Arduino Software SPI User Guide
Similarly to I2C and Serial communications, SPI can be virtualized using software to overcome the physical limitations. Here provides an example of using software SPI with Arduino.
What is SPI
Serial Peripheral Interface (SPI) is a synchronous serial data protocol used by microcontrollers for communicating with one or more peripheral devices quickly over short distances. It can also be used for communication between two microcontrollers.
Software SPI Example
Visit the SoftSPI repositories and download the entire repo to your local drive.
Now, the SoftSPI library can be installed to the Arduino IDE. Open the Arduino IDE, and click
sketch->Include Library->Add .ZIP Library, and choose theSoftSPIfile that you've have just downloaded.
#include <SPI.h>
#include <SoftSPI.h>
// Create a new SPI port with:
// Pin 2 = MOSI,
// Pin 3 = MISO,
// Pin 4 = SCK
SoftSPI mySPI(2, 3, 4);
mySPI.begin();
Serial.begin(9600);
static uint8_t v = 0;
Serial.print("Sending value: ");
Serial.print(v, HEX);
uint8_t in = mySPI.transfer(v);
Serial.print(" Got value: ");
Serial.print(in, HEX);
Serial.println(v == in ? " PASS" : " FAIL");
v++;
