Xadow - RGB OLED 96*64
RBG OLED is a 16 bit 9664 dot matrix OLED display module with RGB color. It is based on SSD1331 module which is a single chip CMOS OLED/PLED driver with 288 segments and 64 common output, supporting up to 96 RGB 64 dot matrix display. It use SPI for communication.
Specifications
- Power Voltage (VCC):3.3V
- Display Color: RGB
- Dot Matrix: 96*64
- Operating temperature: -20~70 ℃
- Dimensions: 25.43mm x 20.35mm
Pin Definition
We only need CS, DC, MOSI, SCLK 4 pins for communication. and
CS <==> A5
DC <==> 3
MOSI <==> 16
SCLK <==> 15
Please notice: heavy impact or stress on OLED will cause the breakdown of screen.
Getting Started
RGB OLED can display all kinds of graphics and characters. We offered lots of example sketches for you to play with it.
The hardware installation
Note: When connecting Xadow RGB OLED to Xadow Main Board, you should concern about the connection direction. The connection method is that the unfilled corner of one Xadow module need to connect to the right angle of another module(see four corners of each Xadow module).
Draw Line
Download RGB OLED Library and SGL Library, then install them to your Arduino Library. Open the DrawLine example sketch by the path: Files->Examples->RGB_OLED_96_64->examples->drawLine.
<pre>
draw rectangle
This sketch is used to test Seeed's Xadow - RGB OLED,
it will draw several line with different color
create on 2014/06/24, version: 0.1
by lawliet.zou([email protected])
#include <SGL.h>
#include <SSD1331.h>
#include <SPI.h>
#define cs A5
#define dc 3
#define mosi 16
#define sclk 15
SSD1331 oled = SSD1331(cs, dc, mosi, sclk);
void setup(){
Serial.begin(9600);
Serial.println("Start to draw");
oled.init();
oled.fillScreen(COLOR_BLACK);
delay(2000);
oled.drawLine(5,7,65,48,COLOR_BLUE);
oled.drawLine(5,40,48,7,COLOR_RED);
oled.drawLine(65,5,47,50,COLOR_GREEN);
oled.drawLine(3,10,80,21,COLOR_YELLOW);
void loop(){
//nothing to do
</pre>
Select the correct port number and the board type should be Seeeduino Xadow, then upload the code, you can see four line with different color will be drew on the screen of RGB OLED just as follow.
Draw Circle
Open the DrawCircle example sketch by the path: Files->Examples->RGB_OLED_96_64->examples->drawCircle.
draw circle
it will draw a circle
#include <SGL.h>
#include <SPI.h>
#define cs A5
#define dc 3
#define mosi 16
#define sclk 15
void setup(){
Serial.begin(9600);
oled.init();
delay(2000);
void loop(){
for(int i = 30; i > 0; i--){
oled.drawCircle(48,32,i,COLOR_CYAN);
delay(50);
for(int i = 1; i <= 30; i++){
oled.drawCircle(48,32,i,COLOR_RED);
delay(50);
oled.drawCircle(48,32,i,COLOR_PURPLE);
delay(50);
oled.drawCircle(48,32,i,COLOR_GOLDEN);
delay(50);
It is used to draw concentric circles with different color. Select the correct port number and the board type should be Seeeduino Xadow, then upload the code, you can see many circles with different colors will be drew on the screen of RGB OLED just as follow.
Draw Rectangle
Open the DrawRectangle example sketch by the path: Files->Examples->RGB_OLED_96_64->examples->drawRectangle.
draw rectangle
it will draw a rectangle with blue color
#include <SGL.h>
#include <SPI.h>
#define cs A5
#define dc 3
#define mosi 16
#define sclk 15
void setup(){
Serial.begin(9600);
oled.init();
delay(2000);
void loop(){
for(int i = 1; i < 16; i++){
oled.drawRectangle(3*i,2*i,95-6*i,63-4*i,COLOR_YELLOW);
delay(50);
delay(2000);
for(int i = 15; i > 0; i--){
oled.drawRectangle(3*i,2*i,95-6*i,63-4*i,COLOR_BLUE);
delay(50);
delay(2000);
Select the correct port number and the board type should be Seeeduino Xadow, then upload the code, you can see many rectangle will be drew on the screen of RGB OLED just as follow.
Draw Triangle
Open the DrawTriangle example sketch by the path: Files->Examples->RGB_OLED_96_64->examples->drawTriangle.
draw triangle
it will draw a triangle
#include <SGL.h>
#include <SPI.h>
#define cs A5
#define dc 3
#define mosi 16
#define sclk 15
void setup(){
Serial.begin(9600);
oled.init();
delay(2000);
void loop(){
//nothing to do
uint8_t x0 = random(0,96);
uint8_t y0 = random(0,64);
uint8_t x1 = random(0,96);
uint8_t y1 = random(0,64);
uint8_t x2 = random(0,96);
uint8_t y2 = random(0,64);
oled.drawTraingle(x0,y0,x1,y1,x2,y2,random(0,65536));
delay(3000);
Upload the code, you can see triangles with random location and shape will be drew on the screen of RGB OLED just as follow.
Draw String
Open the DrawString example sketch by the path: Files->Examples->RGB_OLED_96_64->examples->drawString.
draw string
it will draw a string
#include <SGL.h>
#include <SPI.h>
#define cs A5
#define dc 3
#define mosi 16
#define sclk 15
char* str = "Seeed";
void setup(){
Serial.begin(9600);
oled.init();
delay(2000);
oled.drawString(str,15,25,2,COLOR_GREEN);
delay(2000);
oled.setScolling(Horizontal,0,64,1);
void loop(){
//nothing to do
Upload the code, you can see the string "seeed" will be drew on the screen of RGB OLED just as follow.
