Weight Sensor (Load Cell)0-500g
Applicable to electronic scale, price computering scale, electronic platform scale, digital scale; parcel post scale, electronic balance and all varieties of commercial scales by single load cell.
capacity g 500g
Output sensitivity mv/v 0.5±0.1
Nonlinearty %.F.S 0.05
Hysteresis %F.S 0.05
Repeatability %F.S 0.05
Creep(30min) %.F.S 0.05
Temperature effect on sensitivity %F.S/10℃ 0.05
Temperature effect on zero %F.S/10℃ 0.05
Zero Balance %F.S ±0.5
Input resistance Ω(ohms) 1120±10
Output resistance Ω(ohms) 1000±10
Insulation resistance MΩ(ohms) ≥2000
Recommended excitation voltage v 5v
Method of Connecting wire red: Exc + black: Exc –
green: Sig + white:Sig -
Usage
Hardware install
Note: Weight sensor output 0V when the load less than 150g,so we can not directly measure the load .My method is using a 200g local avoid measure blind spot.Read the analog data of 200g weight as no-load(0g),read the analog data of 700g weight as full load(500g).
Programming
Serial.begin(9600);
int value;
value = analogRead(0);
Serial.println(value);
external link
Sourse
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
