Skeleton box for BeagleBone®
This enclosure is constructed from military grade aluminum and hardwearing acrylic, Providing the ultimate protection from physical and corrosion! The skeleton box allows clearance for any standard Arduino, and the enclosures are stackable in all three dimensions, allowing for limitless expansion possibilities. The skeleton is easy to use, and provides the best protection for your Arduino that money can buy! And this is a simply case, specially designed for BeagleBone®.
Feature
Neat and universal
Easy to assemble
Solid and stable material
Usage
Assembly diagram is as follows:
| Part | Package | Qty |
| Bracket | 1.5mm aluminum plate stamping molding, black sand anodized | 2 |
| Beagle Bottom Cover | 2.5mm Thickness | 1 |
| Beagle Top Cover | 2.5mm Thickness | 1 |
| Rivet(black) | R2056 | 20 |
| Screw | M3X5 | 4 |
| Nylon screw pillor | M3X5X6 | 4 |
| Nylon Nut | M3X2.5 | 4 |
