Connect to TTN
The Things Stack(TTS) is a LoRaWAN® Network Server stack which is the critical component for any LoRaWAN solution. In this chapter we will guide users to connect the Wio Tracker 1110 Dev Board to the Things Network.
Configure the Dev Board​
Before connecting to the TTS, you need to configure the basic parameters of your board on SenseCAP Mate APP, check Get Started for more details.
  • Set the platform to TTN, and then copy the Device EUI/APP EUI/APP Key.
Configure The Things Stack​
Step 1: Create an application​
Navigate to Applications page, click "+Create application".
Enter an Application ID, click Create Application to save your changes.
Step 2: Register the Device​
Paste the Device EUI/APP EUI/APP Key, and select the frequency plan according to your device, and then click Register end device.
The JoinEUI formerly called AppEUI, they are the same.
Step 3: Configure the decoder​
Navigate to Payload formatters, select Formatter type to Custom Javasript formatter, then copy the following code:
For TTN
function decodeUplink (input) {
const bytes = input['bytes']
const fport = parseInt(input['fPort'])
const bytesString = bytes2HexString(bytes)
const originMessage = bytesString.toLocaleUpperCase()
const decoded = {
valid: true,
err: 0,
payload: bytesString,
messages: []
if (fport === 199 || fport === 192) {
decoded.messages.push({fport: fport, payload: bytesString})
return { data: decoded }
if (fport !== 5) {
decoded.valid = false
let measurement = messageAnalyzed(originMessage)
if (measurement.length === 0) {
for (let message of measurement) {
if (message.length === 0) {
continue
let elements = []
for (let element of message) {
if (element.errorCode) {
decoded.err = element.errorCode
decoded.errMessage = element.error
} else {
elements.push(element)
if (elements.length > 0) {
decoded.messages.push(elements)
// decoded.messages = measurement
function messageAnalyzed (messageValue) {
try {
let frames = unpack(messageValue)
let measurementResultArray = []
for (let i = 0; i < frames.length; i++) {
let item = frames[i]
let dataId = item.dataId
let dataValue = item.dataValue
let measurementArray = deserialize(dataId, dataValue)
measurementResultArray.push(measurementArray)
return measurementResultArray
} catch (e) {
return e.toString()
function unpack (messageValue) {
let frameArray = []
for (let i = 0; i < messageValue.length; i++) {
let remainMessage = messageValue
let dataId = remainMessage.substring(0, 2).toUpperCase()
let dataValue
let dataObj = {}
let packageLen
switch (dataId) {
case '12':
packageLen = getInt(remainMessage.substring(8, 10)) * 2 + 10
if (remainMessage.length < packageLen) {
return frameArray
dataValue = remainMessage.substring(2, 8) + remainMessage.substring(10, packageLen)
messageValue = remainMessage.substring(packageLen)
dataObj = {
'dataId': dataId, 'dataValue': dataValue
break
case '13':
packageLen = 24
return frameArray
dataValue = remainMessage.substring(2, packageLen)
dataObj = {
break
case '14':
packageLen = 74
return frameArray
dataObj = {
break
case '15':
packageLen = 60
return frameArray
dataObj = {
break
case '16':
packageLen = 18
return frameArray
dataObj = {
break
case '17':
let byteCount = parseInt(remainMessage.substring(2, 4), 16)
packageLen = getInt(remainMessage.substring(2, 4)) * 2
return frameArray
dataValue = remainMessage.substring(4, packageLen)
if (isNaN(byteCount) || byteCount < 13 || (byteCount - 9) % 4 !== 0 || byteCount > 49) {
continue
dataObj = {
break
case '18':
packageLen = 56
return frameArray
dataObj = {
break
default:
return frameArray
if (dataValue.length < 2) {
break
frameArray.push(dataObj)
return frameArray
function deserialize (dataId, dataValue) {
let measurementArray = []
let eventList = []
let measurement = {}
let collectTime = parseInt(new Date().getTime() / 1000)
let groupId = 0
let shardFlag = {}
let payload = ''
let value
let result = []
let dataArr = []
switch (dataId) {
case '12':
shardFlag = getShardFlag(dataValue.substring(0, 2))
groupId = getInt(dataValue.substring(2, 6))
payload = dataValue.substring(6)
measurement = {
measurementId: '6152',
