Getting Started with Microphone
This wiki introduces how to use the built-in microphone for audio input in Wio Terminal. The microphone can be used to detect surrounding sound and respond accordingly.
note
This wiki only demonstrates the very basic of the microphone, and we are working on a microphone library for Wio Terminal to enable much more functions! Stay tuned!
Example Code
Note: WIO_MIC is defined for the built-in microphone.
pinMode(WIO_MIC, INPUT);
int val = analogRead(WIO_MIC);
Serial.println(val);
delay(200);
Example Code with LCD Screen
Libraries Installation
#include"seeed_line_chart.h" //include the library
#include <math.h>
TFT_eSPI tft;
#define max_size 50 //maximum size of data
doubles data; //Initilising a doubles type to store data
TFT_eSprite spr = TFT_eSprite(&tft); // Sprite
tft.begin();
tft.setRotation(3);
spr.createSprite(TFT_HEIGHT,TFT_WIDTH);
spr.fillSprite(TFT_DARKGREY);
if (data.size() == max_size) {
data.pop();//this is used to remove the first read variable
data.push(val); //read variables and store in data
//Settings for the line graph title
auto header = text(0, 0)
.value("Microphone Reading")
.align(center)
.color(TFT_WHITE)
.valign(vcenter)
.width(tft.width())
.thickness(2);
header.height(header.font_height() * 2);
header.draw(); //Header height is the twice the height of the font
auto content = line_chart(20, header.height()); //(x,y) where the line graph begins
content
.height(tft.height() - header.height() * 1.5) //actual height of the line chart
.width(tft.width() - content.x() * 2) //actual width of the line chart
.based_on(0.0) //Starting point of y-axis, must be a float
.show_circle(true) //drawing a cirle at each point, default is on.
.y_role_color(TFT_WHITE)
.x_role_color(TFT_WHITE)
.value(data) //passing through the data to line graph
.color(TFT_RED) //Setting the color for the line
.draw();
spr.pushSprite(0, 0);
delay(50);
