Connecting SenseCAP T1000 to Helium
Device Configuration
Before connecting to Helium, you need to configure the basic parameters of your device on SenseCAP Mate APP, check Get Started for more details.
- Set the platform to
Helium, and then copy theDevice EUI/APP EUI/APP Key.
Helium Console Configuration
The Helium console is no longer open for new accounts. The description for how to connect a T1000 to the Helium Console remains here for users that already have an account. For new users, please refer to the ChirpStack LNA steps above or determine the necessary steps for your particular LNA based on the two existing examples here.
Add New Device
Log into your Helium console, then go to Devices section and click on Add device button.
Fill the required fields such as the device name**,** the LoRaWAN credentials, etc.
Then click the Save Device button.
Create the decoder function
The next step is to setup the function that will decode the raw bytes into a human readable form.
Head to Function tab on the panel at the left side. Then click the Add New Function button and give it a name:
Copy the following code and then save the changes.
Decoder for Helium
function Decoder (bytes, port) {
const bytesString = bytes2HexString(bytes)
const originMessage = bytesString.toLocaleUpperCase()
const fport = parseInt(port)
const decoded = {
valid: true,
err: 0,
payload: bytesString,
messages: []
if (fport === 199 || fport === 192) {
decoded.messages.push({fport: fport, payload: bytesString})
return { data: decoded }
if (fport !== 5) {
decoded.valid = false
let measurement = messageAnalyzed(originMessage)
if (measurement.length === 0) {
for (let message of measurement) {
if (message.length === 0) {
continue
let elements = []
for (let element of message) {
if (element.errorCode) {
decoded.err = element.errorCode
decoded.errMessage = element.error
} else {
elements.push(element)
if (elements.length > 0) {
decoded.messages.push(elements)
// decoded.messages = measurement
function messageAnalyzed (messageValue) {
try {
let frames = unpack(messageValue)
let measurementResultArray = []
for (let i = 0; i < frames.length; i++) {
let item = frames[i]
let dataId = item.dataId
let dataValue = item.dataValue
let measurementArray = deserialize(dataId, dataValue)
measurementResultArray.push(measurementArray)
return measurementResultArray
} catch (e) {
return e.toString()
function unpack (messageValue) {
let frameArray = []
for (let i = 0; i < messageValue.length; i++) {
let remainMessage = messageValue
let dataId = remainMessage.substring(0, 2).toUpperCase()
let dataValue
let dataObj = {}
let packageLen
switch (dataId) {
case '01':
packageLen = 94
if (remainMessage.length < packageLen) {
return frameArray
dataValue = remainMessage.substring(2, packageLen)
messageValue = remainMessage.substring(packageLen)
dataObj = {
'dataId': dataId, 'dataValue': dataValue
break
case '02':
packageLen = 32
return frameArray
dataObj = {
break
case '03':
packageLen = 64
return frameArray
dataObj = {
break
case '04':
packageLen = 20
return frameArray
dataObj = {
break
case '05':
packageLen = 10
return frameArray
dataObj = {
break
case '06':
packageLen = 44
return frameArray
dataObj = {
break
case '07':
packageLen = 84
return frameArray
dataObj = {
break
case '08':
packageLen = 70
return frameArray
dataObj = {
break
case '09':
packageLen = 36
return frameArray
dataObj = {
break
case '0A':
packageLen = 76
return frameArray
dataObj = {
break
case '0B':
packageLen = 62
return frameArray
dataObj = {
break
case '0C':
packageLen = 2
return frameArray
break
case '0D':
packageLen = 10
return frameArray
dataObj = {
break
case '0E':
packageLen = getInt(remainMessage.substring(8, 10)) * 2 + 10
return frameArray
dataValue = remainMessage.substring(2, 8) + remainMessage.substring(10, packageLen)
dataObj = {
break
case '0F':
packageLen = 34
