🚨 Problem Description
Even without modifying any Jetson kernel-related content, the Jetson device encounters a UUID-related error during boot and enters the recovery terminal. This issue prevents normal system startup and requires manual intervention to resolve.
🔍 Symptoms
Unable to Access User Partition (UUID Error)
Initially, the system mysteriously fails to mount the user partition, resulting in continuous boot failures as shown in the image below:
System Enters Recovery Mode
The system then abnormally enters Recovery mode (rescue terminal):
This issue typically occurs when the boot process encounters corrupted system files or incorrect partition flags, causing the system to fail normal startup and drop into a recovery shell environment. The UUID error indicates that the system cannot properly identify or mount the root filesystem, which is essential for normal operation.
🛠️ Solutions
Method 1: Clear OTA Flags and Replace initrd File
Possible Cause: The /boot/initrd image file is corrupted, causing the boot process to be interrupted.
Symptoms: The system cannot enter the normal OS during startup and repeatedly enters Recovery mode, dropping into the bash-5.1# shell.
Step 1: Mount EFI Variables in Recovery Terminal
First, mount the EFI variables filesystem in the recovery terminal:
mount -t efivarfs efivarfs /sys/firmware/efi/efivars
Step 2: Clear OTA Flag Variables
In the bash-5.1# shell environment, remove and delete the OTA flag bits:
1. Remove and clear L4T default boot mode flag:
chattr -i /sys/firmware/efi/efivars/L4TDefaultBootMode-781e084c-a330-417c-b678-38e696380cb9
rm /sys/firmware/efi/efivars/L4TDefaultBootMode-781e084c-a330-417c-b678-38e696380cb9
2. Remove and clear partition A status flag:
chattr -i /sys/firmware/efi/efivars/RootfsStatusSlotA-781e084c-a330-417c-b678-38e696380cb9
rm /sys/firmware/efi/efivars/RootfsStatusSlotA-781e084c-a330-417c-b678-38e696380cb9
3. Remove and clear partition B status flag:
chattr -i /sys/firmware/efi/efivars/RootfsStatusSlotB-781e084c-a330-417c-b678-38e696380cb9
rm /sys/firmware/efi/efivars/RootfsStatusSlotB-781e084c-a330-417c-b678-38e696380cb9
Step 3: Power Down the System
After clearing the erroneous flag bits, shut down and power off the Jetson device.
Step 4: Replace the /boot/initrd File
Replace the /boot/initrd file using an SSD enclosure to connect the Jetson's SSD to a PC. It's recommended to backup the old initrd file before replacement.
Detailed Steps:
- Remove the drive: Take the SSD out of the development board and connect it to a PC (Linux environment) using an SSD enclosure.
- Mount the partition: Mount the system root partition (RootFS) from the SSD.
- Replace the file:
- a. Locate the
/boot/initrdfile in the mount point. - b. Replace it with a new, verified working initrd image (or a newly compiled image).
- a. Locate the
- Recovery test: Reinstall the SSD back into the development board and power it on.
Download Links for initrd Files:
🔗 L4T 36.4.0 (JetPack 6.1): Click to download
🔗 L4T 36.4.3 (JetPack 6.2): Click to download
🔗 L4T 36.4.4 (JetPack 6.2.1): Click to download
Step 5: Restart the Jetson
After completing the file replacement, restart the Jetson device.
🔄 Method 2: Fresh Installation Approach
Prepare a
The content on the old SSD will remain intact and should now boot properly.
