Deploy AI Models on Jetson: What Can Run and How
This page covers the questions that come up most often when running AI models on NVIDIA Jetson — LLMs, vision-language models, generative models, embodied/VLA models, speech, and computer vision:
- What model size (in B, billion parameters) can my device run?
- Which models can I deploy?
- How do I deploy them?
Three ways to deploy:
- Online platform (recommended): browse and deploy from the reComputer AI Lab — 100+ optimized CV / LLM / VLM models for reComputer Jetson with one-command Docker deployment and benchmarks. Pick a model on the page, copy the command, run it.
- One-command CLI: jetson-examples —
reComputer run <model>. - Manual: you pick the engine (Ollama, llama.cpp, MLC, TensorRT Edge-LLM, TensorRT-Model-Connect) and follow the tutorials listed below.
1. What model size can my device run?
"Model size" is expressed in B (billion parameters) — a 7B model has 7 billion parameters, and larger B numbers need more memory. What matters is your Jetson module's unified memory (the module, not the carrier board). For a quantized (Q4_K_M) model:
8 GB · Orin Nano
1B – 4B models
Llama 3.2 1B/3B, Qwen3.5-4B, Gemma4 E4B, Live VLM WebUI
16 GB · Orin NX
7B – 8B models
Llama3 8B, DeepSeek-R1 7B, Llama2-7B (MLC), LLaVA 7B, LocateAnything
32 GB · AGX Orin
up to 27B (quantized)
Qwen3.5-27B Q4_K_M (see JetPack 6.2 vs 7.2 benchmark below)
64 GB · AGX Orin
30B – 35B+
Nemotron-3-Nano-30B (Q4_K_M), Qwen3.6-35B (UD-Q6_K), GPT-OSS
128 GB · Jetson Thor
35B+ and larger
Nemotron3 33B, JoyAI VLM / ASR / TTS stack
Memory use includes the KV cache and system overhead, so a model whose weights nearly fill the RAM will not run stably. Measured on AGX Orin 32 GB, a Qwen3.5-27B Q4_K_M model used about 24.6 GB of the 30 GB available after load — that is a realistic ceiling for 32 GB devices.
2. Which models can I deploy?
2.1 One-command deployment (jetson-examples)
Install once, then run any supported model with one command:
sudo apt install python3-pip
pip3 install jetson-examples
Qwen Series
reComputer run qwen3.5-4breComputer run qwen3.6-35bLlama Family
reComputer run llama3reComputer run llama3.2reComputer run llavaGemma Family
reComputer run gemma4NVIDIA Models (64 GB)
reComputer run nemotron-3-nanoreComputer run gpt-ossVLM (Vision-Language)
reComputer run live-vlm-webuireComputer run locateanythingYOLO & Detection
reComputer run ultralytics-yoloreComputer run yolo11reComputer run yolo26reComputer run yolo26-tensorrtreComputer run yolov10reComputer run depth-anything-v2reComputer run depth-anything-v3reComputer run nanoowlTooling
reComputer run ollamareComputer run whisperreComputer run llama-factoryNote: sizes above are for the shown quantization. Higher precision (Q8 / FP16) roughly doubles or more the weight size. Each example also needs enough free disk (image + model) — LLaVA FP16 needs about 27.4 GB total. Check the example list in the jetson-examples README for exact image sizes.
2.2 Manual deployment: full tutorial index
Each category below links to a complete tutorial on this wiki. Pick the one that matches your task and follow it on the device.
Engine at a glance
Easy setup
Q4 quantized
GGUF, full control
Production · JP 6.2
On-device build · JP 7.2
1. General LLM
VRAM estimate: reliable — params × bits/8 + KV cache + system. Q4: 7B ≈ 4-5 GB, 27B ≈ 15-18 GB.
- DeepSeek-R1 7B with Ollama
- DeepSeek 1.5B with MLC ~60 tok/s
- Llama2-7B Q4 with MLC
- GPT-OSS 20B with llama.cpp
- Structured LLM output with Langchain
- RAG with LlamaIndex + ChromaDB
- Local AI Assistant (AnythingLLM)
- Local OpenClaw (Clawdbot)
- Fine-tune with Llama-Factory
- Develop reComputer with Clawdbot
- LLM hardware interface control
- Voice control motor by LLM
2. VLM (Vision-Language)
VRAM estimate: roughly — LLM part + vision encoder (0.3-4B) + input resolution/tiles. Higher resolution scales VRAM non-linearly.
