Get Started with LoRaWAN Tracker
This chapter shows you how to quickly set up your SenseCAP T1000-E LoRaWAN Tracker with the SenseCraft App.
Hardware Overview
Diagram
Pin Descriptions
| No. | Name | Function | Description |
| 1 | P0.00 | XL1 | Connection for 32.768 kHz crystal |
| 2 | P0.01 | XL2 | Connection for 32.768 kHz crystal |
| 3 | P0.02 | Digital I/O Analog input | Baterry level dectect |
| 4 | P0.03 | Digital I/O Analog input | Red LED IO |
| 5 | P0.04 | Digital I/O Analog input | VCC voltage dectect |
| 6 | P0.05 | Digital I/O Analog input | Charger insert dectect,must be configured as no pullup or pulldown |
| 7 | P0.06 | Digital I/O | Key IO, must be configured as input_pulldown |
| 8 | P0.07 | Digital I/O | LR1110 BUSY |
| 9 | P0.08 | Digital I/O | AG3335 VRTC EN |
| 10 | P0.09 | NFC input | NC |
| 11 | P0.10 | NFC input | NC |
| 12 | P0.11 | Digital I/O | SPI SCK |
| 13 | P0.12 | Digital I/O | SPI CS |
| 14 | P0.13 | Digital I/O | UART1 TX For AG3335 |
| 15 | P0.14 | Digital I/O | UART1 RX For AG3335 |
| 16 | P0.15 | Digital I/O | AG3335 RTC Interrupt |
| 17 | P0.16 | Digital I/O | UART1 TX For debug |
| 18 | P0.17 | Digital I/O | UART1 RX For debug |
| 19 | P0.18 | Reset | Reset |
| 20 | P0.19 | Digital I/O | QSPI Clock for FLASH |
| 21 | P0.20 | Digital I/O | QSPI CS for FLASH |
| 22 | P0.21 | Digital I/O | QSPI IO0 for FLASH |
| 23 | P0.22 | Digital I/O | QSPI IO1 for FLASH |
| 24 | P0.23 | Digital I/O | QSPI IO2 for FLASH |
| 25 | P0.24 | Digital I/O | Green LED IO |
| 26 | P0.25 | Digital I/O | Buzzer PWM |
| 27 | P0.26 | Digital I/O | I2C SDA |
| 28 | P0.27 | Digital I/O | I2C SCL |
| 29 | P0.28 | Digital I/O Analog input | NC |
| 30 | P0.29 | Digital I/O Analog input | Light Sensor ADC input |
| 31 | P0.30 | Digital I/O Analog input | NC |
| 32 | P0.31 | Digital I/O Analog input | Temperature Sensor ADC input |
| 33 | P1.00 | Digital I/O | QSPI IO3 for FLASH |
| 34 | P1.01 | Digital I/O | LR1110 DIO9 |
| 35 | P1.02 | Digital I/O | Accelerator Interrupt |
| 36 | P1.03 | Digital I/O | Charger State |
| 37 | P1.04 | Digital I/O | Charger Done |
| 38 | P1.05 | Digital I/O | Buzzer Enable |
| 39 | P1.06 | Digital I/O | Sensor VCC Enable |
| 40 | P1.07 | Digital I/O | Accelerator Enable |
| 41 | P1.08 | Digital I/O | SPI MISO |
| 42 | P1.09 | Digital I/O | SPI MOSI |
| 43 | P1.10 | Digital I/O | LR1110 RESET |
| 44 | P1.11 | Digital I/O | AG3335 PWR EN |
| 45 | P1.12 | Digital I/O | AG3335 SLEEP Interrupt |
| 46 | P1.13 | Digital I/O | Flash Enable |
| 47 | P1.14 | Digital I/O | AG3335 RESETB OUT |
| 48 | P1.15 | Digital I/O | AG3335 Reset |
Demo Firmware Overview
Positioning Description
| Location | Description |
| GNSS | Upload longitude and latitude info. (There is usually no GPS signal indoors, so it's recommended to test the device outdoors to get the location) |
| Wi-Fi | Upload the MAC address and RSSI info of the Wi-Fi AP. |
| Bluetooth | Upload the MAC address and RSSI info of the Bluetooth beacon. |
Button
| Button Action | Description |
| Long press for 3 seconds | Power on/off |
| Click button 3 times | Switch on/off Bluetooth |
| Double click | Switch on/off SOS alart |
| Click once | Upload location/battery/sensor data |
LED
| LED Status | Description | |
| Red LED | Solid | Charging |
| Flash | Abnormal charging | |
| Green LED | Solid | Device in DFU mode. Reboot the device to exit DFU mode(Press and hold the button, then release it immediately after connecting the charging cable) |
On 500ms/Off 1s | Bluetooth on | |
| Breath | Joining LoRaWAN network | |
| Quick flash for 2s and then off | Joined the LoRaWAN network successfully | |
Sensor Function
The SenseCAP T1000 Tracker is equipped with 3 sensors: Temperature sensor, Light sensor and 3-Axis Accelerometer. You can choose enable or disable these sensors:
When the sensors are turned on, the device will consume more power.
| Sensor | Description |
| Temperature | Onboard independent temperature sensor. here may be some temperature measurement delay here, because it is separated from the shell. Range: -20 to 60℃; Accuracy: ± 1℃(min 0.5℃, max 1℃); Resolution: 0.1℃ |
| Light | The light sensor is not the actual lumen value monitored, but a percentage of the light from dark to amount. Mainly can be used for anti-demolition monitoring and some light sensitive monitoring. Range: 0 to 100%, (0% is dark, 100% is brightest) |
| 3-Axis Accelerometer | By setting the value of acceleration, motion event and shock event are triggered. |
Battery
Battery life depends on factors such as uplink interval, sensor usage, LoRa transmission distance, and operating temperature. Predicted battery life is based on a typical working environment (25°C) and serves as a reference. Actual battery life may vary.
