SenseCAP Data Logger
Data Logger serves as the bridge to up to 200+ sensors covering industrial-level sensors, Grove sensors and Analog/RS485/GPIO sensors.
Hardware Products​
SenseCAP Sensor Hub Data Logger​
SenseCAP Sensor Hub is a compact solution for remote environmental monitoring. It consists of a powerful data logger that can connect a maximum of 40 RS-485 sensors and a wide range of sensor selection, you can use it for applications like weather station, air quality monitoring. With IP66 and solar power supply, you can count on it to provide a reliable and nonvolatile data collection service. Two versions of the SenseCAP Sensor Hub Data Logger: 2G and 4G, both are available.
SesneCAP Mobile APP,SenseCAP web-based portal, SenseCAP API, and SenseCAP Dashboard are also available for quick configuration and devices + data management.
SenseCAP S2100 LoRaWAN Data Logger​
The SenseCAP S2100 Data Logger is a versatile device that can connect to MODBUS-RTU RS485/Analog/GPIO sensors, allowing for easy transmission of data to the LoRaWAN network. With its LoRa and IP66 design, this device boasts impressive stability and reliability, and can cover a long transmission range while keeping ultra-low power consumption. It is perfect for outdoor use, and can be powered by battery or connected to a 12V external power supply for even greater flexibility. When connected to the 12V power supply, the replaceable built-in battery acts as a backup power source. Additionally, the S2100 Data Logger is optimized for OTA with built-in Bluetooth, making setup and updates quick and simple. To top it off, the S2110 converter enables the S2100 Data Logger to connect to Grove Sensors, making it an excellent choice for DIY industrial-level LoRaWAN sensors and small-scale deployment.
✨ Contributor Project​
  • We have a task list for updating this page, which is categorized under our contributor project, as we are dedicated to enhancing the user experience and providing better support through the development of our wiki platform.
  • Your contribution to this page is essential to us! We really value your input and would greatly appreciate your assistance in generating ideas.
SenseCAP Tech Support​