- Run VLM on reComputer
- Live VLM WebUI 7 VLMs · real-time
- JoyAI-VL-Interaction Thor · voice/video
- VLM with speech interaction
- LLaVA warehouse guard Ollama llava-llama3 8B
- Zero-Shot Detection
3. Generative & World models
VRAM estimate: not by parameters alone — DiT patch/frame count, temporal attention, U-Net vs DiT vs MoE change actual VRAM 3-5x at the same size. Measure on device.
- Stable Diffusion (text-to-image)
- ComfyUI
reComputer run comfyui - AudioCraft (music gen)
reComputer run audiocraft - Wan / video generation, world models — no verified Jetson deployment yet; VRAM must be measured per model
4. Embodied / VLA
VRAM estimate: not by parameters — vision encoder + camera count + control rate + action chunking. Measure on device.
- GR00T N1.5 + LeRobot SO-101 (Thor)
- GR00T N1.6 + LeRobot SO-101 (AGX Orin)
- GR00T N1.7 + reBot Arm (J601)
- GraspNet visual grasping (reBot-DM)
- Control SO-Arm by OpenClaw (Thor)
- Control reBot by NemoClaw (Thor)
- Jetson-Claw starter (8 GB)
- GR00T N1.7 full-weight TensorRT (JP 7.2)
- Voice-control reBot Arm B601
- Microduck RL on Jetson
- Microduck RL environment
- Microduck RL official policies
- Microduck RL custom motion
5. Speech (ASR / TTS)
VRAM estimate: small models — usually fine on 8 GB. Whisper/Riva run alongside an LLM in a pipeline.
6. Computer Vision (YOLO & detection)
VRAM estimate: small — YOLO models typically run on 8 GB with TensorRT, and scale with input resolution. See the one-command list in section 2.1.
- YOLOv8 with TensorRT
- YOLOv8 with DeepStream + TensorRT
- Train and deploy YOLOv8
- YOLOv8 custom classification
- YOLOv5 object detection
- YOLOv11 + Depth Camera
- YOLOv26 dual camera system
- Depth Anything V3
- MaskCam
- Traffic Management (DeepStream)
- DashCamNet multicamera
- Multi-GMSL cameras
- Four-camera fisheye surround view
- Multi-task vision inference engine
- Streaming Vision Agent (Qwen3-VL)
- Frigate NVR
- Security X-ray scan
- Industrial vision monitoring
- NVBlox 3D mapping
- AI NVR
3. How do I deploy?
AI Lab (online platform)
- Open reComputer AI Lab Models (Jetson pre-filtered)
- Filter by device (e.g. Jetson Orin Nano) and browse CV / LLM / VLM models with benchmarks
- Copy the one-command Docker command and run it on your device
100+ optimized models, no setup, includes benchmark numbers.
One-command CLI
Install jetson-examples, then deploy any model from section 2.1:
# Deploy a model (example)
reComputer run qwen3.5-4bExposes an OpenAI-compatible API endpoint, usable directly with curl or any OpenAI SDK.
Manual deployment
Pick an engine from section 2.2 and follow its tutorial on your device:
- Ollama — easiest start, large model library
- MLC LLM — quantized (Q4) compiled models
- llama.cpp — lightweight, GGUF, full control
- TensorRT Edge-LLM / Model-Connect — production speed
All tutorials are verified on reComputer Jetson devices.
4. Performance benchmark: JetPack 6.2 vs 7.2
Same Qwen3.5-27B Q4_K_M model (llama.cpp) on AGX Orin-class hardware, JetPack 6.2 vs 7.2:
| Metric | JetPack 6.2 | JetPack 7.2 | Change |
| Memory after model load | 24.6 GB / 30 GB | 14.7 GB / 30 GB | ~40% lower |
| GPU frequency during inference | 930 MHz | 1.36 GHz | higher boost |
| Prompt processing | 18.2 tok/s | 25.8 tok/s | ~41.8% faster |
| Token generation | 4.3 tok/s | 5.5 tok/s | ~27.9% faster |
Details: JetPack 7.2 Deep Dive.
5. FAQ
My model is too big for one device — what can I do?
- Use a smaller quantization (Q4_K_M instead of Q8/FP16).
- Limit the context length (
--max-sequence-length) to shrink the KV cache. - Distribute inference across multiple reComputer devices with llama.cpp RPC (tutorial).
Do I need a cloud GPU?
No. Everything above runs fully on-device. Data stays on the edge and there are no recurring API fees.
More resources
GenAI topic overview for reComputer-Jetson
Dataset → train → export → deploy
Troubleshooting and usage questions
One-command deployment repo
