Benchmark of Multistream Inference on Raspberrypi 5 with Hailo8
Introduction
YOLOv8 (You Only Look Once version 8) is the popular most YOLO series of real-time pose estimation and object detection models. It builds upon the strengths of its predecessors by introducing several advancements in speed, accuracy, and flexibility. The Hailo8 is used to accelerate inference speed, featuring a 26 TOPS AI performance.
This wiki showcases benchmarking of YOLOv8m for object detection on Raspberry Pi 5 with hailo8. All tests utilize the same model (YOLOv8m), quantized to int8, with an input size of 640x640 resolution, batch size set to 8.
Prepare Hardware
reComputer AI R2140reComputer Industrial R20xxreComputer Industrial R21xx
Install AI kit on RPi5
Please refer to this
Prepare software
update the system
sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
sudo apt update
sudo apt full-upgrade
Download hailo software on hailo office web
Note: you need an official Hailo account and ensure you are logged in. Click this link download the necessary libs as follows:
Install hailort_4.19.0_arm64.deb on respberrypi5
sudo dpkg -i hailort_4.19.0_arm64.deb
sudo reboot
Install dkms
sudo apt-get install dkms
Install hailort-pcie-driver_4.19.0_all.deb
sudo dpkg -i hailort-pcie-driver_4.19.0_all.deb
sudo reboot
Create and activate a Python virtual environment
python -m venv hailo_env
source hailo_env/bin/activate
Install hailort-4.19.0-cp311-cp311-linux_aarch64.whl
pip install hailort-4.19.0-cp311-cp311-linux_aarch64.whl
Check if the software is installed
hailortcli fw-control identify
The result is show as bellow:
ain@pi5-hailo:~ $ hailortcli fw-control identify
Executing on device: 0000:01:00.0
Identifying board
Control Protocol Version: 2
Firmware Version: 4.19.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
Serial Number: HLLWM2B225100548
Part Number: HM218B1C2FAE
Product Name: HAILO-8 AI ACC M.2 M KEY MODULE EXT TEMP
Set pcie to gen2/gen3(gen3 is faster than gen2)
Add following text to /boot/firmware/config.txt
#Enable the PCIe external connector
dtparam=pciex1
#Force Gen 3.0 speeds
dtparam=pciex1_gen=3
note
If you want to use gen2,please comment dtparam=pciex1_gen=3
Install Tapps
Install necessary libs
sudo apt-get install -y rsync ffmpeg x11-utils python3-dev python3-pip python3-setuptools python3-virtualenv python-gi-dev libgirepository1.0-dev gcc-12 g++-12 cmake git libzmq3-dev
sudo apt-get install -y libopencv-dev python3-opencv
sudo apt-get install -y libcairo2-dev libgirepository1.0-dev libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-bad1.0-dev gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly gstreamer1.0-libav gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio gcc-12 g++-12 python-gi-dev
sudo apt install python3-gi python3-gi-cairo gir1.2-gtk-3.0
Set hailo_pci force_desc_page_size
sudo nano /etc/modprobe.d/hailo_pci.conf
And then input the following content.
options hailo_pci force_desc_page_size=4096
Finally, press Ctrl+X, type Y, and press Enter to save the file
And then reboot the raspberrypi5
sudo reboot
Download Tapps
git clone --depth 1 https://github.com/hailo-ai/tappas.git
Download hailort to tapps
cd tappas
mkdir hailort
git clone https://github.com/hailo-ai/hailort.git hailort/sources
Change common.py
nano downloader/common.py
And change the content like below, add RaspberryPI5 = 'rpi5'in common.py:
class Platform(Enum):
X86 = 'x86'
ARM = 'arm'
IMX8 = 'imx8'
Rockchip = 'rockchip'
RaspberryPI = 'rpi'
ANY = 'any'
def __str__(self):
return self.value
Install tappas
./install.sh --skip-hailort --target-platform rpi5
Change batch size to 8
cd ./apps/h8/gstreamer/general/multistream_detection/
nano multi_stream_detection.sh
Add readonly DEFAULT_BATCH_SIZE=8 to the 14 line as follows:
readonly DEFAULT_NETWORK_NAME="yolov5"
readonly MAX_NUM_OF_DEVICES=4
Add batch_size=$DEFAULT_BATCH_SIZE to the 19 line as follows:
network_name=$DEFAULT_NETWORK_NAME
num_of_src=12
Add batch-size=$batch_size to the 154 line as follows:
queue name=hailo_pre_infer_q_0 leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
hailonet hef-path=$hef_path batch-size=$batch_size device-count=$device_count scheduling-algorithm=0 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 ! \
queue name=hailo_postprocess0 leaky=no max-size-buffers=30 max-size-bytes=0 max-size-time=0 ! \
Finally Ctrl+X and input Y to save the file.
Run multistream inference
sudo chmod +x multi_stream_detection.sh
./multi_stream_detection.sh --network yolov8 --num-of-sources 8 --show-fps
Result
All the results are based on inference with a model input size of 640x640, batch size is 8, and a video resolution of 1280x760, which is 720p.
Channel CountPCIE Gen2 PerformancePCIE Gen3 Performance
1 channel stream39.82FPS76.99FPS
2 channels streams19.86FPS38.21FPS
4 channels streams8.45FPS16.94FPS
8 channels streams3.85FPS8.15FPS
12 channels streams2.94FPS5.43FPS
