Using the Grove Analog Port on Wio Terminal
This repo demonstrates how to use Analog as inputs on Wio Terminal. To use analog pins on Wio Terminal, you must use RPI pins.
RPI Analog Pins
The Raspberry Pi pinouts are defined as:
RPI_A0->RPI_A8
Grove Port Configurations
To use the Grove configurable A/D Port as Analog port, simply define it as follow:
pinMode(A0, INPUT);
Now, connect your Grove sensor to the physical pin!
Example Code
In this example, a Grove Loudness sensor is used to demonstrate:
pinMode(A0, INPUT);
int loudness = analogRead(A0);
Serial.print("Loudness: ");
Serial.println(loudness);
delay(50);
