TagoIO Integrated(via TTS)
TagoIO is an IoT Cloud Platform for businesses to manage devices, data, users, analytics, and integration. Its intuitive interface makes it easy for businesses of all sizes to build and deploy innovative IoT solutions.
The content of this chapter will guide users how to connect the SenseCAP T1000 Tracker to TagoIO through TTN.
Before starting the setup, please check Connect SenseCAP T1000 to TTS to connect your SenseCAP T1000 Tracker to TTS first.
Configura the TagoIO
To get started, create an account with TagoIO.
Add Device
Navigate to Devices tab and click Add Device.
Search Seeed SenseCAP T1000 for quick setup.
Name your device and paste your device EUI, then click Create my Device.
Generate authorization
Click Generate authorization and copy your authorization.
Configura The Things Stack
On The Things Stack, navigate to Integrations → Webhooks, and click Add Webhook.
Choose the TaoIO Webhook template.
Name your integration by filling in the Webhook ID, and paste the Plugin ID and TagoIO token.
After your device is connected, you can check all the connections in the Live Inspector tab in TagoIO.
TagoIO Dashboard(Optional)
A dashboard is where you place your widgets to visualize and interact with data, all in real-time. You can customize your dashboard to your needs.
Navigate to Dashboard tab, name your dashboard and click Create my Dashboard.
Location Dashboard
Click Add widget, choose Map type.
Data from: Your device -- location
