WiFi Serial Transceiver Module
In this tutorial, we'll use a seeeduino to control the ESP8266 WiFi module to request a static page from the internet. This is a basic use of TCP socket, for other usage, please refer to the AT command guide of the module.
Material list:
- Seeeduino V3 / Arduino Uno
- ESP8266 Serial WiFi module
- UartSBee v4 / other USB to TTL converter
!!!Note We used a software serial to print some debugging information as there’s only one hardware serial on seeeduino board. But the limitation of software serial is that it can’t communicate in a higher baud rate than 19200. So part of the output from ESP module will be dropped because the baud rate 57600 of ESP module is higher than that of the software serial. If you have a board with more than one hardware serial (e.g. Arduino Mega 2560), the case will be easier.
Step-By-Step
- Step 1: connect module as the following picture
Step 2: Programe the seeeduino board.
- Open Arduino IDE and create a new sketch;
- Parse the following code into the sketch editor (need modifying the SSID and PASS macros into your own situation);
#include <SoftwareSerial.h>
#define SSID "xxxxxxxx"
#define PASS "xxxxxxxx"
#define DST_IP "220.181.111.85" //baidu.com
SoftwareSerial dbgSerial(10, 11); // RX, TX
// Open serial communications and wait for port to open:
Serial.begin(57600);
Serial.setTimeout(5000);
dbgSerial.begin(9600); //can't be faster than 19200 for softserial
dbgSerial.println("ESP8266 Demo");
//test if the module is ready
Serial.println("AT+RST");
if(Serial.find("ready"))
dbgSerial.println("Module is ready");
else
dbgSerial.println("Module have no response.");
while(1);
//connect to the wifi
boolean connected=false;
for(int i=0;i<5;i++)
if(connectWiFi())
connected = true;
break;
if (!connected){while(1);}
delay(5000);
//print the ip addr
/*Serial.println("AT+CIFSR");
dbgSerial.println("ip address:");
while (Serial.available())
dbgSerial.write(Serial.read());*/
//set the single connection mode
Serial.println("AT+CIPMUX=0");
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += DST_IP;
cmd += "\",80";
Serial.println(cmd);
dbgSerial.println(cmd);
if(Serial.find("Error")) return;
cmd = "GET / HTTP/1.0\r\n\r\n";
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
if(Serial.find(">"))
dbgSerial.print(">");
}else
Serial.println("AT+CIPCLOSE");
dbgSerial.println("connect timeout");
return;
Serial.print(cmd);
delay(2000);
//Serial.find("+IPD");
char c = Serial.read();
dbgSerial.write(c);
if(c=='\r') dbgSerial.print('\n');
dbgSerial.println("====");
boolean connectWiFi()
Serial.println("AT+CWMODE=1");
String cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
delay(2000);
if(Serial.find("OK"))
dbgSerial.println("OK, Connected to WiFi.");
return true;
}else
dbgSerial.println("Can not connect to the WiFi.");
return false;
- Step 3: Open Serial Monitor and press the reset button of seeeduino board, you’ll see the output.
At last, Happy Hakcing! :)
Related Projects
Recipe Community is an awesome place where makers share their amazing works here. Our makers have made a lot of awesome projects with esp8266, check this out!
WiFi Scanner -Know the WiFi Signal around you
Build your own Wifi Scanner with few simple steps, all you need to do is prepare:
- A NodeMcu Dev. Board
- An I2C OLED.
- Some cables
- And most importantly, a HOT HEART ON ESP8266
So, why not make one for yourself?
Primary IoT Make with NodeMcu >ESP8266<
An online Temperature&Humidity Monitor made with:
- Grove - Temp&Humi Sensor
- Some cables
Another easy trick, why not make one for yourself?
Na, not enough? More Awesome Projects with ESP8266.
Even more Awesome Projects On Recipe
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