return frameArray
dataObj = {
break
case '10':
packageLen = 26
return frameArray
dataObj = {
break
case '11':
packageLen = 28
return frameArray
dataObj = {
break
default:
return frameArray
if (dataValue.length < 2) {
break
frameArray.push(dataObj)
return frameArray
function deserialize (dataId, dataValue) {
let measurementArray = []
let eventList = []
let measurement = {}
let collectTime = 0
let groupId = 0
let shardFlag = {}
let payload = ''
let result = []
let dataArr = []
switch (dataId) {
case '01':
measurementArray = getUpShortInfo(dataValue)
measurementArray.push(...getMotionSetting(dataValue.substring(30, 40)))
measurementArray.push(...getStaticSetting(dataValue.substring(40, 46)))
measurementArray.push(...getShockSetting(dataValue.substring(46, 52)))
measurementArray.push(...getTempSetting(dataValue.substring(52, 72)))
measurementArray.push(...getLightSetting(dataValue.substring(72, 92)))
break
case '02':
break
case '03':
measurementArray.push(...getMotionSetting(dataValue.substring(0, 10)))
measurementArray.push(...getStaticSetting(dataValue.substring(10, 16)))
measurementArray.push(...getShockSetting(dataValue.substring(16, 22)))
measurementArray.push(...getTempSetting(dataValue.substring(22, 42)))
measurementArray.push(...getLightSetting(dataValue.substring(42, 62)))
break
case '04':
let interval = 0
let workMode = getInt(dataValue.substring(0, 2))
let heartbeatInterval = getMinsByMin(dataValue.substring(4, 8))
let periodicInterval = getMinsByMin(dataValue.substring(8, 12))
let eventInterval = getMinsByMin(dataValue.substring(12, 16))
switch (workMode) {
case 0:
interval = heartbeatInterval
break
case 1:
interval = periodicInterval
break
case 2:
interval = eventInterval
break
{measurementId: '3940', type: 'Work Mode', measurementValue: workMode},
{measurementId: '3942', type: 'Heartbeat Interval', measurementValue: heartbeatInterval},
{measurementId: '3943', type: 'Periodic Interval', measurementValue: periodicInterval},
{measurementId: '3944', type: 'Event Interval', measurementValue: eventInterval},
{measurementId: '3941', type: 'SOS Mode', measurementValue: getSOSMode(dataValue.substring(16, 18))},
{measurementId: '3900', type: 'Uplink Interval', measurementValue: interval}
break;
case '05':
{measurementId: '3000', type: 'Battery', measurementValue: getBattery(dataValue.substring(0, 2))},
{measurementId: '3940', type: 'Work Mode', measurementValue: getWorkingMode(dataValue.substring(2, 4))},
{measurementId: '3965', type: 'Positioning Strategy', measurementValue: getPositioningStrategy(dataValue.substring(4, 6))},
{measurementId: '3941', type: 'SOS Mode', measurementValue: getSOSMode(dataValue.substring(6, 8))}
break
case '06':
collectTime = getUTCTimestamp(dataValue.substring(8, 16))
{measurementId: '4200', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Event Status', measurementValue: getEventStatus(dataValue.substring(0, 6))},
{measurementId: '4197', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Longitude', measurementValue: parseFloat(getSensorValue(dataValue.substring(16, 24), 1000000))},
{measurementId: '4198', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Latitude', measurementValue: parseFloat(getSensorValue(dataValue.substring(24, 32), 1000000))},
{measurementId: '4097', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Air Temperature', measurementValue: getSensorValue(dataValue.substring(32, 36), 10)},
{measurementId: '4199', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Light', measurementValue: getSensorValue(dataValue.substring(36, 40))},
{measurementId: '3000', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Battery', measurementValue: getBattery(dataValue.substring(40, 42))}
break
case '07':
eventList = getEventStatus(dataValue.substring(0, 6))
{measurementId: '5001', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Wi-Fi Scan', measurementValue: getMacAndRssiObj(dataValue.substring(16, 72))},
