SenseCAP K1100 Guide - The Sensor Prototype Kit
Introduction
The SenseCAP K1100 is a comprehensive, cutting-edge environmental monitoring kit designed to provide seamless data collection and analysis. It integrates advanced sensors and connectivity options, making it a versatile solution for various environmental monitoring applications. This kit is ideal for developers, researchers, and hobbyists looking to prototype and deploy robust IoT solutions efficiently.
The Idea of True Wild
The SenseCAP K1100 prototype kit bridges the gap between initial concept development and real-world deployment. It enables users to rapidly create and test their environmental monitoring solutions before deploying them in the field. This transition from prototype to a true wild solution ensures that the devices are reliable, durable, and capable of withstanding various environmental conditions.
Getting Started with SenseCAP K1100
| The Sensor Prototype Kit Introduction | Quick & No-code Initiation with SenseCraft |
| In this tutorial, you can experience the fun of data collection and data processing with our open source project in the shortest time. | We offer two paths for our users to experience IoT, one is LoRa® and the other is WiFi. This tutorial will teach you how to use them. |
LoRaWAN-Network Application
Sensors Basic Usage with Arduino
| Wio Terminal Light Sensor | Wio Terminal IMU Sensor | Grove Soil Moisture Sensor |
| In this section, we will detail how the Light sensors work, how to get sensor data using Wio Terminal and how to send the data out using Wio Terminal & Grove - Wio-E5. | In this section, we will detail how the IMU sensors work, how to get sensor data using Wio Terminal and how to send the data out using Wio Terminal & Grove - Wio-E5. | In this section, we will detail how the Grove Soil Moisture sensors work, how to get sensor data using Wio Terminal and how to send the data out using Wio Terminal & Grove - Wio-E5. |
| Grove VOC and eCO2 Gas Sensor (SGP30) | Grove Temp&Humi Sensor (SHT40) | Grove Vision AI Module |
| In this section, we will detail how the Grove VOC and eCO2 Gas sensors work, how to get sensor data using Wio Terminal and how to send the data out using Wio Terminal & Grove - Wio-E5. | In this section, we will detail how the Grove Temp&Humi sensors work, how to get sensor data using Wio Terminal and how to send the data out using Wio Terminal & Grove - Wio-E5. | In this section, we will detail how the Grove Vision AI Module work, how to get sensor data using Wio Terminal and how to send the data out using Wio Terminal & Grove - Wio-E5. |
Cloud Services
| Helium Cloud Services | TTN Cloud Services | SenseCAP & Node-Red for Cloud Services |
| In this chapter, we will introduce the Helium console controls that we use to get a first impression of the Helium console. | In this chapter, we will introduce the TTN console controls that we use to get a first impression of the TTN console. | Node-RED is a programming tool for wiring together hardware devices, APIs and online services in new and interesting ways. We will do a series of tutorials for SenseCAP & Node-RED. |
Wi-Fi-Network Application
| Advanced WiFi Usage | Cloud Service | Azure IoT Platform Usage |
| This wiki introduces some of the advanced library usage of the Wi-Fi such as HTTPClient, DNSServer and WebServer Libraries. With these libraries implemented, you are able to develop your IoT projects with simple APIs. | In this chapter, we will guide you through connecting Ubidots, Blynk, and Google Cloud using the Wio Terminal. | In this tutorial, we will walk you through the process of connecting the Wio Terminal to Microsoft Azure IoT Central and send telemetry data from the onboard sensors/ hardware on the Wio Terminal such as the 3-axis accelerometer, light sensor, 3 buttons to Microsoft Azure IoT Central. |
Embedded ML Application
| Built-in Sensors with Edge Impulse | Vision AI with Customizable Models |
| This article show a solution for guys wanna use edgeimpulse to generated models and connect with cloud. In our demo , we will use google sheet. | In this wiki, we will teach you how to train your own AI model for your specific application and then deploy it easily to the Grove - Vision AI Module. Let's get started! |
Project Section
In addition to the above basic tutorials for each platform, we have prepared a variety of rich examples on the use of this kit, so you can see here that the value of the kit is unlimited!
| IoT Into the Wild Contest for Sustainable Planet 2022 | Vision AI with Customizable Models |
| We are pleased to share with you the projects that our entrants have produced using this great kit. You can also refer to their projects for even more possibilities! | In this wiki, we will show you how to unitize the Wio Terminal to link Grove - Wio-E5 and Grove - Soil Moisture Sensor which are in the kit, connecting them with Helium and Azure IoT Central platforms, to build a real-time backyard potting monitor and watering-reminder, for a glimpse of Internet of Things. |
✨ Contributor Project
- We have a task list for updating this page, which is categorized under our contributor project, as we are dedicated to enhancing the user experience and providing better support through the development of our wiki platform.
- Your contribution to this page is essential to us! We really value your input and would greatly appreciate your assistance in generating ideas.
SenseCAP Tech Support
