Build a IR Thermal Imaging Camera using Wio Terminal
Overview
With Grove - Infrared Temperature Sensor Array (AMG8833) and Wio Terminal, we can build a low cost FLIR™ like Thermal Imagining camera with ease! To set you back a little, the resolution of the Grove - Infrared Temperature Sensor Array (AMG8833) is only 8 x 8 (64 Pixels), which in some cases is good enough. So Linear Interpolation is used in the code to expand to 70 x 70 (4900 Pixels) for a much better indications.
This demo is inspired by Kris Kasprzak's video. Several modifications were made to make it compatible with Wio Terminal and Grove - Infrared Temperature Sensor Array (AMG8833). Most Graphics are now first drawn to TFT LCD Sprites first to improve overall performance and faster frame rate. Also added a crosshair in the middle of screen and showing the temperature at the crosshair.
Indicating the exact temperature at crosshair
IR Thermal Camera sensing thermal objects
Right button to enable grid ON/OFF functionality
Arduino libraries needed
Install the LCD screen Library
Seeed_Arduino_LCD, please visit Wio Terminal LCD for more information. -
Visit the Seeed_AMG8833 repositories and download the entire repo to your local drive.
- Now, the Seeed_AMG8833 library can be installed to the Arduino IDE. Open the Arduino IDE, and click
sketch->Include Library->Add .ZIP Library, and choose theSeeed_AMG8833file that you've have just downloaded.
Arduino Instructions
Plug in the the Grove - Infrared Temperature Sensor Array (AMG8833) to the Grove I2C Interface of Wio Terminal.
Download the Complete code here or copy the following.
Upload the code.
Complete Code
Note: To boost up performance and frame rate of this IR Thermal Imaging Camera, you can boost the Wio Terminal CPU Speed to 200MHz. Select Tools -> CPU Speed -> 200MHz(Overclock)
This program is for upsizing an 8 x 8 array of thermal camera readings
it will size up by 10x and display to a 240 x 320
interpolation is linear and "good enough" given the display is a 5-6-5 color palet
Total final array is an array of 70 x 70 of internal points only
Revisions
1.0 Kasprzak Initial code
1.1 Anson(Seeed Studio) Adapted to Wio Terminal with Grove - Infrared Sensor(AMG8833)
#include <Seeed_AMG8833_driver.h>
#include <TFT_eSPI.h> // Include the graphics library (this includes the sprite functions)
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite Display = TFT_eSprite(&tft); // Create Sprite object "img" with pointer to "tft" object
// the pointer is used by pushSprite() to push it onto the TFT
unsigned long CurTime;
uint16_t TheColor;
// start with some initial colors
uint16_t MinTemp = 25;
uint16_t MaxTemp = 35;
// variables for interpolated colors
byte red, green, blue;
// variables for row/column interpolation
byte i, j, k, row, col, incr;
float intPoint, val, a, b, c, d, ii;
byte aLow, aHigh;
// size of a display "pixel"
byte BoxWidth = 3;
byte BoxHeight = 3;
int x, y;
char buf[20];
// variable to toggle the display grid
int ShowGrid = -1;
// array for the 8 x 8 measured pixels
float pixels[64];
// array for the interpolated array
float HDTemp[80][80];
// create the camara object
AMG8833 ThermalSensor;
//Toggle the grid on and off
void toggleGrid() {
ShowGrid = ShowGrid *-1;
Display.fillRect(15, 15, 210, 210, TFT_BLACK);
yield();
// start the display and set the background to black
tft.begin();
tft.fillScreen(TFT_BLACK);
//Interrupt to toggle Gird on and off
pinMode(WIO_KEY_A, INPUT);
attachInterrupt(digitalPinToInterrupt(WIO_KEY_A), toggleGrid, FALLING);
// set display rotation (you may need to change to 0 depending on your display
tft.setRotation(3);
// show a splash screen
tft.setCursor(20, 20);
tft.setTextColor(TFT_BLUE, TFT_BLACK);
tft.print("Thermal ");
tft.setTextColor(TFT_RED, TFT_BLACK);
tft.print("Camera");
// let sensor boot up
bool status = ThermalSensor.init();
delay(100);
if (!status) {
Serial.print("Failed to initalized AMG8833");
// read the camera for initial testing
ThermalSensor.read_pixel_temperature(pixels);
// check status and display results
if (pixels[0] < 0) {
while (1) {
tft.setCursor(20, 40);
tft.print("Readings: FAIL");
delay(500);
else {
tft.setTextColor(TFT_GREEN, TFT_BLACK);
tft.print("Readings: OK");
delay(2000);
Display.createSprite(TFT_HEIGHT, TFT_WIDTH);
Display.fillSprite(TFT_BLACK);
// get the cutoff points for the color interpolation routines
// note this function called when the temp scale is changed
Getabcd();
// draw a legend with the scale that matches the sensors max and min
DrawLegend();
CurTime = millis();
// draw a large white border for the temperature area
Display.fillRect(10, 10, 220, 220, TFT_WHITE);
// read the sensor
