Frigate NVR with Raspberry Pi 5/CM5
Introduction​
Frigate NVR is an open-source network video recorder designed for real-time object detection with AI models. Paired with the Raspberry Pi 5/CM5, it enables efficient video surveillance at the edge. This guide will walk you through the installation and configuration process for an optimal setup.
Official Frigate​
Prepare Hardware​
reComputer AI R2130reComputer AI Industrial R2145reComputer Industrial R20xxreComputer Industrial R21xx
Alternatively, you also need at least one camera for video streaming. You can refer to Recommended hardware to see the recommended cameras.
Install Hailo PCIe Driver​
Step 1: Enable PCIe Gen 3​
Open a terminal and run the following command.
sudo apt update
sudo raspi-config
In the dialog, select 6 Advanced Options and then A8 PCIe Speed.
6 Advanced Options A8 PCIe Speed
Choose "Yes" to enable PCIe Gen 3 mode.
Choose Yes
Afterward, click "Finish" to exit.
Edit /boot/firmware/config.txt, append the following line at the end of the file.
dtoverlay=pciex1-compat-pi5,no-mip
Step 2: Install Hailo PCIe Driver​
Install the dkms package. This package is required to install the Hailo PCIe driver.
sudo apt update
sudo apt install dkms
Get Hailo PCIe Driver from GitHub.
git clone https://github.com/hailo-ai/hailort-drivers
cd hailort-drivers/linux/pcie
git checkout 24e7ff2fb58fab7029024c1a1d3f2d1914f56d7b
Then, install the Hailo PCIe driver.
sudo make install_dkms
After installation, download firmware for Hailo and copy it to the /lib/firmware/hailo directory.
cd ../..
./download_firmware.sh
sudo mkdir -p /lib/firmware/hailo
sudo cp hailo8_fw*.bin /lib/firmware/hailo/hailo8_fw.bin
To avoid PCIe max_desc_page_size issue, we also need to create a rule in /etc/modprobe.d/hailo_pci.conf with the following content.
options hailo_pci force_desc_page_size=4096
Restart the system to take effect.
sudo reboot
After the system is restarted, the Hailo PCIe driver is installed successfully. The /dev/hailo0 device will be created. Check the device by running the following command.
$ ls /dev/hailo*
/dev/hailo0
Install Frigate NVR​
In this part, we assume you have your camera set up and ready to stream with RTSP protocol in 1920x1080 resolution.
  • Example RTSP URL: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
Step 1: Prepare the Environment​
  1. Update your system:
    sudo apt update
  2. Install Docker:
    curl -fsSL get.docker.com | bash
    sudo usermod -aG docker $USER
  3. Reboot the system:
    sudo reboot
Step 2: Deploying Frigate​
  1. Pull the Frigate Image:
    Go to Package frigate, choose one image with -h8l suffix. In this example, we choose ghcr.io/blakeblackshear/frigate:0.15.0-rc2-h8l.
    docker pull ghcr.io/blakeblackshear/frigate:0.15.0-rc2-h8l
  2. Create Docker Compose File:
    Here is an example of the frigate.yml file, the hailo0 device is the one you created in the previous step, configuration files are in the ./config directory and data files are in the ./data directory.:
    services:
    frigate-hailo:
    container_name: frigate-hailo
    privileged: true
    restart: unless-stopped
    image: ghcr.io/blakeblackshear/frigate:0.15.0-rc2-h8l
    shm_size: 1024mb
    devices:
    - /dev/hailo0:/dev/hailo0
    volumes:
    - /etc/localtime:/etc/localtime:ro
    - ./config/:/config
    - ./data/db/:/data/db
    - ./data/storage:/media/frigate
    - type: tmpfs
    target: /tmp/cache
    tmpfs:
    ports:
    - 5000:5000
  3. Edit Frigate Config:
    Here is an example of the config/config.yml file, which is for the Frigate application:
    database:
    path: /data/db/frigate.db
    go2rtc:
    streams:
    home:
    - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
    cameras:
    home:
    ffmpeg:
    inputs:
    - path: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
    roles:
    - record
    - detect
    mqtt:
    enabled: False
    objects:
    track:
    - person
    - cat
    detectors:
    hailo8l:
    type: hailo8l
    device: PCIe
    model:
    width: 300
    height: 300
    model_type: ssd
    path: /config/model_cache/h8l_cache/ssd_mobilenet_v1.hef
    version: 0.15-1
  4. Start Docker Instance:
    docker compose -f frigate.yml up -d
    After the Frigate is up and running, you can access the Frigate web UI at http://<your-raspberry-pi-ip>:5000 to check the camera stream.
    frigate-web
Seeed Frigate​
Modify PCIe settings​
Open config.txt
sudo nano /boot/firmware/config.txt
Add the following text to config.txt
dtparam=pciex1_gen=3
Then use Ctrl+x to save the file and reboot the AI box
Install docker and hailo-all​
sudo apt update
sudo apt install hailo-all
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
sudo apt install docker-compose-plugin
Create yml file​
Create frigate.yml for docker compose to run frigate
cd ~
sudo nano frigate.yml
Here is an example of frigate.yml
version: "3.9"
services:
frigate-hailo:
privileged: true
image: mjqx2023/frigate_seeed:latest
shm_size: 1024mb
environment:
- HAILO_MONITOR=1
devices:
volumes:
- ./config/:/config
- type: tmpfs
target: /tmp/cache
tmpfs:
ports:
- 5000:5000
- 1984:1984
- 5002:5002
- 5003:5003
Download yolo model and create config.yml.
mkdir config && cd config && mkdir model_cache
cd model_cache && wget https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.14.0/hailo8/yolov8n.hef
cd .. && nano config.yml
Here is an example of config.yml
database:
go2rtc:
streams:
home:
- rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=1
home1:
yard:
yard1:
cameras:
home:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/home
roles:
- detect
motion:
threshold: 45
contour_area: 60
improve_contrast: true
yard:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/yard
roles:
- detect
motion:
threshold: 45
contour_area: 60
home1:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/home1
roles:
- detect
motion:
threshold: 45
contour_area: 60
yard1:
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/yard1
roles:
- detect
motion:
threshold: 45
contour_area: 60
mqtt:
enabled: false
objects:
track:
- person
- cat
detectors:
hailo8l:
type: hailo8l
device: PCIe
model:
width: 640
height: 640
path: /config/model_cache/yolov8n.hef
version: 0.16-0
camera_groups:
test:
order: 1
icon: LuAlignEndHorizontal
cameras:
- home
- home1
- yard
- yard1
Pull docker image and run frigate​
Pull frigate_seeed image
cd ~
docker pull mjqx2023/frigate_seeed
docker compose -f frigate.yml start
Then open localhost:5000 on your AI box web browser: frigate-web
