Connect Wio Tracker to LoRa Cloud™ Locator
This document details the step-by-step instructions on how to set up the Wio Tracker 1110 Dev Board and configure it in the LoRa Cloud™ Locator.
Gateway Settings
Add the Gateway on LoRa Cloud™ Locator
Login to LoRa Cloud™ Locator web.
Navigate to GATEWAY SETTINGS, click Add New Gateway.
Enter the Gateway EUI and select the right LoRaWAN® frequency band based on your location.
Click on Create and you should see a popup with new Gateway’s supporting files(certificates, keys). Make sure you click on Download and save the files to a safe location (you might need to allow browser to download multiple files). The downloaded files are:
- cups_url.txt: Contains the URL that should be used in your gateway to point to the CUPS server
- cups.trust: Contain the CUPS trust certificate
- cups.crt: Contain the certificate used to connect to CUPS server
- cups.key: Contain the private key used to connect to CUPS server
Set up the Gateway
Then we need to configure the SenseCAP M2 Multi-Platform LoRaWAN Indoor Gateway, check Get Started for more details.
Login to Luci page, navigate to LoRa > LoRa Network
- Step 1: LoRa Network Settings Navigate to LoRa > LoRa Network
- Step 2:Set Mode to Basics Station
- Step 3:Basic Station Settings:
Gateway EUI: It will automatically get the EUI of the connected gateway
Server: Select CUPS
URL:: Copy the URL in your
cups_url.txtfile.
Example: https://A321**0HK3U1DZL.cups.lorawan.eu-west-1.amazonaws.com:443
Authentication Mode: TLS Server and Client Authentication
trust/certificate/key : Copy the file contect we downloaded before.
Click Save & Apply once everything is set up.
Once your gateway is properly configured, its status should switch to Connected.
Device Settings
Set up the device
Please check Connect Wio Tracker 1110 Dev Board to TTN to select the platform to TTN.
Add device on LoRa Cloud™ Locator
Then go back to the LoRa Cloud™ Locator web page, navigate to DEVICE SETTINGS, click Add New Device.
Tracker type: LoRa Basics™ Modem SDK
Choose the APPKey as the activation mode, then copy the Dev EUI, Join EUI and APP key we defined before.
Network: The Things Network Community, and select your regional cluster, then click Create to add your device.
Once the device successfully joins the network, you can see its messages here。
Then navigate to TRACKING, you can check the location now.
