Sensing & Network
This topic here introduces the Seeed Studio product documentation regarding the very first step of digitized data from physical world, that is, delopying information infrastructures in a dynamic sensing framework, to lay the groundwork for society monitoring and understanding the physical and natural environments.
You can discover this page with two large portions.
industrial grade sensors with long range connectivity and intelligence
Specialized
"Sensor Network" topic
SenseCAP sensors and probes offer multiple ambient data sensing, with industrial hardware design.
SenseCAP LoRaWAN Sensors
Wiki PDF Download ⏬
SenseCAP S2101 - Temperature and Humidity -> Get One Now
SenseCAP S2102 - Wireless Light Intensity -> Get One Now
SenseCAP S2103 - Temperature, Humidity and CO2 > Get One Now
SenseCAP S2104 - Soil Moisture and Temperature > Get One Now
SenseCAP S2105 - Soil Moisture, Temperature and EC > Get One Now
SenseCAP Multi-in-one Sensors
Wiki PDF Download ⏬
SenseCAP ORCH S4 - 4-in-1 weather sensor -> Get One Now
SenseCAP ONE S500 - 5-in-1 weather sensor -> Get One Now
SenseCAP ONE S700 - 7-in-1 weather sensor -> Get One Now
SenseCAP ONE S900 - 9-in-1 weather sensor > Get One Now
SenseCAP ONE S1000 - 10-in-1 weather sensor > Get One Now
SenseCAP Sensor Probes
Liquid Level Detecting
-> Wiki Website
-> Get One Now
Water Leak Warning
-> Wiki Website
-> Get One Now
pH Meter for Soil Conditions and Water Quality
-> Wiki Website
-> Get One Now
Soil Moisture & Temperature Probe
-> Wiki Website
-> Get One Now
Soil Moisture & Temperature & EC Probe
-> Wiki Website
-> Get One Now
RS485 500cm Ultrasonic Level Sensor
-> Wiki Website
-> Get One Now
Get One Now
Wiki Page
Industrial IoT - Specialized
We launched industrial grade sensors with long range connectivity and intelligence, generating digitized data from physical world in instrumental-level precision. You can find in this portion with:- Sensors & Probes for various industrial-grade environmental data sensing
- AI-based Sensors for reday-to-deploy intelligent scenarios
- Data Logger for remote environmental data monitoring
- Gateway for long-range, high-security, indoor and outdoor data transmission
- Other network infrastructures for data transmission, such as routers.
Industrial Sensors and Probes
Water Leak Warning
PDF Download of SenseCAP ONE Weather Sensor Sereis User Guide
SenseCAP ONE S500 - Temperature, Humidity, Barometric Pressure, Wind Speed, and Wind Direction
SenseCAP ONE S700 - Temperature, Humidity, Wind Speed/Direction, Barometric Pressure, Light Intensity, Precipitation Intensity
SenseCAP ONE S900 - 9-in-1 sensor, capable of sensing PM2.5 and PM10
SenseCAP ONE S1000 - 10-in-1 sensor, capable of sensing CO2, PM2.5 and PM10
Industrial AI-based Sensors
Train and Deploy Your Own AI Model Into SenseCAP A1101
One Stop Model Training with Edge Impulse
Data Logger with Configuration Guide
Configure the 12V RS485 Sensor for S2100 Data Logger
Configure the Analog Sensor for S2100 Data Logger
Configure the Counter & GPIO Sensor for S2100 Data Logger
Build LoRaWAN® Sensors with SenseCAP S2110 Sensor Builder and SenseCAP Data Logger
PDF Download of SenseCAP Sensor Hub 4G User Guide
PDF Download of Private MQTT Messaging of SenseCAP SensorHub Developer Guide
Gateway for Multiple Platform
SenseCAP M1 Local Console
SenseCAP M2 Data Only Quick Start
SenseCAP M2 Data Only Local Console
SenseCAP M2 Light Gateway Quick Start
SenseCAP M2 Light Gateway FAQ
Connectting AWS Platform
Connectting TTN Platform
Connectting ChirpStack Platform
SenseCAP M4 Square Quick Start
SenseCAP M4 Square FAQ
The Things Indoor Gateway
Routers for Other Network Infrastructure
Original OS Installation
Application: OpenWRT Installation
Application: Plex Media Server Installation
Application: Mender Usage for reRouter
Application: Building a smart home control centre around Home Assistant
Easy IoT - Build Your Own
Without complicated instruments, we can sense and monitor the physical world just using microcontrollers and simple functional elecrtricals. That is, in this portion you can find:- Grove sensors and other functional electricals