Draw BitMap
Open the DrawBitMap example sketch by the path: Files->Examples->RGB_OLED_96_64->examples->drawBitMap.
draw bitmap
it will draw a bitmap
#include <SGL.h>
#include <SPI.h>
#define cs A5
#define dc 3
#define mosi 16
#define sclk 15
static unsigned char SeeedLogo[] PROGMEM ={
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x06, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x80, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x0F, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x01, 0xE0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3E, 0x00, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x3E, 0x00, 0x01, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x00, 0xF8,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x7C, 0x00, 0x00, 0xF8, 0x00, 0x60, 0x00, 0x00,
0x00, 0x00, 0x18, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x18, 0x00,
0xFC, 0x00, 0x00, 0xFC, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0xFC, 0x00, 0x00, 0xFC,
0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x1C, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0xE0, 0x00, 0x00,
0x00, 0x00, 0x1C, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00,
0xFC, 0x00, 0x00, 0xFC, 0x01, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0xFC, 0x00, 0x00, 0xFC,
0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x01, 0xE0, 0x00, 0x00,
0x00, 0x00, 0x1F, 0x00, 0xFC, 0x00, 0x00, 0xFC, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80,
0xFC, 0x00, 0x00, 0xFC, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x80, 0xFE, 0x00, 0x00, 0xFC,
0x07, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC0, 0x7E, 0x00, 0x01, 0xFC, 0x0F, 0xE0, 0x00, 0x00,
0x00, 0x00, 0x0F, 0xC0, 0x7E, 0x00, 0x01, 0xF8, 0x0F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0,
0x7E, 0x00, 0x01, 0xF8, 0x1F, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x3F, 0x00, 0x01, 0xF0,
0x3F, 0x80, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x3F, 0x00, 0x03, 0xF0, 0x3F, 0x80, 0x00, 0x00,
0x00, 0x00, 0x03, 0xF8, 0x1F, 0x00, 0x03, 0xE0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFC,
0x1F, 0x80, 0x07, 0xE0, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFE, 0x0F, 0x80, 0x07, 0xC1,
0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x07, 0xC0, 0x07, 0x83, 0xFC, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x7F, 0x83, 0xC0, 0x0F, 0x07, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F,
0xC1, 0xE0, 0x0E, 0x0F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF0, 0xE0, 0x1C, 0x1F,
0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x70, 0x38, 0x7F, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xFC, 0x38, 0x30, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xFF, 0x00, 0x03, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0x80, 0x07, 0xF0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF0, 0x3F, 0xC0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x7E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x08, 0x40, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00,
0x00, 0x03, 0xF0, 0x0F, 0xC0, 0x0F, 0xC0, 0x0F, 0x80, 0x1F, 0xBC, 0x00, 0x00, 0x0F, 0xF8, 0x3F,
0xF0, 0x3F, 0xF0, 0x3F, 0xE0, 0x7F, 0xFC, 0x00, 0x00, 0x1F, 0xFC, 0x7F, 0xF8, 0x7F, 0xF8, 0x7F,
0xF8, 0xFF, 0xFC, 0x00, 0x00, 0x1F, 0x7E, 0xFE, 0xFC, 0xFD, 0xFC, 0xFD, 0xFD, 0xFD, 0xFC, 0x00,
0x00, 0x1E, 0x1E, 0xF0, 0x3F, 0xF0, 0x3D, 0xE0, 0x3D, 0xE0, 0x7C, 0x00, 0x00, 0x1F, 0xF1, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xE0, 0x3C, 0x00, 0x00, 0x0F, 0xFD, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFD, 0xC0, 0x3C, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xC0, 0x3C, 0x00,
0x00, 0x3C, 0x1E, 0xF0, 0x31, 0xF0, 0x21, 0xE0, 0x21, 0xE0, 0x7C, 0x00, 0x00, 0x3F, 0x3E, 0xFE,
0xFC, 0xFC, 0xF8, 0xFD, 0xF9, 0xFD, 0xFC, 0x00, 0x00, 0x1F, 0xFE, 0x7F, 0xFC, 0x7F, 0xF8, 0x7F,
0xF8, 0xFF, 0xFC, 0x00, 0x00, 0x0F, 0xFC, 0x3F, 0xF0, 0x3F, 0xF0, 0x3F, 0xE0, 0x7F, 0xFC, 0x00,
0x00, 0x03, 0xF0, 0x0F, 0xC0, 0x0F, 0xC0, 0x0F, 0x80, 0x1F, 0xBC, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x64, 0xCD, 0xF6, 0xE1, 0xC9, 0x3F,
0x3F, 0xFB, 0xA6, 0x00, 0x00, 0x1F, 0xFF, 0xEF, 0xFF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFE, 0x00,
0x00, 0x1F, 0xFF, 0xEF, 0xFF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x1F, 0xFF, 0xED,
0xFF, 0xFF, 0xFF, 0xB7, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x20, 0x00, 0x01, 0x00,
0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
void setup(){
Serial.begin(9600);
oled.init();
delay(2000);
oled.drawBitMap(0,0,SeeedLogo,96,64,COLOR_YELLOW);
delay(5000);
Serial.println("start to scoll ...");
oled.setScolling(Vertical,0,64,0);
void loop(){
//nothing to do
Upload the code, you can see Seeed's logo with yellow color will be drew on the screen of RGB OLED just as follow.
Schematic Online Viewer