// now that we have an 8 x 8 sensor array
// interpolate to get a bigger screen
// interpolate the 8 rows (interpolate the 70 column points between the 8 sensor pixels first)
for (row = 0; row < 8; row ++) {
for (col = 0; col < 70; col ++) {
// get the first array point, then the next
// also need to bump by 8 for the subsequent rows
aLow = col / 10 + (row * 8);
aHigh = (col / 10) + 1 + (row * 8);
// get the amount to interpolate for each of the 10 columns
// here were doing simple linear interpolation mainly to keep performace high and
// display is 5-6-5 color palet so fancy interpolation will get lost in low color depth
intPoint = (( pixels[aHigh] - pixels[aLow] ) / 10.0 );
// determine how much to bump each column (basically 0-9)
incr = col % 10;
// find the interpolated value
val = (intPoint * incr ) + pixels[aLow];
// store in the 70 x 70 array
// since display is pointing away, reverse row to transpose row data
HDTemp[ (7 - row) * 10][col] = val;
// now that we have raw data with 70 columns
// interpolate each of the 70 columns
// forget Arduino..no where near fast enough..Teensy at > 72 mhz is the starting point
for (row = 0; row < 70; row ++) {
// also need to bump by 8 for the subsequent cols
aLow = (row / 10 ) * 10;
aHigh = aLow + 10;
intPoint = (( HDTemp[aHigh][col] - HDTemp[aLow][col] ) / 10.0 );
incr = row % 10;
val = (intPoint * incr ) + HDTemp[aLow][col];
HDTemp[ row ][col] = val;
//display the 70 x 70 array
DisplayGradient();
//Crosshair in the middle of the screen
Display.drawCircle(115, 115, 5, TFT_WHITE);
Display.drawFastVLine(115, 105, 20, TFT_WHITE);
Display.drawFastHLine(105, 115, 20, TFT_WHITE);
//Push the Sprite to the screen
Display.pushSprite(0, 0);
//Displaying the temp at the middle of the Screen
tft.setRotation(3);
tft.setTextColor(TFT_WHITE);
tft.drawFloat(HDTemp[35][35], 2, 90, 20);
//Uncomment this to print out frame rate
Serial.print("Frame rate: "); Serial.println(1/(0.001*(millis() - CurTime)));
// function to display the results
void DisplayGradient() {
tft.setRotation(4);
// rip through 70 rows
// fast way to draw a non-flicker grid--just make every 10 pixels 2x2 as opposed to 3x3
// drawing lines after the grid will just flicker too much
if (ShowGrid < 0) {
BoxWidth = 3;
else {
if ((row % 10 == 9) ) {
BoxWidth = 2;
else {
BoxWidth = 3;
// then rip through each 70 cols
for (col = 0; col < 70; col++) {
if (ShowGrid < 0) {
BoxHeight = 3;
else {
if ( (col % 10 == 9)) {
BoxHeight = 2;
else {
BoxHeight = 3;
// finally we can draw each the 70 x 70 points, note the call to get interpolated color
Display.fillRect((row * 3) + 15, (col * 3) + 15, BoxWidth, BoxHeight, GetColor(HDTemp[row][col]));
// my fast yet effective color interpolation routine
uint16_t GetColor(float val) {
pass in value and figure out R G B
several published ways to do this I basically graphed R G B and developed simple linear equations
again a 5-6-5 color display will not need accurate temp to R G B color calculation
equations based on
http://web-tech.ga-usa.com/2012/05/creating-a-custom-hot-to-cold-temperature-color-gradient-for-use-with-rrdtool/index.html
red = constrain(255.0 / (c - b) * val - ((b * 255.0) / (c - b)), 0, 255);
if ((val > MinTemp) & (val < a)) {
green = constrain(255.0 / (a - MinTemp) * val - (255.0 * MinTemp) / (a - MinTemp), 0, 255);
else if ((val >= a) & (val <= c)) {
green = 255;
else if (val > c) {
green = constrain(255.0 / (c - d) * val - (d * 255.0) / (c - d), 0, 255);
else if ((val > d) | (val < a)) {
green = 0;
if (val <= b) {
blue = constrain(255.0 / (a - b) * val - (255.0 * b) / (a - b), 0, 255);
else if ((val > b) & (val <= d)) {
blue = 0;
else if (val > d) {
blue = constrain(240.0 / (MaxTemp - d) * val - (d * 240.0) / (MaxTemp - d), 0, 240);
// use the displays color mapping function to get 5-6-5 color palet (R=5 bits, G=6 bits, B-5 bits)
return Display.color565(red, green, blue);
// function to get the cutoff points in the temp vs RGB graph
void Getabcd() {
a = MinTemp + (MaxTemp - MinTemp) * 0.2121;
b = MinTemp + (MaxTemp - MinTemp) * 0.3182;
c = MinTemp + (MaxTemp - MinTemp) * 0.4242;
d = MinTemp + (MaxTemp - MinTemp) * 0.8182;
// function to draw a legend
void DrawLegend() {
//color legend with max and min text
j = 0;
float inc = (MaxTemp - MinTemp ) / 160.0;
for (ii = MinTemp; ii < MaxTemp; ii += inc) {
tft.drawFastHLine(260, 200 - j++, 30, GetColor(ii));
tft.setTextSize(2);
tft.setCursor(245, 20);
tft.setTextColor(TFT_WHITE, TFT_BLACK);
sprintf(buf, "%2d/%2d", MaxTemp, (int) (MaxTemp * 1.8) + 32);
tft.print(buf);
tft.setTextSize(2);
tft.setCursor(245, 210);
sprintf(buf, "%2d/%2d", MinTemp, (int) (MinTemp * 1.8) + 32);
tft.print(buf);
// END OF CODE
