Wialon Integrated
Wialon is the fleet management software platform for GPS monitoring and IoT which tracks over 3,7 million mobile and stationary units in 150+ countries of the world and consists of more than 2,500 partner companies, 700 hardware manufacturers, hundreds of Wialon-based solution developers.
The content of this chapter will guide users how to connect the SenseCAP T1000 Tracker to Wialon platform.
Before starting the setup, please check Get Started to connect your SenseCAP T1000 Tracker to SenseCAP Cloud first.
Get SenseCAP API on SenseCAP Portal
Log into SenseCAP Portal, navigate to Access API keys, click Create Access Key.
Then you will get the API ID and Access API keys.
Wialon Configuration
Log into Wialon Hosting.
Wialon Hosting is a platform for GPS monitoring and IoT which is stored and administered in our data centers.
Add Unit
Navigate to Units tab and click New to add a new unit.
Name your unit, and select the Device Type to SenseCAP API, click the wrench icon to fill in the properties.
API host:sensecap.seeed.cc
API ID: The API ID in SenseCAP Portal
API Password: The Access API keys in SenseCAP Portal
Unique ID: The EUI of your device.
Keep your device online, then you can see the location on the map.
Geofence(optional)
Geofence is a limited area on the map that can be used for monitoring purposes.
Navigate to Geofences tab and click New to add a new geofence.
- Indicate the geofence name.
- Select the type.
- Mark the center of the geofence on the map (double-click on the required place).
- Indicate the geofence radius.
- Click
Save.
