蜂鸣器
SenseCAP Indicator 的内置蜂鸣器是一个无源蜂鸣器,这意味着它需要交流信号(PWM)来触发并输出声音,您可以生成各种音调和效果。
基础
#include <Arduino.h>
#define Buzzer 19 //蜂鸣器 GPIO
digitalWrite(Buzzer, OUTPUT); //将蜂鸣器设置为输出
analogWrite(Buzzer, 127); //生成50%占空比的PWM
digitalWrite(Buzzer, LOW); //关闭蜂鸣器
示例代码 1
此示例使用蜂鸣器播放旋律。它向蜂鸣器发送适当频率的方波,生成相应的音调。 "一闪一闪小星星..."
int length = 15; /* 音符数量 */
char notes[] = "ccggaagffeeddc ";
int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 };
int tempo = 300;
//将蜂鸣器引脚设置为输出
pinMode(19, OUTPUT);
for(int i = 0; i < length; i++) {
if(notes[i] == ' ') {
delay(beats[i] * tempo);
} else {
playNote(notes[i], beats[i] * tempo);
delay(tempo / 2); /* 音符之间的延迟 */
//播放音调
void playTone(int tone, int duration) {
for (long i = 0; i < duration * 1000L; i += tone * 2) {
digitalWrite(19, HIGH);
delayMicroseconds(tone);
digitalWrite(19, LOW);
void playNote(char note, int duration) {
char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 };
// 播放与音符名称对应的音调
for (int i = 0; i < 8; i++) {
if (names[i] == note) {
playTone(tones[i], duration);
示例代码 2
此示例演示当CO2值大于1000ppm时的报警功能。
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SensirionI2CScd4x.h>
SensirionI2CScd4x scd4x;
String SDDataString = "";
void sensor_power_on(void) {
pinMode(18, OUTPUT);
digitalWrite(18, HIGH);
void sensor_scd4x_init(void) {
uint16_t error;
char errorMessage[256];
scd4x.begin(Wire);
// 停止可能之前启动的测量
error = scd4x.stopPeriodicMeasurement();
if (error) {
Serial.print("Error trying to execute stopPeriodicMeasurement(): ");
Serial.println(errorMessage);
// 开始测量
error = scd4x.startPeriodicMeasurement();
if (error) {
Serial.print("Error trying to execute startPeriodicMeasurement(): ");
void sensor_scd4x_get(void) {
uint16_t error;
Serial.print("sensor scd4x: ");
// 读取测量值
uint16_t co2;
float temperature;
float humidity;
error = scd4x.readMeasurement(co2, temperature, humidity);
if (error) {
Serial.print("Error trying to execute readMeasurement(): ");
} else if (co2 == 0) {
Serial.println("Invalid sample detected, skipping.");
} else {
Serial.print("Co2:");
Serial.print(co2);
Serial.print("\t");
Serial.print("Temperature:");
Serial.print(temperature);
Serial.print("\t");
Serial.print("Humidity:");
Serial.println(humidity);
if( co2 > 1000 ) {
analogWrite(Buzzer, 10);
} else {
analogWrite(Buzzer, 0);
int cnt = 0;
sensor_power_on();
Wire.setSDA(20);
Wire.setSCL(21);
Wire.begin();
sensor_scd4x_init();
delay(5000);
sensor_scd4x_get();
技术支持
别担心,我们为您提供支持!请访问我们的 Seeed 官方 Discord 频道 来提出您的问题!
如果您有大批量订单或定制需求,请联系 [email protected]
