Get Started with Meshtastic
note
When the device is in the states below, please don't manually reboot or turn off it. Or else the device can be dead.
  1. Not finishing the message transmission process
  2. Being configured
Flash Firmware​
Visit Meshtastic Web Flasher.
For Wio tracker Wio Tracker L2 Pro and Wio Tracker L2 firmware flashing, select the target device to Seeed Wio Tracker L2 and choose the latest firmware, then click Flash.
Switch on the device, click Enter DFU Mode, there will be a serial port named Tracker L2, click and connect it.
And then click "Flash". Don't forget to tick "Full Erase and Install" if you want to cover previous firmware.
Get Started​
UI Switching​
Go to Setting page -> Choose Reboot/Shutdown -> Long press the Bluetooth icon -> Click OK
The BaseUI switch popup appears when you long-press the Bluetooth icon.
If you just click the Bluetooth icon, you will enter Bluetooth mode. If so, long press the Bluetooth icon shown on the screen, the device will automatically reboot to MUI.
Phone Connection​
Step1. Find Node ID
Find MAC address on device sticker. The Node ID is based on the last four digits of the MAC address. The last digit should -2. For example, if the device is 29CA, then the real node if should be 29c8.
Step2. Get in Bluetooth Connection Mode
Go to Setting page, click Reboot/Shutdown, then click the Bluetooth icon.
While using MUI, please first switch to Bluetooth Pairing mode before pairing with your ohone. Or else your phone can not recognize your device.
The device will then reboot in Bluetooth mode. The Bluetooth pairing code will be shown on the screen.
Step2. Download Meshtastic APP
Click here to download Meshtastic APP.
Step3. Pair with Device
  • Select the target device on the Bluetooth panel.
  • Enter the code shown on the screen and then click Pair to connect the device.
Configure LoRa​
In order to start communicating over the mesh, you must set your region. This setting controls which frequency range your device uses and should be set according to your regional location.
Region List
Region CodeDescriptionFrequency Range (MHz)Duty Cycle (%)Power Limit (dBm)
UNSETUnsetN/AN/AN/A
USUnited States902.0 - 928.010030
EU_868European Union 868MHz869.4 - 869.651027
Refer to LoRa Region by Country for a more comprehensive list.
info
EU_868 has to adhere to an hourly duty cycle limitation of 10%, calculated every minute on a rolling 1-hour basis. Your device will stop transmitting if you reach it, until it is allowed again.
Go to Setting page, click LeoR Region, the device will automatically reboot.
Now that you have set the LoRa region on your device, you can continue with configuring any LoRa Configs to suit your needs.
Map Usage​
Step1. Enable GPS
You need to enable GPS to get position. This can be configured directly on device by long pressing the position icon.
Also, you can configure it on your phone APP.
Step2. SD Card Preparation
You need to format and install map in your SD card. For detailed SD card usage tutorial, please click here to view.
Step3. Install SD Card
Step4. View Map
Waiting for the map to load. After successfully connecting to Wi-Fi and obtaining location, the device will display an offline map.
Advanced Usage​
Connect via Website​
If you want to text messages and communicate with other nodes in the website, you can connect the device to the Meshtastic Website now.
Step 1: Switch to BaseUI
Step 2: Open the Website
Click here to go to the webstite.
Step 3: Add the new device
Click "+ New Connection".
Choose serial method. Open the device manager to see which port the device is connected to. Choose that port in the pop-up window.
Your device will be shown in the list. Click to connect. If the connection succeed, you can see the device status directly on the website.
Configure GPS​
You can adjust the update inerval and broadcast interval to obtain a more up-to-date location information.
For IOS, please turn on the Accurate Location. Otherwise, the positioning may deviate.
Sensor connection​
You can add sensor to the device via the grove interface. The following sensors have been verified to be compatible with the Grove interface on the device.
Sensor typeSensor Model
Environmental SensorPressureBMP085
TemperatureMCP9808 、PCT2075
Temperature & HumiditySHT31/SHTC3/SHT4X、AHT10
Temperature & Humidity & PressureBME280
OtherHeart Rate & SpO₂MAX30102
I2C KeyboardCardKB
  • Enable Telemetry to get sensor data. If you want to show sensor data on the OLED screen, enale on screen
For example, when a Grove BME280 environmental sensor (temperature, humidity and barometer) is plugged into the Grove interface, the readings can be displayed directly on the device's touchscreen:
BME280 display effect
Other Function​
Interaction MethodEffect
Long press home iconResynced
Long press node list iconEnters node filter page
Long press settings iconScreen turns off
FAQ​
Device can not pair with Phone via BLE​
  • While using MUI, please first switch to Bluetooth Pairing mode before pairing with your ohone. Or else your phone can not recognize your device. Go to Setting page, click Reboot/Shutdown, then click the Bluetooth icon.
