Reading/Writing from the SD Card
This repo describes how to Read/Write from or to the SD Card. With this, you are able to load data from the SD Card, a simple demonstration will be storing sensor reading to the SD Card.
Initializing the SD Card on Wio Terminal
Include theSeeed_FS
libraries as follow. And initializing the SD Card using: SD.begin(SDCARD_SS_PIN, SDCARD_SPI)
, where SPI is used to communicate in Wio Terminal for SD Card.
#include <SPI.h>
#include <Seeed_FS.h>
#include "SD/Seeed_SD.h"
File myFile; //Intialise the file Class and named it myFile
while (!Serial) {
Serial.print("Initializing SD card...");
if (!SD.begin(SDCARD_SS_PIN, SDCARD_SPI)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
Writing to the SD Card
To write in the SD Card, need to first open the file. There are different modes for the file system so need to state what mode to use while opening the file, modes are as follow:
FILE MODE | Name Defined |
WRITE | FILE_WRITE |
READ | FILE_READ |
APPEND | FILE_APPEND |
To open the file, the open
File Class member function is used and takes 2 parameters as follow:
open(const char *filepath, uint8_t mode = FILE_READ) //default mode is READ
In this case, open a txt file name test.txt
and FILE_WRITE
is used. To write inside a txt file can use println
function(File Class):
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE); //Writing Mode
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3."); //Writing this to the txt file
// close the file:
myFile.close();
Serial.println("done.");
} else {
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
Note: One file at the time, so close a file when done.
Reading from the SD Card
To read a file from SD Card, also needs to open the file. This time, using FILE_READ
mode to only read the file.
Using the File member function availble()
to check the availablity of the file and read()
to print out things inside the file .
myFile = SD.open("test.txt", FILE_READ); //Read Mode
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
} else {
Complete Code
#include <SPI.h>
File myFile;
while (!Serial) {
while (1);
if (myFile) {
// close the file:
myFile.close();
} else {
// re-open the file for reading:
if (myFile) {
// close the file:
myFile.close();
} else {
// nothing happens after setup
Reading/Writing the Flash using QSPI
As the FS library has updated and we have introduced SFUD into the systems. You can now access the the Flash on the Wio Terminal using QSPI.
Full Example Code
This example demonstrates Read/Erase/Write:
#include <sfud.h>
#define SFUD_DEMO_TEST_BUFFER_SIZE 1024
static uint8_t sfud_demo_test_buf[SFUD_DEMO_TEST_BUFFER_SIZE];
static void sfud_demo(uint32_t addr, size_t size, uint8_t *data);
#define SERIAL Serial
SERIAL.begin(115200);
while(!SERIAL) {};
while(!(sfud_init() == SFUD_SUCCESS));
#ifdef SFUD_USING_QSPI
sfud_qspi_fast_read_enable(sfud_get_device(SFUD_W25Q32_DEVICE_INDEX), 2);
#endif
sfud_demo(0, sizeof(sfud_demo_test_buf), sfud_demo_test_buf);
* SFUD demo for the first flash device test.
* @param addr flash start address
* @param size test flash size
* @param size test flash data buffer
static void sfud_demo(uint32_t addr, size_t size, uint8_t *data) {
sfud_err result = SFUD_SUCCESS;
const sfud_flash *flash = sfud_get_device_table() + 0;
size_t i;
/* prepare write data */
for (i = 0; i < size; i++) {
data[i] = i;
/* erase test */
result = sfud_erase(flash, addr, size);
if (result == SFUD_SUCCESS) {
SERIAL.println("Erase the flash data finish");
} else {
SERIAL.println("Erase flash data failed");
return;
/* write test */
result = sfud_write(flash, addr, size, data);
SERIAL.println("Write the flash data finish");
} else {
SERIAL.println("Write the flash data failed");
return;
/* read test */
size_t BaseTime = micros();
result = sfud_read(flash, addr, size, data);
size_t CostTime = micros() - BaseTime;
SERIAL.println("Read the flash data success.");
SERIAL.println("Offset (h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F\r\n");
if (i % 16 == 0) {
SERIAL.print("0x");
SERIAL.print(addr + i,HEX);
SERIAL.print("\t");
SERIAL.print(data[i],HEX);
SERIAL.print("\t");
if (((i + 1) % 16 == 0) || i == size - 1) {
SERIAL.println("");
SERIAL.println(" ");
} else {
SERIAL.println("Read the flash data failed.");
/* data check */
if (data[i] != i % 256) {
SERIAL.println("Read and check write data has an error.");
break;
if (i == size) {
SERIAL.println("The flash test is success.\r\n");
SERIAL.print("read costTime: ");
SERIAL.print(CostTime);
SERIAL.println(" us");