{measurementId: '4097', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Air Temperature', measurementValue: getSensorValue(dataValue.substring(72, 76), 10)},
{measurementId: '4199', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Light', measurementValue: getSensorValue(dataValue.substring(76, 80))},
{measurementId: '3000', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Battery', measurementValue: getBattery(dataValue.substring(80, 82))}
break
case '08':
{measurementId: '5002', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'BLE Scan', measurementValue: getMacAndRssiObj(dataValue.substring(16, 58))},
{measurementId: '4097', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Air Temperature', measurementValue: getSensorValue(dataValue.substring(58, 62), 10)},
{measurementId: '4199', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Light', measurementValue: getSensorValue(dataValue.substring(62, 66))},
{measurementId: '3000', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Battery', measurementValue: getBattery(dataValue.substring(66, 68))}
break
case '09':
{measurementId: '3000', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Battery', measurementValue: getBattery(dataValue.substring(32, 34))}
break
case '0A':
{measurementId: '3000', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Battery', measurementValue: getBattery(dataValue.substring(72, 74))}
break
case '0B':
{measurementId: '3000', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Battery', measurementValue: getBattery(dataValue.substring(58, 60))},
break
case '0D':
let errorCode = getInt(dataValue)
let error = ''
switch (errorCode) {
case 1:
error = 'FAILED TO OBTAIN THE UTC TIMESTAMP'
break
case 2:
error = 'ALMANAC TOO OLD'
break
case 3:
error = 'DOPPLER ERROR'
break
measurementArray.push({errorCode, error})
break
case '0E':
shardFlag = getShardFlag(dataValue.substring(0, 2))
groupId = getInt(dataValue.substring(2, 6))
payload = dataValue.substring(6)
measurement = {
measurementId: '6152',
groupId: groupId,
index: shardFlag.index,
count: shardFlag.count,
type: 'gnss-ng payload',
measurementValue: payload
measurementArray.push(measurement)
break
case '0F':
shardFlag = getShardFlag(dataValue.substring(26, 28))
groupId = getInt(dataValue.substring(28, 32))
groupId: groupId,
groupId: groupId,
measurementValue: '' + getSensorValue(dataValue.substring(16, 20), 10)
groupId: groupId,
type: 'Light',
measurementValue: '' + getSensorValue(dataValue.substring(20, 24))
groupId: groupId,
type: 'Battery',
measurementValue: '' + getBattery(dataValue.substring(24, 26))
break
case '10':
shardFlag = getShardFlag(dataValue.substring(18, 20))
groupId = getInt(dataValue.substring(20, 24))
groupId: groupId,
groupId: groupId,
type: 'Battery',
measurementValue: '' + getBattery(dataValue.substring(16, 18))
break
case '11':
measurementId: '3576',
type: 'Positioning Status',
measurementValue: getPositingStatus(dataValue.substring(0, 2))
measurementValue: getEventStatus(dataValue.substring(2, 8))
if (!isNaN(parseFloat(getSensorValue(dataValue.substring(16, 20), 10)))) {
if (!isNaN(parseFloat(getSensorValue(dataValue.substring(20, 24))))) {
type: 'Light',
type: 'Battery',
break
return measurementArray
function getMotionId (str) {
return getInt(str)
function getPositingStatus (str) {
let status = getInt(str)
switch (status) {
case 0:
return {id:status, statusName:"Positioning successful."}
case 1:
return {id:status, statusName:"The GNSS scan timed out and failed to obtain the location."}
case 2:
return {id:status, statusName:"The Wi-Fi scan timed out and failed to obtain the location."}
case 3:
return {id:status, statusName:"The Wi-Fi + GNSS scan timed out and failed to obtain the location."}
case 4:
