reComputer 上的 Moonfire NVR
简介
Moonfire-NVR 的设计目标是提供一个易于使用的 NVR 系统,该系统轻量且简约,这意味着它不会像其他更臃肿的商业 NVR 解决方案那样复杂。它强调功能性和简洁性,使用户能够直接从 IP 摄像头录制到文件系统或云存储。
先决条件
硬件要求
reComputer R1125reComputer AI R2130reComputer AI Industrial R2145
reComputer Industrial R20xxreComputer Industrial R21xx
下载 Moonfire
更新系统
请使用以下命令运行。
sudo apt update
sudo apt upgrade -y
下载 docker 和 docker compose
请使用以下命令安装 docker。
wget https://get.docker.com -O get-docker.sh
chmod +x
sudo sh get-docker.sh
sudo systemctl start docker
sudo systemctl enable docker
docker --version
结果如下所示:
请使用以下命令安装 docker compose。
sudo curl -L "https://github.com/docker/compose/releases/download/$(curl -s https://api.github.com/repos/docker/compose/releases/latest | jq -r .tag_name)/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose
sudo chmod +x /usr/local/bin/docker-compose
docker-compose --version
结果如下所示:
创建 docker-compose.yaml
请使用以下命令识别您的 IDUID
id
结果如下所示。
请使用以下命令创建 docker-compose.yaml
cd ~ && nano docker-compose.yaml
注意:根据您自己的 IDUID 重写 YAML 文件。
然后将以下内容输入到 YAML 文件中。
services:
moonfire-nvr:
# The `vX.Y.Z` images will work on any architecture (x86-64, arm, or
# aarch64); just pick the correct version.
image: ghcr.io/scottlamb/moonfire-nvr:v0.7.23
command: run
volumes:
# Pass through `/var/lib/moonfire-nvr` from the host.
- "/var/lib/moonfire-nvr:/var/lib/moonfire-nvr"
# Pass through `/etc/moonfire-nvr.toml` from the host.
# Be sure to create `/etc/moonfire-nvr.toml` first (see below).
# Docker will "helpfully" create a directory by this name otherwise.
- "/etc/moonfire-nvr.toml:/etc/moonfire-nvr.toml:ro"
# Pass through `/var/tmp` from the host.
# SQLite expects to be able to create temporary files in this dir, which
# is not created in Moonfire's minimal Docker image.
# See: <https://www.sqlite.org/tempfiles.html>
- "/var/tmp:/var/tmp"
# Add additional mount lines here for each sample file directory
# outside of /var/lib/moonfire-nvr, e.g.:
# - "/media/nvr:/media/nvr"
# The Docker image doesn't include the time zone database; you must mount
# it from the host for Moonfire to support local time.
- "/usr/share/zoneinfo:/usr/share/zoneinfo:ro"
# Edit this to match your `moonfire-nvr` user.
# Note that Docker will not honor names from the host here, even if
# `/etc/passwd` is passed through.
# - Be sure to run the `useradd` command below first.
# - Then run `echo $(id -u moonfire-nvr):$(id -g moonfire-nvr)` to see
# what should be filled in here.
user: "1000:1000"
# Uncomment this if Moonfire fails with `clock_gettime failed` (likely on
# older 32-bit hosts). <https://github.com/moby/moby/issues/40734>
# security_opt:
# - seccomp:unconfined
environment:
# Edit zone below to taste.
TZ: "America/Los_Angeles"
RUST_BACKTRACE: 1
# docker's default log driver won't rotate logs properly, and will throw
# away logs when you destroy and recreate the container. Using journald
# solves these problems.
# <https://docs.docker.com/config/containers/logging/configure/>
logging:
driver: journald
options:
tag: moonfire-nvr
restart: unless-stopped
ports:
- "8080:8080/tcp"
请使用以下命令更改权限。
sudo chmod -R 777 /var/lib/moonfire-nvr
创建 /etc/moonfire-nvr.toml
请使用以下命令创建 /etc/moonfire-nvr.toml
sudo nano /etc/moonfire-nvr.toml
然后将以下内容输入到 toml 文件中。
ain@AI-Box:~ $ sudo cat /etc/moonfire-nvr.toml
[[binds]]
ipv4 = "0.0.0.0:8080"
allowUnauthenticatedPermissions = { viewVideo = true }
[[binds]]
unix = "/var/lib/moonfire-nvr/sock"
ownUidIsPrivileged = true
配置 Moonfire
运行 docker compose
请使用以下命令初始化数据库。
sudo docker compose run --rm moonfire-nvr init
结果如下所示。
创建文件夹
请创建一个文件夹来保存视频录制:
sudo mkdir -p /var/lib/moonfire-nvr/recordings
sudo chown 1000:1000 /var/lib/moonfire-nvr/recordings
运行交互式配置
sudo docker compose run --rm moonfire-nvr config 2>debug-log
请按照以下步骤添加文件夹。
请按照以下步骤添加摄像头。
运行 Moonfire NVR
请使用以下命令运行 Moonfire NVR。
sudo docker compose up --detach moonfire-nvr
然后,在您的设备上打开 localhost:8080 端口进行访问。结果如下所示:
注意:不要忘记点击左上角的选项。
结果
一旦我们配置好所有内容,就可以查看当前摄像头的实时画面。
