Wio Link Deluxe Plus Kit
This kit is same as Wio Link Deluxe Kit except that this kit additionally contains two display modules, which can add visual interfaces for the user. You can use this kit to run some real projects or do prototyping. It contains sensors(mainly), switching-function modules, servo motors, LED strip and a speaker. The most amazing part of this kit is the Wio Link development board which can be utilized for various devices: without a bit programming skill required. All the actions you want your modules performed and the flashing-code operation to Wio Link could be completed with taps in a mobile app. And you can send instructions to your devices over internet at anywhere. So Wio Link will be a perfect utility to making things around smarter for everyone. Now let us do something real!
The Wio IFTTT function is EOL. But Wio APP is available. You can use the API from Wio APP to read sensor status and control the actuator.
- Full package of all general required functional modules
- Grove port interfaced, more practical function and less work
- Completely easy to make things around you smarter and add fun to daily life
- Cost-effective
- Weight: 355 g
Parts list
| Parts name | Quantity |
| Grove - Button | 1PC |
| Grove - Relay | 1PC |
| Grove - Moisture Sensor | 1PC |
| Grove - Temp&Humi Sensor | 1PC |
| Grove - Digital Light Sensor | 1PC |
| Grove - Rotary Angle Sensor | 1PC |
| Grove - Protoshield | 1PC |
| Grove - Magnetic Switch | 1PC |
| Grove - 3-Axis Digital Accelerometer(±1.5g) | 1PC |
| Grove - IR Distance Interrupt | 1PC |
| Grove - Barometer Sensor (BMP180) | 1PC |
| Grove - Air quality sensor v1.3 | 1PC |
| Grove - Gesture | 1PC |
| Grove - I2C Hub | 1PC |
| Grove - Speaker | 1PC |
| Grove - WS2812 Waterproof LED Strip - 30 LEDs 1 meter | 1PC |
| Micro USB Cable - 48cm | 2PCS |
| Grove - Servo | 1PC |
| Grove - OLED Display 0.96" | 1PC |
| Grove - Ultrasonic Ranger | 1PC |
| Wio Link | 2PCS |
A simple demo
This demo can be used as a compilation result-indicator.
Preliminary Guide
Material required
- Wio Link APP
- Wio Link
- Grove Relay × 3
- A Travis CI Account
- A GitHub Account
- Traffic Light
A detailed how-to
Please go to Recipe for the detailed manual:
if you have any technical issue. submit the issue into our forum. Thank you for choosing our products! We are here to provide you with different support to ensure that your experience with our products is as smooth as possible. We offer several communication channels to cater to different preferences and needs.
