Driving reTerminal D1001 Microphone
Introduction​
This wiki shows how to drive the I2S microphone on reTerminal D1001, and how to build a full record-and-play loop:
  • Record from microphone for 10 seconds (ES7210 capture path).
  • Play back the recorded PCM data for 10 seconds (ES8311 speaker path).
  • Repeat continuously to validate both RX and TX audio pipelines.
The audio path in this example includes three key parts:
  • ESP32-P4: Captures microphone PCM data and sends playback PCM data.
  • ES7210 (I2C address: 0x40): Converts analog microphone signals into digital I2S data.
  • ES8311 + PA control (PCA9535): Converts PCM to speaker output and enables the power amplifier for playback.
Microphone + Speaker Architecture​
Block Diagram (ES7210 + ES8311)​
Pin Mapping Table​
Signal GroupSignal NameESP32-P4 PinConnected DeviceDescription
Shared I2C ControlI2C_SDAGPIO20ES7210 / PCA9535Shared I2C data line for ES7210 configuration and PA control
Shared I2C ControlI2C_SCLGPIO21ES7210 / PCA9535Shared I2C clock line
Microphone I2S (RX)ADC_I2S_MCLKGPIO29ES7210Master clock for ES7210
Microphone I2S (RX)ADC_I2S_SCLKGPIO28ES7210Bit clock for ES7210 capture path
Microphone I2S (RX)ADC_I2S_LRCKGPIO27ES7210Word select (LRCK)
Microphone I2S (RX)ADC_I2S_SDOUTGPIO26ES7210PCM data output from ES7210 to ESP32-P4
PA ControlEN_PA (EXP_GPO11)PCA9535 P13Power AmplifierKeep HIGH when validating microphone + speaker loop playback
This table focuses on the microphone path. In this example, ES8311 also shares the same I2C bus for playback codec configuration.
Software Flow​
GitHub Example Repository​
Download the official reTerminal D1001 repository from GitHub:
Project Directory Structure​
The following diagram shows the project directory structure used in this example.
Please navigate to the record-and-play example directory for ES7210 + ES8311 in the repository (for example, driver_examples/02_I2SCodec_es7210).
Development Execution Sequence​
Step 1. Initialize PA Control via PCA9535​
The speaker path requires the PA enable pin to be asserted through PCA9535 (P13 = HIGH).
static esp_err_t pca9535_write_reg(uint8_t reg, uint8_t data)
uint8_t write_buf[2] = {reg, data};
return i2c_master_write_to_device(1, PCA9535_I2C_ADDR, write_buf, sizeof(write_buf), 1000 / portTICK_PERIOD_MS);
static void pca9535_init(void)
int i2c_master_port = 1; // Use I2C_NUM_1
i2c_config_t conf = {
.mode = I2C_MODE_MASTER,
.sda_io_num = MISC_I2C_SDA,
.sda_pullup_en = GPIO_PULLUP_ENABLE,
.scl_io_num = MISC_I2C_SCL,
.scl_pullup_en = GPIO_PULLUP_ENABLE,
.master.clk_speed = 100000,
i2c_param_config(i2c_master_port, &conf);
i2c_driver_install(i2c_master_port, conf.mode, 0, 0, 0);
pca9535_write_reg(0x06, 0x00);
pca9535_write_reg(0x07, 0x00);
pca9535_write_reg(0x02, 0x00);
pca9535_write_reg(0x03, 0x08); // Set P13 (EXP_GPO11) to HIGH
Step 2. Initialize I2S for ES8311 (Speaker TX)​
Configure one I2S TX channel for playback to ES8311.
