UartSB Frame
UartSB Frame is a USB based programming adapter for Seeeduino Film equipped with a FPC socket. The integrated USB UART IC FT232RL can be used for programming or communicating with MCUs with 3.3V logic. It also doubles as a "FT232RL" Low Voltage(3.3V) Breakout board. UartSB Frame provides breakouts for the bit-bang mode pins of FT232RL as well.This Bit-bang mode pins (8 I/O pins) can be used as a replacement for applications involving PC parallel port which is scares now a days.
Model:PGM31058P
- USB 2.0 compatible Serial Interface.
- 20 Pin FPC connector for attaching Seeeduino Film
- 3.3V compatible I/Os.
- 3.3V and 5V dual power outputs.
- Bit-Bang mode ready (8 Serial I/Os or as SPI).
- LEDs for TxD,Rxd and Power.
Applications Ideas
- Programmer for Seeeduino Film and 3.3V compatible boards.
- USB to Serial adapter for communicating with 3.3V level Serial devices.
- Programmer for micro-controllers / CPLDs using ISP(in-circuit-serial-programming).
- 3.3V / 5V power source for a breadboard MCU applications.
- The 5V supply can be used to charge the Seeeduino Film battery. (Do not use FPC connection for this application)
- Endless possibilities as a USB based parallel device in FT232RL bit-bang mode - Known to work as AVR-ISP, Slowspeed JTAG with OpenOCD and as I2C
Cautions
Connect UartSB Frame to Seeeduino Film only as shown in Seeeduino Film Programmer "UartSB_Frame#Seeeduino_Film_Programmer") section.
Do not use FFC (Flexible Flat Cable) to directly connect UartSB Frame to Seeeduino Film. This would reverse the 20 pin FPC connection.
Handle the 20 pin FPC connector with care.
Use UartSB Frame only with 3.3v I/Os.
Schematic
Specifications
Key Specifications
| Microprocessor | FT232RL |
| PCB size | 35mm x 20mm |
| Indicators | POWER - Green LED, RX and TX - Red LEDs |
| Power supply | 3.3V and 5V DC |
| Interface | Mini-B USB, 2.54mm pitch pin header |
| Seeeduino Programming Port | 20 Pin FPC socket |
| Connectivity | USB |
| Communication Protocol | UART, Bit Bang I/O, SPI |
Electrical Characterstics
| Specification | Minimum | Typical | Maximum | Unit |
| Input voltage | - | 5 | 5 | Vdc |
| Current Consumption | - | - | 500 | mA |
| Output voltage | 3.3 | - | 5 | Vdc |
Pin definition and Rating
| Pad Name | Description |
| GND | Ground pin |
| 3v3 | 3.3V Power Supply |
| 5V | 5V Power supply from USB Port |
| RXD | UART Data input |
| TXD | UART Data output |
| CTS | UART Clear to Send Signal |
| RTS | UART Request to Send Signal |
| DTR | UART Data Terminal Ready Signal |
| DCD | UART Data Carrier Detect Signal |
| DSR | UART Data Set Ready Signal |
Usage
UartSB Frame is designed exclusively for flashing Seeeduino Film. It works as a USB to Serial Port (COM port) interface when connected to PC. This kind of configuration can be used to communicate with a MCU serial port.Also useful to program a MCU which support UART based ISP.
If the FT232RL drivers were not installed, follow the procedure in next section(configuring UartSB Frame).
Connect the Seeeduino Film to UartSB Frame as shown below :
- Set the board type to Arduino Pro or Pro Mini (3.3V, 8MHz) w/ATMega168 in Arduino IDE
- Upload the sketch.
Configuring UartSB Frame in Windows
- In Windows OS, the first time you plug in the device, you might be asked for the driver.
Download and install the Virtual COM port driver from FTDI website :
https://www.ftdichip.com/Drivers/VCP.htm
- A wizard opens for installing the driver. Choose "Install from a list or specific location"
- Choose the downloaded driver path
- If you have downloaded unsigned driver, the following Window appears. Just click "Continue Anyway"
- UartSB Frame driver is successfully installed. Windows assigns a COM port name to FT232RL like COM10, COM11 etc... Please check the exact name in Device Manager. In this case "COM16" is assigned for UartSB Frame
Configuring UartSB Frame in GNU/Linux
All modern GNU/Linux OS comes with FT232RL drivers. To check if UartSB Frame is detected, Issue a lsusb command. An output similar to below should appear.
GNU/Linux assigns /dev/ttyUSB0, /dev/ttyUSB1 etc... as device name.
To verify the working of serial port connect TxD and RxD pins of UartSB Frame and use a terminal application like cutecom to configure the device parameters as shown below.
Baudrate:9600, Data bits:8, Stop bits:None and no Handshake
Any character typed in terminal would be echoed back as shown.
The same functionality can be verified in Windows - Hyperterminal as well.
Battery Charger for Seeeduino Film
The USB 5v supply available in UartSB Frame breakout can be used to charge the battery of Seeeduino Film.
