arduino IDE for RePhone, then you'll be able to see the example codes.
- You may find the Arduino example coded manually for all the RePhone modules in the following path:
Arduino_IDE_for_RePhone-master\hardware\arduino\mtk\libraries
RePhone Community
We’ve been looking for a better place where our backers (RePhone Users) can sit together, warmly and comfortably, have conversations about RePhone, discuss technical problems, share ideas/projects, and give feedback on the modules’ development in the future. And then here we go, the RePhone Community.
Now join us in the RePhone Community! Together we seek answers, make interesting stuff, care about each other, and share our experiences.
Frequently Asked Questions
Some frequently asked questions in RePhone Community are collected and answered to the topic "Frequently Asked Questions of RePhone (FAQ)" , the topic will be kept updating whenever a new FAQ comes out.