- Microtrollers and attached extension board, accessories, etc
- Application for IoT or embedded ML methods acknowledge
- Kit with free courses and more intriguing tutorials
Sensors and Sensors' Network
Thermal Imaging
One Wire - MAX31850K
NOx/PM/VOC/RH/Temp
Fast Models Traning
Two Probe Type
Gesture
Laser PM2.5 Sensor
Dust Sensor
Multichannel Gas
Sunlight(Multiple Light)
Fingerprint
GSR(Galvanic Skin)
Recorder
Speech Recognizer
Round Force Sensitive
Slide Potentiometer
Serial Bluetooth v3.0
NFC Tag
GPS - Air530
125KHz RFID Reader
868MHz Long Range
RJ45 Adapter
Frequency Modulation Receiver
24GHz mmWave Fall Detection Sensor , 24GHz mmWave Human Static Presence Sensor
60GHz mmWave Sleep Breathing Monitoring Module
60GHz mmWave Breathing and Heartbeat Module
60GHz mmWave Fall Detection Module Pro
Microwave Sensor - 24GHz Doppler Radar Motion Sensor - MW2401TR11
Water Flow Sensor , Gear Stepper Motor Driver Pack
Photo Reflective Sensor , Weight Sensor
WiFi Serial Transceiver Module
2KM Long Range RF link kits w/ encoder and decoder
Microcontrollers
Pin Multiplexing
LCD, IMU, PDM, IO Ports, Light Sensor, SD Card
CircuitPython, Wi-Fi, Bluetooth
Wio RP2040 Boards
Wio Tracker Boards
Seeeduino Cloud Boards
Seeeduino LoRaWAN® Boards
Arch BLE Boards
Arch GPRS Boards
Getting Started with Arduino Boards
Getting Started with Micro:bit Boards
MT3620 Mini Dev Board for Azure Sphere
reButton for Azure IoT Hub/IoT Central
Air602 Firmware Manual
Eagleye 530s
Linklt ONE
ATmega328
Mobile Robotic Platform
Application
Easy IoT Application
> SenseCAP & Node-Red for Cloud Services
Integrated Azure IoT, Power BI, InfluxDB
> Helium Cloud Services
Integrated Azure IoT, Google Sheets, AWS IOT
> TTN Cloud Services
> Quick Start With Blynk
> Quick Start With Google Cloud IoT
> Develop in Microsoft Azure IoT Central
> Data visualisation with Power BI
> Advanced WiFi Usage
Wappsto IoT
Azure IoT Central, Azure IoT Hub
Use Socket to connect to the forum
Wireless Fall Detection Device
Embedde ML Scenarios
> Continuous Motion Recognition
> Audio scene recognition
> People counting with Ultrasonic sensor
> Distinguishing Beverage
> Anomaly detection for Predictive Maintenance
> TensorFlow Lite Micro Getting Started
> Weather Prediction
> Speech Recognition and Speech-to-Internet
> Gesture Recognition
> Speech Recognition with TensorFlow Lite
> Motion Recognition with Edge Impulse
Extensions
Find out more
Battery Chassis, Battery Chassis with LoRaWAN®
Board 2: 8 Grove ports / Battery Management
Seeed Studio Round Display Extension Board for XIAO
RTC for Wio Tracker
Accessories
LCD RGB Backlight
PWM Driver
RTC - PCF85063TP based
±5A DC/AC current sensor
MOSFET
LED Bar
RGB LED Ring
6-Position DIP Switch
Panel Mount Switch
8 Channel I2C Multiplexer
Grove to Qwiic Hub
LCD 8*2
Solar Panel
DC framework
RS-232 To TTL Conveter
RFID module
AVR USB Programmer
Shield MaTrix V0.9
DSO Nano Oscilloscope
RF Explorer Software
Kit with Courses
Grove Speech Recognizer Kit for Arduino
Grove Smart Plant Care Kit
Applications Kit ML101 with Prof. Vijay Course
Introduction to Artificial Intelligence for Makers
Tutorials
How to add Seeed Studio boards to Arduino IDE
How to use demos downloaded from Seeed Studio Github
How to use and write a library
How to upload code
Use External Editor
Suli, Seeed Arduino Serial
I2C And I2C Address of Seeed Product
Firmata Tutorial - How to Use Firmata on Arduino Compatible
FreeRTOS Tutorial - How to use FreeRTOS apply Multi-tasking
How to Debug Arduino Boards using SWD Interface
Flashing the Arduino Bootloader using DAP Link
Compiling MicroPython for embedded devices
Codecraft Platform for Arduino
Joystick Control RGB Led
Light Sensor and LED Bar
USB Host for a Keyboard, Mouse, Xbox
USB Client for a Keyboard, Mouse, MIDI, HMI
How to display Gyro on Wio Terminal
How to use Wio Terminal to store data
How to use Wio Terminal to display photos
Wio Terminal Interactive Faces Demo
Pressure sensor using the Wio terminal
Reading Coronavirus Live Data using Wio Terminal
How to measure noise levels with Wio Terminal
How to Use Wio Terminal as RTL8720DN Dev Board
