Renbotics Servo Shield Rev
The Renbotics ServoShield is an Arduino-compatible shield that uses two 4017 decade counters to drive up to 16 servos using only 4 pins (digital pins 6 to 9) and as little as one 8bit timer (Timer 2) in standard mode or two 16/8bit timers (Timer 1 and Timer 2 for Duemilanove or Timer 3 for Mega) in high accuracy mode. It also includes a 196 point breadboard style prototyping area.
16 Servo Channels
Convenient screw terminal for servo power supply
196 Point breadboard style prototyping area
Compatible with Arduino Duemilanove and Arduino Mega
Easy to use API
Application Ideas
Robotics
Animatronics
Mechatronic Art
Usage
Hardware Installation
Accembled View:
Programming
Sample 1: Simple servo sweeper
#include <ServoShield.h>
ServoShield servos; //Create a ServoShield object
for (int servo = 0; servo < 16; servo++)//Initialize all 16 servos
servos.setbounds(servo, 1000, 2000); //Set the minimum and maximum pulse duration
servos.setposition(servo, 1500); //Set the initial position of the servo
servos.start(); //Start the servo shield
for(int pos = 1000; pos < 2000; pos++) //Move the servos from 0 degrees to 180 degrees
{ //in steps of 1 degree
for (int i = 0; i < 16; i++) //for all 16 servos
servos.setposition(i, pos); //Tell servo to go to position in variable 'pos'
delay(1);
for(int pos = 2000; pos >= 1000; pos--)//Move the servos from 180 degrees to 0 degrees
for (int i = 0; i < 16; i++) //all 16 servos
delay(1);
Bill of Materials (BOM) /parts list
2 x 4017 Decade Counter DIP16
2 x 10nf Capacitors
2 x 6 pin Female Shield Stacking Headers
2 x 8 pin Female Shield Stacking Headers
1 x 2 pin Screw Terminal
3 x 16 pin Male Breakaway Headers
Version Tracker
| Revision | Descriptions | Release |
| v1.1 | Initial public release | Aug 23, 2009 |
