Using the Grove I2C Port on Wio Terminal
This repo demonstrates how to use the Grove I2C Port on Wio Terminal, you can simply use this plug and play functionality with the Grove Ecosystem!
Port Configurations
To use the Grove I2C port on Wio Terminal, Simply connect your Grove sensor that uses I2C to the physical I2C port on Wio Terminal.
Note: Remember to include the Sensor libraries in Arduino IDE. Refer to this How to install library for more information.
Example Code
In this example, a Grove LCD is used to demonstrate. This is the HelloWorld example from the RGB LCD libabry.
#include <Wire.h>
#include "rgb_lcd.h"
rgb_lcd lcd;
const int colorR = 255;
const int colorG = 0;
const int colorB = 0;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
delay(100);