return {id:status, statusName:"The GNSS + Wi-Fi scan timed out and failed to obtain the location."}
case 5:
return {id:status, statusName:"The Bluetooth scan timed out and failed to obtain the location."}
case 6:
return {id:status, statusName:"The Bluetooth + Wi-Fi scan timed out and failed to obtain the location."}
case 7:
return {id:status, statusName:"The Bluetooth + GNSS scan timed out and failed to obtain the location."}
case 8:
return {id:status, statusName:"The Bluetooth + Wi-Fi + GNSS scan timed out and failed to obtain the location."}
case 9:
return {id:status, statusName:"Location Server failed to parse the GNSS location."}
case 10:
return {id:status, statusName:"Location Server failed to parse the Wi-Fi location."}
case 11:
return {id:status, statusName:"Location Server failed to parse the Bluetooth location."}
case 12:
return {id:status, statusName:"Failed to parse the GNSS location due to the poor accuracy."}
case 13:
return {id:status, statusName:"Time synchronization failed."}
case 14:
return {id:status, statusName:"Failed to obtain location due to the old Almanac."}
return getInt(str)
function getUpShortInfo (messageValue) {
return [
measurementId: '3000', type: 'Battery', measurementValue: getBattery(messageValue.substring(0, 2))
measurementId: '3502', type: 'Firmware Version', measurementValue: getSoftVersion(messageValue.substring(2, 6))
measurementId: '3001', type: 'Hardware Version', measurementValue: getHardVersion(messageValue.substring(6, 10))
measurementId: '3940', type: 'Work Mode', measurementValue: getWorkingMode(messageValue.substring(10, 12))
measurementId: '3965', type: 'Positioning Strategy', measurementValue: getPositioningStrategy(messageValue.substring(12, 14))
measurementId: '3942', type: 'Heartbeat Interval', measurementValue: getMinsByMin(messageValue.substring(14, 18))
measurementId: '3943', type: 'Periodic Interval', measurementValue: getMinsByMin(messageValue.substring(18, 22))
measurementId: '3944', type: 'Event Interval', measurementValue: getMinsByMin(messageValue.substring(22, 26))
measurementId: '3945', type: 'Sensor Enable', measurementValue: getInt(messageValue.substring(26, 28))
measurementId: '3941', type: 'SOS Mode', measurementValue: getSOSMode(messageValue.substring(28, 30))
function getMotionSetting (str) {
return [
{measurementId: '3946', type: 'Motion Enable', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3947', type: 'Any Motion Threshold', measurementValue: getSensorValue(str.substring(2, 6), 1)},
{measurementId: '3948', type: 'Motion Start Interval', measurementValue: getMinsByMin(str.substring(6, 10))},
function getStaticSetting (str) {
return [
{measurementId: '3949', type: 'Static Enable', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3950', type: 'Device Static Timeout', measurementValue: getMinsByMin(str.substring(2, 6))}
function getShockSetting (str) {
return [
{measurementId: '3951', type: 'Shock Enable', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3952', type: 'Shock Threshold', measurementValue: getInt(str.substring(2, 6))}
function getTempSetting (str) {
return [
{measurementId: '3953', type: 'Temp Enable', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3954', type: 'Event Temp Interval', measurementValue: getMinsByMin(str.substring(2, 6))},
{measurementId: '3955', type: 'Event Temp Sample Interval', measurementValue: getSecondsByInt(str.substring(6, 10))},
{measurementId: '3956', type: 'Temp ThMax', measurementValue: getSensorValue(str.substring(10, 14), 10)},
{measurementId: '3957', type: 'Temp ThMin', measurementValue: getSensorValue(str.substring(14, 18), 10)},
{measurementId: '3958', type: 'Temp Warning Type', measurementValue: getInt(str.substring(18, 20))}
function getLightSetting (str) {
return [
{measurementId: '3959', type: 'Light Enable', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3960', type: 'Event Light Interval', measurementValue: getMinsByMin(str.substring(2, 6))},