EU868(1C/SF12)
| Upload Interval | 1 minute | 5 minutes | 60 minutes | 1 day |
| Battery Life(day) | 2.46 | 11.72 | 84.68 | 184.86 |
US915(1C/SF9)
| Battery Life(day) | 2.89 | 13.66 | 92.59 | 186.83 |
Get Started
Press the button for 3s to power on the device, a rising melody indicates that the device has been successfully powered on.
Connect via App
- Step 1: Download
SenseCraftApp
Login to the SenseCraft APP.
Select Server Location as Global.
- Step 2: Add Device
Click Add Device tab on the top right, then scan the QR code on the device label.
Configure the Device
- Navigate to
User->Device Bluetooth Configurationpage.
- Click the button 3 times to enter the configuration mode. Device name: T1000-E xxxx(the last four digits of the MAC address).
Quick Configuration
For quick start with the SenseCAP cloud, you can select Quick Configuration.
Configure the Frequency Plan according to your region, and set up the Uplink Interval you want.
Advanced Configuration
For advanced usage, please select Advanced Configuration.
You can see the current device information, which includes the device EUI, hardware/software version, battery, etc.
Navigate to Settings to set up the parameters.
- LoRa Setup
| Parameters | Description | |
| Platform | SenseCAP for The Things Network(by default) | A proprietary TTN server of SenseCAP. Out of the box when paired with a SenseCAP gateway. SenseCA Outdoor GatewaySenseCA Indoor Gateway |
| SenseCAP for Helium | A private Helium console of SenseCAP. Out of the box with SenseCAP Mate App and Portal. | |
| Helium | Public Helium Server | |
| The Things Network | Public TTN Server | |
| Other Platform | Other LoRaWAN Network Server | |
| Frequency Plan | EU868/US915/AU915/KR920/IN865/AS923-1/AS923-2/AS923-3/AS923-4 | EU868 by default |
| Packet Policy | 1C | Enable by default |
| LoRaWAN ADR | Enable by default | Enable by default |
| Restore LoRa Configuration | Enable by default | Enable by default |
- General Setup
| 3-axis accelerometer | Enable/Disable, disable by default | Upload the data of the 3-axis accelerometer |
| SOS Report Mode | Single(by default) | Upload data and report SOS event once. Buzzer alarm for 3 seconds |
| Continuous | Upload data and report SOS event every minute, ends after 30 times. Buzzer alarm for 30 seconds | |
| Uplink Interval(min) | 1-10080min, 60min by default | Upload data at intervals. The higher the frequency, the higher the power consumption |
| Geolocation Strategy | GNSS only(by default) | Uses only GPS satellite systems to determine the position |
| Wi-Fi only | Upload the MAC address and RSSI info of the Wi-Fi AP | |
| Bluetooth only | Upload the MAC address and RSSI info of the Bluetooth beacon | |
| GNSS + Wi-Fi | Uses GPS positioning first, if GPS fails, then uses Wi-Fi in one geolocation cycle | |
| Bluetooth + GNSS | Uses Bluetooth positioning first, if Bluetooth fails, then uses GNSS in one geolocation cycle | |
| Bluetooth + Wi-Fi | Uses Bluetooth positioning first, if Bluetooth fails, then uses Wi-Fi in one geolocation cycle | |
| Bluetooth + Wi-Fi + GNSS | Use Bluetooth, Wi-Fi and GNSS for positioning in turn (switch to the next type of positioning after one type of positioning fails) | |
| GNSS(GPS) | GNSS Max Scan Time(s) | 10-120s, 30s by default |
| IBeacon Scan | Maximum number of BLE scans | 3-5, 3 by default |
| Scan Timeout(s) | 3-10s, 3s by default | |
| Group UUID(Hex) | Set UUID Filter, up to 16bytes. Forexample, if set as '01 020304', it will filter beacons with thepattern'0102 03 04 xx xx xx ...' | |
| Wi-Fi Scan | Maximum number of Wi-Fi scans | 3-5, 3 by default |
Device Data View
SenseCraft App
Check the Location on the APP.
SenseCAP Portal
The main function of the SenseCAP Portal is to manage SenseCAP devices and store data. It is built on Azure, a secure and reliable cloud service from Microsoft. Users can apply for an account and bind all devices to this account. The SenseCAP Portal provides a web portal and API. The web portal includes Dashboard, Device Management, Data Management, and Access Key Management. The API is open to users for further development.
- Dashboard: Including Device Overview, Announcement, Scene Data, and Data Chart, etc.
- Device Management: Manage SenseCAP devices.
- Data Management: Manage data, including Data Table and Graph section, providing methods to search for data.
- Subaccount System: Register subaccounts with different permissions.
- Access Key Management: Manage Access Key (to access API service), including Key Create, Key Update, and Key Check.
Device Data View
Log in SenseCAP Portal
If you have created an account through the APP, you can log in directly.
Select register account, enter email information, and click "register", the registered email will be sent to the user's mailbox
Open the "SenseCAP…"Email, click the jump link, fill in the relevant information, and complete the registration
Return to the login interface and complete the login
Check SenseCAP Portal User Guide for more details.
SenseCAP API
SenseCAP API is for users to manage IoT devices and data. It includes 3 types of API methods: HTTP protocol, MQTT protocol, and Websocket protocol.
- With HTTP API, users can manage LoRa devices, to get raw data or historical data.
- With MQTT API, users can subscribe to the sensor's real-time measurement data through the MQTT protocol.
- With Websocket API, users can get real-time measurement data of sensors through Websocket protocol.
Please check API User Guide for more details.