  • While using BaseUI, after setting and enabling Wifi, you can only connect your device with your phone APP via Network.
Device can not connect with my Wifi​
  • Please make sure you are connecting a 2.4g Wifi. The devcie can not pair with 5G Wifi. Usually phone hot spot can be adjusted to be 2.4g in phone setting. So you can test your phone hot spot first.
  • Please enable Wifi after setting Wifi name and Wifi password.
Wifi is disabled when the wifi ip is empty and the wifi icon is grey. Wifi is enabled when the wifi ip is displayed and the wifi icon is white.
Device automatically turn off​
  • After the device turning on, it will turn off or reboot automatically after a while.
  • The serial port log ran for a while and then stopped.
This is possibly caused by manually and forcely rebooting or turning off the device when the device is in the following states:not finishing the messages transmission process, being configured......
Troubleshoot
You need to perform a flash erase, and the re-flash the latest firmware.
Screen stays black after flashing the firmware​
  • After flashing the firmware, the device cannot boot normally and the screen stays black.
Troubleshoot
  • Step 1. Press the RST button once to reset the device. In most cases, the screen will light up after the reset.
  • Step 2. If the screen still does not light up, try flashing the factory firmware or Meshtastic 2.8.2 beta first, and then re-flash the firmware you need.
Factory Reset​
If you want to restore to the default settings, you can do the factory reset. There are two methods for you to do the factory reset.
Go to Setting page, click Configure Reset, choose Factory Reset and then click the OK.
The device will reboot with default configuration.
Direct Message Fail​
NodeDB Reset​
NodeDB is the local database that stores information about nodes discovered in the current Mesh network. If you encounter a situation where you can't communicate with a certain node, it might be because your nodedB has stored outdated information for that node. You will need to update it.
Go to Setting page, click Configure Reset, choose NodedB Reset and then click the OK.
The device will reboot.
Exchange User Info​
Each node will periodically send its own node information, enabling other nodes in the mesh to "see" and "recognize" it. Two nodes need to exchange their node information with each other in order to be able to communicate with each other. If you are unable to send or receive private messages with another node on the list, you can manually prompt them to exchange information in the app.
Device entry in Settings
Regenerate Private Key​
Each node owns a public/private key pair. To exchange an encrypted private message, the sender encrypts it with the recipient's public key, and only that recipient's private key can decrypt it. Two nodes can therefore communicate privately once they know each other's public key. If one node keeps failing in private-message transmission, try regenerating its private key. After regeneration, delete that node from the other devices' node lists so they can reconnect and obtain its new public key.
Reboot the faulty device to make the configuration function.
note
After the key regeneration, other device needs to reconnect with the node. So it is better to delete the node in other device's node list.
Signal Quality​
  • SNR reflects the quality of the communication link. Normal device usually operates above -7 dB. Device with a SNR lower than -10 dB indicates poor performance.
  • RSSI is determined jointly by the device and its surrounding environment. Normal device usually operates above -110 dBm. Device with an RSSI lower than -115 dBm is considered to have poor performance.
    To achieve the best signal effect, please use the device in an open, unobstructed area with minimal interference for use.
Battery Mapping​
#define OCV_ARRAY 4180, 4040, 3864, 3800, 3745, 3710, 3687, 3663, 3623, 3482, 3300
Why is my position offset on other nodes?​
This is expected behavior, not a GPS or hardware fault. Each channel has a Position precision setting, defaulting to 13 bits. That rounds every position you broadcast to a ~±2.9 km grid (a privacy default for shared channels), while your own device shows its full-precision fix over Bluetooth — so your own position looks accurate but other nodes see an offset.
Precise location off, slider at ±2.9 km
To send full precision, enable it on every device:
  1. Open Channels in the Meshtastic app and tap your channel.
  2. Turn on Precise location (sets precision to 32 = full).
  3. Repeat on each device — the setting takes effect on the sender.
Precise location on (full precision)
CLI alternative: meshtastic --ch-set module_settings.position_precision 32 --ch-index 0
Note (firmware 2.8+): public channels (no key, default key, or single-byte key) are limited to 15 bits (~729 m). Use a private channel with a random key for full precision.
Resource​
