麦克风入门指南
本教程介绍如何在 Wio Terminal 中使用内置麦克风进行音频输入。麦克风可用于检测周围声音并做出相应响应。
note
本教程仅演示麦克风的基本功能,我们正在为 Wio Terminal 开发麦克风库以实现更多功能!敬请期待!
示例代码
注意:WIO_MIC 是为内置麦克风定义的。
pinMode(WIO_MIC, INPUT);
int val = analogRead(WIO_MIC);
Serial.println(val);
delay(200);
带 LCD 屏幕的示例代码
库安装
#include"seeed_line_chart.h" //include the library
#include <math.h>
TFT_eSPI tft;
#define max_size 50 //maximum size of data
doubles data; //Initilising a doubles type to store data
TFT_eSprite spr = TFT_eSprite(&tft); // Sprite
tft.begin();
tft.setRotation(3);
spr.createSprite(TFT_HEIGHT,TFT_WIDTH);
spr.fillSprite(TFT_DARKGREY);
if (data.size() == max_size) {
data.pop();//this is used to remove the first read variable
data.push(val); //read variables and store in data
//Settings for the line graph title
auto header = text(0, 0)
.value("Microphone Reading")
.align(center)
.color(TFT_WHITE)
.valign(vcenter)
.width(tft.width())
.thickness(2);
header.height(header.font_height() * 2);
header.draw(); //Header height is the twice the height of the font
auto content = line_chart(20, header.height()); //(x,y) where the line graph begins
content
.height(tft.height() - header.height() * 1.5) //actual height of the line chart
.width(tft.width() - content.x() * 2) //actual width of the line chart
.based_on(0.0) //Starting point of y-axis, must be a float
.show_circle(true) //drawing a cirle at each point, default is on.
.y_role_color(TFT_WHITE)
.x_role_color(TFT_WHITE)
.value(data) //passing through the data to line graph
.color(TFT_RED) //Setting the color for the line
.draw();
spr.pushSprite(0, 0);
delay(50);
