将模型转换为Google Coral的Edge TPU TFlite格式
介绍
Coral M.2 加速器配备双Edge TPU,是一个M.2模块,为具有可用M.2 E-key插槽的现有系统和产品带来两个Edge TPU协处理器。Tensorflow和Pytorch是最受欢迎的深度学习框架。因此,为了使用Edge TPU,我们需要将模型编译为Edge TPU格式。
本wiki文章将指导您完成编译模型并在Google Coral TPU上运行的过程,使您能够利用其功能进行高性能机器学习应用。
准备硬件
安装硬件
转换模型
note
在开始之前,请确保您已按照安装指南将 Google Coral TPU 安装到 Pi 5 上。
- 适用于 Tensorflow 模型
- For Pytorch Model
- For Yolo Model
note
所有过程都已在 Python 3.11.9 上测试过。
安装 Tensorflow
pip install tensorflow
Check tflite_converter
tflite_convert -h
结果应该是这样的:
2024-07-23 10:41:03.750087: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2024-07-23 10:41:04.276520: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:38] TF-TRT Warning: Could not find TensorRT
usage: tflite_convert [-h] --output_file OUTPUT_FILE [--saved_model_dir SAVED_MODEL_DIR | --keras_model_file KERAS_MODEL_FILE] [--saved_model_tag_set SAVED_MODEL_TAG_SET]
[--saved_model_signature_key SAVED_MODEL_SIGNATURE_KEY] [--enable_v1_converter] [--experimental_new_converter [EXPERIMENTAL_NEW_CONVERTER]]
[--experimental_new_quantizer [EXPERIMENTAL_NEW_QUANTIZER]]
Command line tool to run TensorFlow Lite Converter.
optional arguments:
-h, --help show this help message and exit
Full filepath of the output file.
Full path of the directory containing the SavedModel.
Full filepath of HDF5 file containing tf.Keras model.
Comma-separated set of tags identifying the MetaGraphDef within the SavedModel to analyze. All tags must be present. In order to pass in an empty tag set, pass in "". (default "serve")
Key identifying the SignatureDef containing inputs and outputs. (default DEFAULT_SERVING_SIGNATURE_DEF_KEY)
Enables the TensorFlow V1 converter in 2.0
Experimental flag, subject to change. Enables MLIR-based conversion instead of TOCO conversion. (default True)
Experimental flag, subject to change. Enables MLIR-based quantizer instead of flatbuffer conversion. (default True)
将 Tensorflow 模型转换为 TFlite 模型
tflite_convert --saved_model_dir=YOUR_MODEL_PATH --output_file=YOUR_MODEL_NAME.tflite
将 TFlite 模型转换为 Edge TPU 模型
note
在将 tflite 模型转换为 edge tpu 模型之前,您应该优化您的模型,请查看 优化 Tensorflow 模型
安装 edgetpu 编译器
curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | sudo apt-key add -
echo "deb https://packages.cloud.google.com/apt coral-edgetpu-stable main" | sudo tee /etc/apt/sources.list.d/coral-edgetpu.list
sudo apt-get update
sudo apt-get install edgetpu-compiler
edgetpu_compiler YOUR_MODEL_NAME.tflite
然后你应该得到一个名为 YOUR_MODEL_NAME_edgetpu.tflite
的新文件
note
我们不推荐这种方法,因为在实际过程中存在许多冲突的包。而且 TensorFlow Lite 支持的操作集有限,某些 PyTorch 操作可能不被支持。
将 Pytorch 模型转换为 tflite 模型
安装依赖项
pip install -r https://github.com/google-ai-edge/ai-edge-torch/releases/download/v0.1.1/requirements.txt
pip install ai-edge-torch==0.1.1
Convert
import ai_edge_torch
import numpy
import torch
import torchvision
resnet18 = torchvision.models.resnet18(torchvision.models.ResNet18_Weights.IMAGENET1K_V1).eval()
sample_inputs = (torch.randn(1, 3, 224, 224),)
torch_output = resnet18(*sample_inputs)
edge_model = ai_edge_torch.convert(resnet18.eval(), sample_inputs)
edge_model.export('resnet.tflite')
您将获得 resnet.tflite
检查 tflite_converter
note
在将 tflite 模型转换为 edge tup 模型之前,您应该优化您的模型,请查看 优化 Tensorflow 模型
tflite_convert -h
结果应该是这样的:
optional arguments:
Install edgetpu compiler
sudo apt-get update
edgetpu_compiler resnet18.tflite
然后你应该得到一个名为 resnet18_edgetpu.tflite
的新文件
安装 Ultralytics
pip install ultralytics
将 YOLO 模型转换为边缘 TPU 模型
# For example, if you want to convert yolov8n.pt to yolov8n_integer_quant_edgetpu.tflite
yolo export model=yolov8n.pt format=edge int8=True
结果应该像这样:
jiahao@PC:~/yolov8s_saved_model$ ls
assets saved_model.pb yolov8s_float32.tflite yolov8s_full_integer_quant.tflite
fingerprint.pb variables yolov8s_full_integer_quant_edgetpu.log yolov8s_int8.tflite
metadata.yaml yolov8s_float16.tflite yolov8s_full_integer_quant_edgetpu.tflite yolov8s_integer_quant.tflite
是您需要的模型。
您可以使用以下命令将其他 tflite 模型转换为 edge TPU 模型
# For example, you can convert yolov8s_int8.tflite to edge TPU model
edgetpu_compiler yolov8s_int8.tflite
