Deploy DeepSeek on Raspberry Pi AI Box & Industrial box
Introduction
This wiki explains how to deploy the DeepSeek model on a Raspberry Pi AI Box using the Ollama deployment framework. Ollama simplifies the process of installing and running AI models on compact hardware like the Raspberry Pi, handling dependency management and system configuration. In this guide, you will find clear, step-by-step instructions on setting up your environment, installing the necessary software, and launching the DeepSeek model. This resource is aimed at developers and AI enthusiasts who want to harness the power of AI on low-power devices.
Prepare Hardware
| reComputer AI R2130 | reComputer AI Industrial R2145 | reComputer Industrial R20xx | reComputer Industrial R21xx |
Prepare software
update the system:
sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
sudo apt update
sudo apt full-upgrade
Install Ollama
Open one terminal with Ctrl+Alt+T and input command like below to install ollama:
curl -fsSL https://ollama.com/install.sh | sh
Install and run deepseek model
Then input command like below to install and run deepseek 7b model:
ollama run deepseek-r1
Result
In this demonstration, I used the DeepSeek 1.5b model. You can choose which model to use based on your needs and the capacity of your hardware.