static esp_err_t i2s_driver_init_es8311(void)
i2s_chan_config_t tx_chan_cfg = I2S_CHANNEL_DEFAULT_CONFIG(I2S_NUM, I2S_ROLE_MASTER);
tx_chan_cfg.auto_clear = true;
ESP_ERROR_CHECK(i2s_new_channel(&tx_chan_cfg, &tx_handle_es8311, NULL));
i2s_std_config_t std_cfg = {
.clk_cfg = I2S_STD_CLK_DEFAULT_CONFIG(EXAMPLE_SAMPLE_RATE),
.slot_cfg = I2S_STD_PHILIPS_SLOT_DEFAULT_CONFIG(I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_STEREO),
.gpio_cfg = {
.mclk = I2S_MCK_IO,
.bclk = I2S_BCK_IO,
.ws = I2S_WS_IO,
.dout = I2S_DO_IO,
.din = I2S_GPIO_UNUSED,
std_cfg.clk_cfg.mclk_multiple = EXAMPLE_MCLK_MULTIPLE;
ESP_ERROR_CHECK(i2s_channel_init_std_mode(tx_handle_es8311, &std_cfg));
ESP_ERROR_CHECK(i2s_channel_enable(tx_handle_es8311));
ESP_LOGI(TAG, "ES8311 I2S initialized");
return ESP_OK;
Step 3. Initialize ES8311 Codec​
ES8311 is configured for speaker playback format and volume.
static esp_err_t es8311_codec_init(void)
const i2c_config_t es_i2c_cfg = {
.sda_io_num = I2C_SDA_IO,
.scl_io_num = I2C_SCL_IO,
i2c_param_config(I2C_NUM, &es_i2c_cfg);
i2c_driver_install(I2C_NUM, I2C_MODE_MASTER, 0, 0, 0);
es8311_handle_t es_handle = es8311_create(I2C_NUM, ES8311_ADDRRES_0);
const es8311_clock_config_t es_clk = {
.mclk_inverted = false,
.sclk_inverted = false,
.mclk_from_mclk_pin = true,
.mclk_frequency = EXAMPLE_MCLK_FREQ_HZ,
.sample_frequency = EXAMPLE_SAMPLE_RATE
ESP_ERROR_CHECK(es8311_init(es_handle, &es_clk, ES8311_RESOLUTION_16, ES8311_RESOLUTION_16));
ESP_ERROR_CHECK(es8311_sample_frequency_config(es_handle, EXAMPLE_SAMPLE_RATE * EXAMPLE_MCLK_MULTIPLE, EXAMPLE_SAMPLE_RATE));
ESP_ERROR_CHECK(es8311_voice_volume_set(es_handle, EXAMPLE_VOICE_VOLUME, NULL));
ESP_ERROR_CHECK(es8311_microphone_config(es_handle, false));
ESP_LOGI(TAG, "ES8311 codec configured");
return ESP_OK;
Step 4. Initialize I2S + ES7210 (Microphone RX)​
Set up microphone capture from ES7210 through I2S RX.
static esp_err_t i2s_driver_init_es7210(void)
i2s_chan_config_t rx_chan_cfg = I2S_CHANNEL_DEFAULT_CONFIG(ES7210_I2S_NUM, I2S_ROLE_MASTER);
ESP_ERROR_CHECK(i2s_new_channel(&rx_chan_cfg, NULL, &rx_handle_es7210));
.gpio_cfg = {
.mclk = ES7210_I2S_MCK_IO,
.bclk = ES7210_I2S_BCK_IO,
.ws = ES7210_I2S_WS_IO,
.dout = I2S_GPIO_UNUSED,
.din = ES7210_I2S_DI_IO,
ESP_ERROR_CHECK(i2s_channel_init_std_mode(rx_handle_es7210, &std_cfg));
ESP_ERROR_CHECK(i2s_channel_enable(rx_handle_es7210));
ESP_LOGI(TAG, "ES7210 I2S initialized in STD mode (Stereo)");
return ESP_OK;
static esp_err_t es7210_codec_init(void)
es7210_dev_handle_t es7210_handle = NULL;
es7210_i2c_config_t i2c_conf = {
.i2c_port = I2C_NUM,
.i2c_addr = ES7210_ADDRRES_00
ESP_ERROR_CHECK(es7210_new_codec(&i2c_conf, &es7210_handle));
es7210_codec_config_t codec_conf = {
.sample_rate_hz = EXAMPLE_SAMPLE_RATE,
.mclk_ratio = EXAMPLE_MCLK_MULTIPLE,
.i2s_format = ES7210_I2S_FMT_I2S,
.bit_width = ES7210_I2S_BITS_16B,
.mic_bias = ES7210_MIC_BIAS_2V87,
.mic_gain = ES7210_MIC_GAIN_24DB,
.flags.tdm_enable = false
ESP_ERROR_CHECK(es7210_config_codec(es7210_handle, &codec_conf));
ESP_ERROR_CHECK(es7210_config_volume(es7210_handle, 0));
ESP_LOGI(TAG, "ES7210 codec configured");
return ESP_OK;
Step 5. Record 10s and Play 10s in a Loop​
Allocate a PSRAM buffer, record by chunks from ES7210, then write the recorded PCM to ES8311.
