Connecting the Wio Terminal to Microsoft Azure IoT
This is a document written by @Benjamin Cabé. Thank you Benjamin for the great work! You may also find Benjamin's work here.
This sample application shows you how to connect your Wio Terminal to Azure IoT Hub. It is built on top of the Azure SDK for Embedded C, a small footprint, easy-to-port library for communicating with Azure services.
To connect with Microsoft Azure IoT with Wio Terminal, please see the Benjamin's Guide.
Connecting to MQTT Server
If you want to connect Wio Terminal to MQTT servers(such as Microsoft Azure IoT), you may also check Benjamin's Guide for MQTT on Wio Terminal!
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