Solder the Seeeduino Film Power-Connector to 5V and GND of UartSB Frame.
Connect Power connector to CHG jack.
Connect the Battery to Seeeduino Film BAT jack.
Power on the USB.
BitBang Mode
An nice feature of UartSB Frame compared to other FT232RL based USB-Serial devices is that all the Bit-Bang I/Os are brought to the header pins.
Bit-Bang mode is a special feature of FT232RL in which 8 I/O lines (D0 - D7) can be used as a general purpose bidirectional I/O lines. Three Bit-Bang modes are supported by FT232RL
- Asynchronous Bit-Bang mode
Any data written to the device is clocked to the configured output pins. The rate of data transfer is configured based on baud rate generator. In this mode any of 8 I/O lines can be configured as input or ouput.
- Synchronous Bit-Bang mode
In this mode data is sent synchronously. An input is read before an output byte is sent to the device. Hence to read input, a write operation must be performed.
- CBUS Bit-Bang Mode
This is a special mode which requires reprogramming of FT232RL EEPROM. This uses signals C0 - C3.
Bit-Bang Mode of FT232RL is well documented in the application note[1]
Table: Bit-Bang I/O Mapping
| UartSB Frame Signal | BitBang I/O Signal |
| TxD | D0 |
| RxD | D1 |
| RTS | D2 |
| CTS | D3 |
| DTR | D4 |
| DSR | D5 |
| DCD | D6 |
| RI | D7 |
BitBang Mode Operation:
A simple Asynchronous Bit-Bang mode operation is demonstrated in the below breadboard arrangement in which DTR (D4) pin is connected to an LED. The LED blinking rate is controlled by the PC side application program.
LED Blinky Circuit
This above image is made with Fritzing.org
Bit Bang I/O Pins (ISP header) shown at Bottom Layer
Bit-Bang mode requires special FTDI direct driver called D2XX. This driver needs to be installed after removing the Virtual COM Port driver of FT232RL chip. In GNU/Linux this driver runs in kernel mode. As an alternative to D2XX an Free Open Source driver libFTDI is available. This works in Windows, GNU/Linux and Mac OS. It runs in user mode in GNU/Linux. Hence no need to remove the existing FT232RL driver.
libFTDI
http://www.intra2net.com/en/developer/libftdi/
libUSB libFTDI required libusb which can be downloaded from
The below example code can be compiled in the similar way as that of libFTDI example files. An easy way is to copy the contents of the below code to one of the existing example .c file and build the whole driver using
./configure
make
Code Example
Blinky.C: UartSBee v3.1 (FT232RL) Bit-Bang mode - Blinky.
Circuit: Connect TXD to Anode of LED, Connect one end of resistor to GND and other end to Cathode of the LED
#ifdef __WIN32__
#define sleep(x) Sleep(x)
#endif
// 8 bit pin mask for I/O pin </span>
#define TXD 0x01
#define RXD 0x02
#define RTS 0x04
#define CTS 0x08
#define DTR 0x10
#define DSR 0x20
#define DCD 0x40
#define RI 0x80
#include <stdio.h>;
#include <ftdi.h>;
int main
unsigned char ouputState =0;
struct ftdi_context ftdic;
/* 1. Initialize ftdi device context */
ftdi_init(&ftdic);
/* 2. Open the device based of VID/PID pair */
if(ftdi_usb_open(&ftdic, 0x0403, 0x6001) <<span ;>0)
printf("Unable to open UartSBs Frame");
return1;}
/* 3. Enable Bit-Bang mode with for DTR line */
ftdi_set_bitmode(&ftdic, TXD, BITMODE_BITBANG);
/* 4. Blink LED every 1 second */
while(1)</span> <span class="br0">{
ouputState ^= TXD;
ftdi_write_data(&ftdic, &ouputState, 1);
sleep(1);
FT232RL Bit-Bang mode can be used to construct AVR ISP, JTAG, SPI and I2C Ports. Refer the external links.
Image Gallery
Please list your question here:
Support
If you have questions or other better design ideas, you can go to our forum or wish to discuss.
Document Version Tracker
| Revision | Description | Editor | Release Date |
| V0.9b | Detailed Application Notes | Visweswara R | 22 Feb 2010 |
Hardware Version Tracker
| Revision | Description | Release Date |
| UartSBs Frame | 0.9b | Feb 22, 2010 |
Bug Tracker
Bug Tracker is the place you can publish any bugs you think you might have found during use. Please write down what you have to say, your answers will help us improve our products.
Additional Idea
The Additional Idea is the place to write your project ideas about this product, or other usages you've found. Or you can write them on Projects page.
[PDF] PDF Schematic
How to buy
Click here to buy UartSB Frame
Licensing
This documentation is licensed under the Creative Commons Attribution-ShareAlike License 3.0. Source code and libraries are licensed under GPL/LGPL, see source code files for details.
External Links
[https://www.ftdichip.com/Drivers/VCP.htm FTDI Virtual COM Port (VCP) drivers
Open Source Drivers
Other Sources of FT232RL application information
