Grove Port
This repo introduces how to use Wio Terminal with the Grove Ecosystem.
With the help of Grove, you are able prototype much quicker with simpler connections!
Wio Terminal With Grove - TDS Sensor
This section introduces how to use Grove - TDS Sensor with Wio Terminal to display real time TDS readings on a line chart!
Libraries Installation
Complete Code
Connect the Grove TDS sensor to the Grove D/A Pin of Wio Terminal, upload the code and check the results!
#include"seeed_line_chart.h" //include the library
TFT_eSPI tft;
#define max_size 50 //maximum size of data
doubles data; //Initilising a doubles type to store data
TFT_eSprite spr = TFT_eSprite(&tft); // Sprite
#define sensorPin A0 //Analog pin
int sensorValue = 0;
float tdsValue = 0;
float Voltage = 0;
pinMode(sensorPin, INPUT);
tft.begin();
tft.setRotation(3);
spr.createSprite(TFT_HEIGHT,TFT_WIDTH);
spr.fillSprite(TFT_WHITE);
sensorValue = analogRead(sensorPin);
Voltage = sensorValue*5/1024.0; //Convert analog reading to Voltage
tdsValue=(133.42*Voltage*Voltage*Voltage - 255.86*Voltage*Voltage + 857.39*Voltage)*0.5; //Convert voltage value to TDS value
if (data.size() == max_size) {
data.pop();//this is used to remove the first read variable
data.push(tdsValue); //read variables and store in data
//Settings for the line graph title
auto header = text(0, 0)
.value("TDS Reading")
.align(center)
.valign(vcenter)
.width(tft.width())
.thickness(3);
header.height(header.font_height() * 2);
header.draw(); //Header height is the twice the height of the font
auto content = line_chart(20, header.height()); //(x,y) where the line graph begins
content
.height(tft.height() - header.height() * 1.5) //actual height of the line chart
.width(tft.width() - content.x() * 2) //actual width of the line chart
.based_on(0.0) //Starting point of y-axis, must be a float
.show_circle(true) //drawing a cirle at each point, default is on.
.value(data) //passing through the data to line graph
.color(TFT_RED) //Setting the color for the line
.draw();
spr.pushSprite(0, 0);
delay(50);
Wio Terminal With Grove - OLED Display
If you required a second screen to display with Wio Terminal, Grove - OLED Dispaly 0.96" will be the perfect choice. It can be used to display graphics and data, adding more interactive features with Wio Terminal.
- Install the U8g2 libraries from the Library Manager in Arduino IDE. Navigate to Sketch -> Include Library -> Manage Libraries... and Search and install
U8g2in the Library Manager.
U8g2 Initilization
Initialuse the OLED display using u8g2's software I2C and use SCL for clock and SDA for Data:
U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE);
Usage
Call u8g2.firstPage().
Start a do-while loop.
Inside the loop-body: Draw something with the usual draw commands.
Loop as long as u8g2.nextPage() returns true.
For more information, please visit u8g2
Complete Code
Connect the Grove OLED Display 0.96" to the Grove I2C pin and check the results!
#include <U8g2lib.h>
const unsigned char WAVE[] PROGMEM = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xF0,0x00,0xFF,0x00,0x0F,0xF0,0x00,
0xFC,0x03,0xFF,0xC0,0x3F,0xFC,0x00,
0xFE,0x07,0xFF,0xE0,0x7F,0xFE,0x00,
0x1F,0xFF,0x81,0xFF,0xF8,0x1F,0xC0,
0x0F,0xFF,0x00,0xFF,0xF0,0x0F,0xC0,
0x03,0xFC,0x00,0x3F,0xC0,0x03,0xC0,
0xE0,0x00,0x7E,0x00,0x07,0xE0,0x00,
0xF8,0x01,0xFF,0x80,0x1F,0xF8,0x00,
0xFF,0x0F,0xFF,0xF0,0xFF,0xFF,0x00,
0x07,0xFE,0x00,0x7F,0xE0,0x07,0xC0,
0x01,0xF8,0x00,0x1F,0x80,0x01,0xC0,
0x3F,0xFF,0xC3,0xFF,0xFC,0x3F,0xC0,
0x00,0xF0,0x00,0x0F,0x00,0x00,0xC0,
0x80,0x00,0x18,0x00,0x01,0x80,0x00,
u8g2.begin();
u8g2.firstPage();
do {
u8g2.setFont(u8g2_font_t0_16b_mr);
u8g2.drawXBMP(40, 0, 50, 50, WAVE);
u8g2.setCursor(20, 60);
u8g2.print("Wio Terminal");
} while (u8g2.nextPage());
Wio Terminal With Grove - Temperature Sensor
This section introduces how to use Grove - Temperature Sensor with Wio Terminal to display real-time surrounding temperature readings.
Complete Code
Connect the Grove Temperature sensor to the Grove D/A Pin of Wio Terminal, upload the code and check the results!
#include <math.h>
TFT_eSPI tft;
const int B = 4275; // B value of the thermistor
const int R0 = 100000; // R0 = 100k
const int pinTempSensor = A0; // Grove - Temperature Sensor connect to A0
pinMode(pinTempSensor, INPUT);
tft.begin();
tft.setRotation(3);
spr.fillSprite(TFT_DARKCYAN);
int a = analogRead(pinTempSensor);
float R = 1023.0/a-1.0;
R = R0*R;
float temperature = 1.0/(log(R/R0)/B+1/298.15)-273.15; // convert to temperature via datasheet
data.push(temperature); //read variables and store in data
.value("Temperature Reading")
.align(center)
.color(TFT_WHITE)
.valign(vcenter)
.width(tft.width())
.thickness(2);
content
.y_role_color(TFT_WHITE)
.x_role_color(TFT_WHITE)
.draw();
delay(50);
Wio Terminal With Grove - GPS Sensor
This section introduces how to use Grove - GPS Sensor with Wio Terminal for obtaining real-time GPS information. The sensor itself outputs NMEA GPS data which we will use the TinyGPSPlus library to parse the data to readable information.
- Install the TinyGPSPlus Library.
Complete Code
Connect the Grove GPS Sensor to the Grove I2C Pin (Left Side) of Wio Terminal, upload the code and check the results in Serial Monitor(w/ baud rate: 9600)!
#include <TinyGPS++.h>
#include <wiring_private.h>
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device - Left side Grove connector.
// Left side Grove connector shares pins with I2C1 of 40 pin connector.
static Uart Serial3(&sercom3, PIN_WIRE_SCL, PIN_WIRE_SDA, SERCOM_RX_PAD_1, UART_TX_PAD_0);
Serial3.begin(GPSBaud);
pinPeripheral(PIN_WIRE_SCL, PIO_SERCOM_ALT);
// This sketch displays information every time a new sentence is correctly encoded.
while (Serial3.available() > 0)
if (gps.encode(Serial3.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
else
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
else
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
else
Serial.println();
void SERCOM3_0_Handler()
Serial3.IrqHandler();
void SERCOM3_1_Handler()
void SERCOM3_2_Handler()
void SERCOM3_3_Handler()
