将 Wio Terminal 用作鼠标
本教程介绍如何将 Wio Terminal 用作简单的鼠标。这可以用来模拟鼠标的上、下、左、右移动。此外,还可以实现左/右鼠标按钮点击、上/下滚动等功能。
安装库​
此示例还需要一个额外的 Arduino 鼠标库:
  1. 访问 Arduino Mouse Library 仓库,将整个仓库下载到本地驱动器。
  2. 现在,可以将库安装到 Arduino IDE 中。打开 Arduino IDE,点击 sketch -> Include Library -> Add .ZIP Library,选择刚刚下载的 Mouse-master 文件。
InstallLibrary
完整代码​
请查看以下代码或从 github 这里 获取。此外,如需更多功能,请参考 Arduino 官方的 鼠标函数。
* Wio Terminal 通过按钮模拟鼠标的演示程序。
* 包括鼠标上移、鼠标下移、鼠标左移、鼠标右移、
* 点击鼠标左键、点击鼠标右键、
* 向上滚动、向下滚动等功能。
* Copyright (c) 2020 seeed technology co., ltd.
* Author : weihong.cai (weihong.cai@seeed.cc)
* Create Time : July 2020
* Change Log :
* The MIT License (MIT)
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software istm
* furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
* AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
* OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS INcommInterface
* THE SOFTWARE.
* 使用方法(在 Wio Terminal 上):
* 按下 WIO_5S_UP --------------------> 鼠标上移
* 按下 WIO_5S_DOWN --------------------> 鼠标下移
* 按下 WIO_5S_LEFT --------------------> 鼠标左移
* 按下 WIO_5S_RIGHT --------------------> 鼠标右移
* 按下 BUTTON_3 ------------------------> 点击鼠标左键
* 按下 BUTTON_2 ------------------------> 点击鼠标右键
* 按下 WIO_5S_PRESS 和 WIO_5S_UP ----> 向上滚动
* 按下 WIO_5S_PRESS 和 WIO_5S_DOWN ----> 向下滚动
* 一些提示:
* 1. 如果您的 PC 无法识别 USB 设备导致 Wio Terminal 无法工作。
* 您可以通过更新 ArduinoCore 来解决这个问题。
* 请参考: https://forum.seeedstudio.com/t/seeeduino-xiao-cant-simulate-keys-pressed/252819/6?u=weihong.cai
* 您可以从这里了解更多关于 Wio Terminal 的信息: https://wiki.seeedstudio.com/cn/Wio-Terminal-Getting-Started/
* 如果您有任何问题,可以在论坛留言: https://forum.seeedstudio.com
#include "Mouse.h"
/*----------------定义按钮引脚---------------------------*/
const int upButton = WIO_5S_UP;
const int downButton = WIO_5S_DOWN;
const int leftButton = WIO_5S_LEFT;
const int rightButton = WIO_5S_RIGHT;
const int mouseWheel = WIO_5S_PRESS;
const int mouseBttonLeft = BUTTON_3;
const int mouseBttonRight = BUTTON_2;
// X 或 Y 移动的输出范围;影响移动速度
int range = 2;
// 鼠标的响应延迟,单位为毫秒
int responseDelay = 5;
// 时间记录参数
unsigned long _currentMillis;
unsigned long _previousMillis;
// 初始化按钮输入:
pinMode(upButton, INPUT);
pinMode(downButton, INPUT);
pinMode(leftButton, INPUT);
pinMode(rightButton, INPUT);
pinMode(mouseWheel, INPUT);
pinMode(mouseBttonLeft, INPUT);
pinMode(mouseBttonRight, INPUT);
// 初始化鼠标控制:
Mouse.begin();
// 读取按钮状态:
int upState = digitalRead(upButton);
int downState = digitalRead(downButton);
int rightState = digitalRead(rightButton);
int leftState = digitalRead(leftButton);
int clickState_mouseWheel = digitalRead(mouseWheel);
int clickState_mouseButtonLeft = digitalRead(mouseBttonLeft);
int clickState_mouseButtonRight = digitalRead(mouseBttonRight);
// 根据按钮状态计算移动距离:
int xDistance = (leftState - rightState) * range;
int yDistance = (upState - downState) * range;
/*------------------鼠标移动--------------------------------------*/
// 如果 X 或 Y 不为零,则移动:
if ((xDistance != 0) || (yDistance != 0)) {
Mouse.move(xDistance, yDistance, 0);
/*-------------鼠标左键点击------------------------------*/
// 如果鼠标左键被按下:
if (clickState_mouseButtonLeft == LOW) {
// 如果鼠标没有被按下,则按下它:
if (!Mouse.isPressed(MOUSE_LEFT)) {
Mouse.press(MOUSE_LEFT);
//Mouse.click(MOUSE_LEFT);
// 否则鼠标左键没有被按下:
else {
// 如果鼠标被按下,则释放它:
if (Mouse.isPressed(MOUSE_LEFT)) {
Mouse.release(MOUSE_LEFT);
/*-------------鼠标右键点击-----------------------------*/
// 如果鼠标右键被按下:
if (clickState_mouseButtonRight == LOW) {
// 如果鼠标没有被按下,则按下它:
if (!Mouse.isPressed(MOUSE_RIGHT)) {
Mouse.press(MOUSE_RIGHT);
//Mouse.click(MOUSE_RIGHT);
// 否则鼠标右键没有被按下:
else {
// 如果鼠标被按下,则释放它:
if (Mouse.isPressed(MOUSE_RIGHT)) {
Mouse.release(MOUSE_RIGHT);
/*------------------向上滚动----------------------------------------*/
if ((upState == LOW) && (clickState_mouseWheel == LOW)) {
Mouse.move(0, 0, 1);
My_delay(200);
/*------------------向下滚动--------------------------------------*/
if ((downState == LOW) && (clickState_mouseWheel == LOW)) {
Mouse.move(0, 0, -1);
My_delay(200);
// 延迟以防止鼠标移动过快:
My_delay(responseDelay);
// 使用 millis() 的延迟函数
void My_delay(int Time)
while((_currentMillis - _previousMillis) <= Time)
_currentMillis = millis();
_previousMillis = _currentMillis;
