SenseCAP Sensor Probes Product Catalogue
About SenseCAP
Among the first launch of Seeed IIoT product series, SenseCAP is focusing on wireless environmental sensing applications: smart agriculture, precision farming, and smart city, to name a few. It consists of hardware products (sensors, data-loggers & gateways, etc.), software services (SenseCAP Mate App, SenseCAP Web Portal, open dashboard), and API for device & data management.
About Sensor Probes
Our range of SenseCAP industrial sensor probes are designed to withstand harsh environments such as vibration and exposure to chemicals and gases, which is common in industrial applications, and our industrial range of sensors is equipped with serious IP ratings from IP66 to IP68 to ensure the products perform soundly in respective harsh environments. SenseCAP Sensor Probes also feature process connections to ensure a secure fit in the medium being measured, along with sensor data transmitters which convert the signal to suit industrial instrumentation systems. Some of the MODBUS RS485 Industrial Sensors come in two versions. The main difference is the cable connector. Please choose the version that best suits your needs: (1) The one with hook-up wires is suggested to use with SenseCAP LoRaWAN® Data Logger to connect with the LoRaWAN® network, enjoying the benefits of low-power and long-range communication. (2)The one with aviation connector already preconfigured SenseCAP Sensor Hub 4G Data Logger with plug-and-play experience to collect various sensor data via 3G/4G LTE.
Applications
Architecture
Industrial-Grade MODBUS RS485 NH3 Sensor - with Waterproof Aviation Connector
SKU 101990862
[1] The time from when the sensor is powered on to when the data is read. Note the parameter when the sensor is powered on.
[2] If started in an environment with clean air it requires less time
[3] The measurement data update interval, after the power-up warm-up time, if the power supply continues, the sensor periodically updates the reading at this interval.
[4] T90<30s
Industrial-grade MODBUS RS485 H2S Sensor - with Waterproof Aviation Connector
SKU 101990863
[4] T90<30s
SenseCAP CO2, Temperature and Humidity Sensor with RS485 & SDI-12 , with Waterproof Aviation Connector
SKU 101991029
[1] The preparation time required for the sensor to be powered on and ready to read measured values through Modbus instructions should be noted when the sensor is powered on and off for each reading.
[2] The warm-up time = (register 0x0021 value + 3); reading register 0x0000 before the warm-up time will result in 0, and the reading will be updated every second after the warm-up time; the sensor has a T90 time of 300 seconds and a T60 time of 120 seconds.
[3] The measurement data update interval, after the power-on warm-up time, if continuously powered, the sensor updates the reading periodically at this interval.
[4] Modbus master query frequency.
[5] The time required for the sensor to respond after receiving the read instruction, after the response delay register 0x0020 is set to 0.
Industrial MODBUS RS485 Air Temperature and Humidity Sensor
SKU 101990881
Industrial Soil Moisture & Temperature Sensor MODBUS-RTU RS485, 0-2V Analog Voltage (S-Soil MT-02A)
With Hook-up Wires 101990668
With Aviation Connector 314990620
Industrial Soil Moisture & Temperature & EC Sensor MODBUS-RTU RS485 (S-Soil MTEC-02A)
With Hook-up Wires 101990667
With Aviation Connector 314990621
Industrial Light Intensity Sensor, MODBUS-RTU RS485 &0-2V (S-Light-01)
With Hook-up Wires 314990739
With Aviation Connector 314990740
Industrial PAR Sensor (S-PAR-02A), MODBUS-RTU RS485
With Hook-up Wires 314990733
With Aviation Connector 314990735
Industrial PAR Sensor (PAR-2.5V), Supporting Analog 0~2.5V Output
SKU 314990734
Industrial Total Solar Radiation Sensor (S-ZFS-02A),MODBUS-RTU RS485
SKU 101991047
Industrial UV Radiation Sensor (S-ZW-01A), MODBUS-RTU RS485
SKU 101991048
Industrial Leaf Wetness &Temperature Sensor (A), MODBUS-RTU RS485
With Hook-up Wires 314990737
With Aviation Connector 314990738
Liquid Level Sensor for Water Level, Oil Level and Mild-corrosive Liquid Level Monitoring
SKU 314990619
Industrial Liquid Level Sensor MODBUS RS485 Aviation Connector
SKU 101990860
Industrial pH Sensor MODBUS-RTU RS485 & 0~2V Analog Voltage (S-pH-01A) V2.0
With Hook-up Wires 101990666
With Aviation Connector 314990622
Industrial EC & TDS Sensor MODBUS-RTU RS485 & 0-2V Analog Voltage
With Hook-up Wires 314990634
With Aviation Connector 314990742
RS485 MODBUS Dissolved Oxygen Sensor, Fluorescence DO Meter
SKU 314990633
RS485 MODBUS Turbidity Sensor(S-DTS210-01B)
SKU [101990793]
RS485 750cm Ultrasonic Level Sensor
SKU 101991041
RS485 500cm Ultrasonic Level Sensor
SKU 101991042
Industrial-Grade Optical Rain Gauge RG-15 Rain Sensor
SKU 114992321
Industrial-Grade Water Leak Detector IP66 RS485
SKU 314990618
Solar Radiation Shield for Outdoor Sensor Protection - A10
SKU 114992222