groupId: groupId,
index: shardFlag.index,
count: shardFlag.count,
type: 'gnss-ng payload',
measurementValue: payload
measurementArray.push(measurement)
break
case '13':
collectTime = getUTCTimestamp(dataValue.substring(8, 16))
shardFlag = getShardFlag(dataValue.substring(16, 18))
groupId = getInt(dataValue.substring(18, 22))
measurementArray.push({
measurementId: '4200',
timestamp: collectTime,
motionId: getMotionId(dataValue.substring(6, 8)),
groupId: groupId,
type: 'Event Status',
measurementValue: getEventStatus(dataValue.substring(0, 6))
break
case '14':
{measurementId: '4200', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Event Status', measurementValue: getEventStatus(dataValue.substring(0, 6))},
{measurementId: '5001', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'Wi-Fi Scan', measurementValue: getMacAndRssiObj(dataValue.substring(16, 72))}
break
case '15':
{measurementId: '5002', timestamp: collectTime, motionId: getMotionId(dataValue.substring(6, 8)), type: 'BLE Scan', measurementValue: getMacAndRssiObj(dataValue.substring(16, 58))},
break
case '16':
measurementId: '3576',
type: 'Positioning Status',
measurementValue: getPositingStatus(dataValue.substring(0, 2))
measurementValue: getEventStatus(dataValue.substring(2, 8))
break
case '17':
collectTime = getUTCTimestamp(dataValue.substring(6, 14))
value = getUnsignedSensorValue(dataValue.substring(0, 6))
if (value !== null) {
measurementId: '4208',
measureTime: collectTime,
type: 'Custom Event Status',
measurementValue: value
let initId = 4165
for (let i = 14; i < dataValue.length; i += 8) {
value = getUnsignedSensorValue(dataValue.substring(i, i + 8))
measurementId: initId++,
type: 'Custom Measurement Type',
break
case '18':
value = getSignSensorValue(dataValue.substring(14, 18), 10)
measurementId: '4097',
type: 'Air Temperature',
value = getUnsignedSensorValue(dataValue.substring(18, 20), 1)
measurementId: '4098',
type: 'Air Humidity',
value = getUnsignedSensorValue(dataValue.substring(20, 26), 1)
measurementId: '4101',
type: 'Barometric Pressure',
value = getUnsignedSensorValue(dataValue.substring(26, 30), 1)
measurementId: '4115',
type: 'Distance',
value = getUnsignedSensorValue(dataValue.substring(30, 34), 100)
measurementId: '4190',
type: 'UV Index',
value = getUnsignedSensorValue(dataValue.substring(34, 38), 1)
measurementId: '4206',
type: 'VOC_INDEX',
value = getUnsignedSensorValue(dataValue.substring(38, 42), 1)
measurementId: '4207',
type: 'Noise',
value = getSignSensorValue(dataValue.substring(42, 46), 100)
measurementId: '4150',
type: ' AccelerometerX',
value = getSignSensorValue(dataValue.substring(46, 50), 100)
measurementId: '4151',
type: 'AccelerometerY',
value = getSignSensorValue(dataValue.substring(50, 54), 100)
measurementId: '4152',
type: 'AccelerometerZ',
break
return measurementArray
function getMotionId (str) {
return getInt(str)
function getPositingStatus (str) {
let status = getInt(str)
switch (status) {
case 0:
return {id:status, statusName:"Positioning successful."}
case 1:
return {id:status, statusName:"The GNSS scan timed out and failed to obtain the location."}
case 2:
return {id:status, statusName:"The Wi-Fi scan timed out and failed to obtain the location."}
case 3:
return {id:status, statusName:"The Wi-Fi + GNSS scan timed out and failed to obtain the location."}
case 4:
return {id:status, statusName:"The GNSS + Wi-Fi scan timed out and failed to obtain the location."}
case 5:
return {id:status, statusName:"The Bluetooth scan timed out and failed to obtain the location."}
case 6:
return {id:status, statusName:"The Bluetooth + Wi-Fi scan timed out and failed to obtain the location."}
case 7:
return {id:status, statusName:"The Bluetooth + GNSS scan timed out and failed to obtain the location."}
case 8:
return {id:status, statusName:"The Bluetooth + Wi-Fi + GNSS scan timed out and failed to obtain the location."}
case 9:
return {id:status, statusName:"Location Server failed to parse the GNSS location."}
case 10:
return {id:status, statusName:"Location Server failed to parse the Wi-Fi location."}
case 11:
return {id:status, statusName:"Location Server failed to parse the Bluetooth location."}
case 12:
return {id:status, statusName:"Failed to parse the GNSS location due to the poor accuracy."}
case 13:
return {id:status, statusName:"Time synchronization failed."}
case 14:
return {id:status, statusName:"Failed to obtain location due to the old Almanac."}
return getInt(str)
function getShardFlag (str) {
let bitStr = getByteArray(str)
return {
count: parseInt(bitStr.substring(0, 4), 2),
index: parseInt(bitStr.substring(4), 2)
function bytes2HexString (arrBytes) {
var str = ''
for (var i = 0; i < arrBytes.length; i++) {
var tmp
var num = arrBytes[i]
if (num < 0) {
tmp = (255 + num + 1).toString(16)
} else {
tmp = num.toString(16)
if (tmp.length === 1) {
tmp = '0' + tmp
str += tmp
return str
function loraWANV2DataFormat (str, divisor = 1) {
let strReverse = bigEndianTransform(str)
let str2 = toBinary(strReverse)
if (str2.substring(0, 1) === '1') {
let arr = str2.split('')
let reverseArr = arr.map((item) => {
if (parseInt(item) === 1) {
return 0
} else {
return 1
str2 = parseInt(reverseArr.join(''), 2) + 1
return '-' + str2 / divisor
return parseInt(str2, 2) / divisor
function bigEndianTransform (data) {
let dataArray = []
for (let i = 0; i < data.length; i += 2) {
dataArray.push(data.substring(i, i + 2))
return dataArray
function toBinary (arr) {
let binaryData = arr.map((item) => {
let data = parseInt(item, 16)
.toString(2)
let dataLength = data.length
if (data.length !== 8) {
for (let i = 0; i < 8 - dataLength; i++) {
data = `0` + data
return data
return binaryData.toString().replace(/,/g, '')
function getMacAndRssiObj (pair) {
let pairs = []
if (pair.length % 14 === 0) {
for (let i = 0; i < pair.length; i += 14) {
let mac = getMacAddress(pair.substring(i, i + 12))
if (mac) {
let rssi = getInt8RSSI(pair.substring(i + 12, i + 14))
pairs.push({mac: mac, rssi: rssi})
} else {
continue
return pairs
function getMacAddress (str) {
if (str.toLowerCase() === 'ffffffffffff') {
return null
let macArr = []
for (let i = 1; i < str.length; i++) {
if (i % 2 === 1) {
macArr.push(str.substring(i - 1, i + 1))
let mac = ''
for (let i = 0; i < macArr.length; i++) {
mac = mac + macArr[i]
if (i < macArr.length - 1) {
mac = mac + ':'
return mac
function getInt8RSSI (str) {
return loraWANV2DataFormat(str)
function getInt (str) {
return parseInt(str, 16)
function getEventStatus (str) {
// return getInt(str)
let bitArr = []
for (let i = 0; i < bitStr.length; i++) {
bitArr[i] = bitStr.substring(i, i + 1)
bitArr = bitArr.reverse()
let event = []
for (let i = 0; i < bitArr.length; i++) {
if (bitArr[i] !== '1') {
continue
switch (i){
case 0:
event.push({id:1, eventName:"Start moving event."})
break
case 1:
event.push({id:2, eventName:"End movement event."})
break
case 2:
event.push({id:3, eventName:"Motionless event."})
break
case 3:
event.push({id:4, eventName:"Shock event."})
break
case 4:
event.push({id:5, eventName:"Temperature event."})
break
case 5:
event.push({id:6, eventName:"Light event."})
break
case 6:
event.push({id:7, eventName:"SOS event."})
break
case 7:
event.push({id:8, eventName:"Press once event."})
break
return event
function getByteArray (str) {
let bytes = []
for (let i = 0; i < str.length; i += 2) {
bytes.push(str.substring(i, i + 2))
return toBinary(bytes)
function getUTCTimestamp(str){
return parseInt(loraWANV2PositiveDataFormat(str)) * 1000
function getUnsignedSensorValue (str, dig = 1) {
if (isNull(str)) {
return null
return parseInt(str, 16) / dig
function isNull (str) {
if (str.substring(0, 1) !== '8') {
return false
if (str.substring(i, i + 1) !== '0') {
return false
return true
function getSignSensorValue (str, dig = 1) {
if (isNull(str)) {
return null
return loraWANV2DataFormat(str, dig)
function loraWANV2PositiveDataFormat (str, divisor = 1) {
Step 4: Check the data​
When the device tries to connect to the network, the breathing light will flash. If the device joins the network successfully, the breathing light will flash quickly, and there will be a light and cheerful melody.
Then you can check the data on the TTS console.
Resource​
TTN decoder for Wio Tracker 1110 Dev Board