{measurementId: '3961', type: 'Event Light Sample Interval', measurementValue: getSecondsByInt(str.substring(6, 10))},
{measurementId: '3962', type: 'Light ThMax', measurementValue: getSensorValue(str.substring(10, 14), 10)},
{measurementId: '3963', type: 'Light ThMin', measurementValue: getSensorValue(str.substring(14, 18), 10)},
{measurementId: '3964', type: 'Light Warning Type', measurementValue: getInt(str.substring(18, 20))}
function getShardFlag (str) {
let bitStr = getByteArray(str)
return {
count: parseInt(bitStr.substring(0, 4), 2),
index: parseInt(bitStr.substring(4), 2)
function getBattery (batteryStr) {
return loraWANV2DataFormat(batteryStr)
function getSoftVersion (softVersion) {
return `${loraWANV2DataFormat(softVersion.substring(0, 2))}.${loraWANV2DataFormat(softVersion.substring(2, 4))}`
function getHardVersion (hardVersion) {
return `${loraWANV2DataFormat(hardVersion.substring(0, 2))}.${loraWANV2DataFormat(hardVersion.substring(2, 4))}`
function getSecondsByInt (str) {
return getInt(str)
function getMinsByMin (str) {
return getInt(str)
function getSensorValue (str, dig) {
if (str === '8000') {
return null
} else {
return loraWANV2DataFormat(str, dig)
function bytes2HexString (arrBytes) {
var str = ''
for (var i = 0; i < arrBytes.length; i++) {
var tmp
var num = arrBytes[i]
if (num < 0) {
tmp = (255 + num + 1).toString(16)
} else {
tmp = num.toString(16)
if (tmp.length === 1) {
tmp = '0' + tmp
str += tmp
return str
function loraWANV2DataFormat (str, divisor = 1) {
let strReverse = bigEndianTransform(str)
let str2 = toBinary(strReverse)
if (str2.substring(0, 1) === '1') {
let arr = str2.split('')
let reverseArr = arr.map((item) => {
if (parseInt(item) === 1) {
return 0
} else {
return 1
str2 = parseInt(reverseArr.join(''), 2) + 1
return '-' + str2 / divisor
return parseInt(str2, 2) / divisor
function bigEndianTransform (data) {
let dataArray = []
for (let i = 0; i < data.length; i += 2) {
dataArray.push(data.substring(i, i + 2))
return dataArray
function toBinary (arr) {
let binaryData = arr.map((item) => {
let data = parseInt(item, 16)
.toString(2)
let dataLength = data.length
if (data.length !== 8) {
for (let i = 0; i < 8 - dataLength; i++) {
data = `0` + data
return data
return binaryData.toString().replace(/,/g, '')
function getSOSMode (str) {
return loraWANV2DataFormat(str)
function getMacAndRssiObj (pair) {
let pairs = []
if (pair.length % 14 === 0) {
for (let i = 0; i < pair.length; i += 14) {
let mac = getMacAddress(pair.substring(i, i + 12))
if (mac) {
let rssi = getInt8RSSI(pair.substring(i + 12, i + 14))
pairs.push({mac: mac, rssi: rssi})
} else {
continue
return pairs
function getMacAddress (str) {
if (str.toLowerCase() === 'ffffffffffff') {
return null
let macArr = []
for (let i = 1; i < str.length; i++) {
if (i % 2 === 1) {
macArr.push(str.substring(i - 1, i + 1))
let mac = ''
for (let i = 0; i < macArr.length; i++) {
mac = mac + macArr[i]
if (i < macArr.length - 1) {
mac = mac + ':'
return mac
function getInt8RSSI (str) {
function getInt (str) {
return parseInt(str, 16)
function getEventStatus (str) {
// return getInt(str)
let bitArr = []
for (let i = 0; i < bitStr.length; i++) {
bitArr[i] = bitStr.substring(i, i + 1)
bitArr = bitArr.reverse()
let event = []
for (let i = 0; i < bitArr.length; i++) {
if (bitArr[i] !== '1') {
continue
switch (i){
case 0:
event.push({id:1, eventName:"Start moving event."})
break
case 1:
event.push({id:2, eventName:"End movement event."})
break
case 2:
event.push({id:3, eventName:"Motionless event."})
break
case 3:
event.push({id:4, eventName:"Shock event."})
break
case 4:
event.push({id:5, eventName:"Temperature event."})
break
case 5:
event.push({id:6, eventName:"Light event."})
break
case 6:
event.push({id:7, eventName:"SOS event."})
break
case 7:
event.push({id:8, eventName:"Press once event."})
break
return event
function getByteArray (str) {
let bytes = []
for (let i = 0; i < str.length; i += 2) {
bytes.push(str.substring(i, i + 2))
return toBinary(bytes)
function getWorkingMode (workingMode) {
return getInt(workingMode)
function getPositioningStrategy (strategy) {
return getInt(strategy)
function getUTCTimestamp(str){
return parseInt(loraWANV2PositiveDataFormat(str)) * 1000
function loraWANV2PositiveDataFormat (str, divisor = 1) {
Check the data
When the device tries to connect to the network, the breathing light will flash. If the device joins the network successfully, the breathing light will flash quickly, and there will be a light and cheerful melody.
Then you can check the data on the Helium console.
Note
For users operating with the EU868/RU864 region:
It is not recommended to set the upload interval to less than 4 minutes.
If you set an upload interval of less than 4 minutes, you may notice a timestamp misalignment between the device's uplink and the current time.
Here's the rationale:
Given the 1% duty cycle constraint in EU868, the device must patiently wait approximately 4 minutes for each uplink transmission. Additionally, the Helium network initiates data-rate and power corrections only after accumulating 20 consecutive uplink packets marked with the ADR bit set to 1.
So if the upload interval you set is less than 4 minutes, real-time data will be temporarily stored in RAM and held until the Helium network triggers data rate and power corrections before uploading.
ChirpStack LNS
For new users, to receive the data from a device on the Helium network it must be associated with an LNS (LoraWAN Network Server), typically use one of the public LNSs, many of which use ChirpStack, but it's also possible to connect one's own LNS to Helium.
For those familiar with the general process the TL;DR; is:
- create an device profile with the appropriate region and the codec (see source below)
- create device with
devEUI,appKey, and aapp_euivariable with the AppEUI, all three values coming from theSenseCraftApp
Add device profile
The first step is to add a device profile for the T1000 Tracker to your ChirpStack LNS. This tells the LNS how to decode the packets it receives from a T1000 as well as a number of other settings.
In the ChirpStack dashboard select the Device Profiles and click Add device profile.
On the general tab, enter a device profile name you will recognize and select the appropriate region parameters.
LoRaWAN MAC version: 1.0.4
The expected uplink interval can be set too, the main thing it controls is when the LNS user interface shows the device as active vs. inactive. It has no effect on the delivery of packets through the LNS.
On the Codec tab select JavaScript functions and enter the codec:
There are 2 versions of ChirpStack, select the appropriate one:
Add Application and your Device
The next step is to create an application and add actual devices to it.
Go to the Applications section and add a new application.
Then add a device to the application and enter the devEUI as captured in the SenseCraft App earlier.
On the variables tab add a variable called app_eui with the AppEUI from the SenseCraft app as value:
Hitting submit will bring up a page asking for the AppKey, again as captured earlier using the SenseCraft app:
View the device connection
On the LoRaWAN frames tab you will see a spinner and then packets show up as they are received/sent.
Press the button of your T1000 Tracker to cause it to take a measurement and send a join request to connect with the LNS.
Once this happens, you should see something like this:
Once the join process has been performed the T1000 sends data. The LNS responds back with some information about the network frequencies and such, but subsequent to that there should only be uplinks with data.