static void record_play_task(void *args)
int16_t *record_buf = heap_caps_malloc(RECORD_BUFFER_SIZE, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
if (!record_buf) {
vTaskDelete(NULL);
return;
size_t bytes_read = 0;
size_t bytes_written = 0;
while (1) {
size_t total_read = 0;
size_t chunk_size = 4096;
// Record phase (10s)
while (total_read < RECORD_BUFFER_SIZE) {
size_t to_read = RECORD_BUFFER_SIZE - total_read;
if (to_read > chunk_size) {
to_read = chunk_size;
if (i2s_channel_read(rx_handle_es7210, (uint8_t *)record_buf + total_read, to_read, &bytes_read, portMAX_DELAY) == ESP_OK) {
total_read += bytes_read;
} else {
break;
// Playback phase (10s)
size_t total_written = 0;
while (total_written < total_read) {
size_t to_write = total_read - total_written;
if (to_write > chunk_size) {
to_write = chunk_size;
if (i2s_channel_write(tx_handle_es8311, (uint8_t *)record_buf + total_written, to_write, &bytes_written, portMAX_DELAY) == ESP_OK) {
total_written += bytes_written;
} else {
break;
Step 6. Main Entry​
Initialize all modules in order, then start the record-play task.
void app_main(void)
printf("\n============================================\n");
printf(" Record & Play Example (ES7210 + ES8311) \n");
printf("============================================\n\n");
pca9535_init();
if (i2s_driver_init_es8311() != ESP_OK) {
abort();
if (es8311_codec_init() != ESP_OK) {
abort();
if (i2s_driver_init_es7210() != ESP_OK) {
abort();
if (es7210_codec_init() != ESP_OK) {
abort();
xTaskCreatePinnedToCore(record_play_task, "record_play_task", 32768, NULL, 5, NULL, 0);
Expected Serial Log Before Recording​
When using our example project, before the first 10-second recording starts, the serial monitor should print startup messages similar to:
PCA9535 initialized, P13 set to HIGH
=== Start Recording for 10 seconds ===
If these logs do not appear in sequence, check each init step return value first.
Troubleshooting​
Q1: No Sound During Playback​
  • Check: Confirm PCA9535 is initialized and P13 (EN_PA) is set HIGH.
  • Check: Verify ES8311 TX I2S pins and i2s_channel_enable(tx_handle_es8311) execution.
Q2: No Data Captured from Microphone​
  • Check: Verify ES7210 I2S RX pin mapping and i2s_channel_enable(rx_handle_es7210) execution.
  • Check: Confirm ES7210 I2C address and codec init return value.
Q3: Distorted Audio or Loud Noise​
  • Check: Keep sample rate and MCLK ratio consistent across ES8311, ES7210, and I2S configs.
  • Check: Reduce microphone gain (for example, lower than ES7210_MIC_GAIN_24DB) if near-field clipping occurs.
  • Check: If speaker output has continuous metallic noise or incomplete voice, verify channel slot config: slot_cfg = I2S_STD_PHILIPS_SLOT_DEFAULT_CONFIG(I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_STEREO).
  • Check: Ensure RX/TX channel alignment is correct; mono/stereo mismatch can cause broken or robotic voice.
